*** VRP MidSection X-pipe ***
Old Jan 31, 2009 | 01:25 AM
  #101
URnext's Avatar
SL55 AMG
Originally Posted by LZH
If you had any clue or experience with motorsports you would know that the first X pipe pictured is a bad design.
If I had any clue? LOL......Please explain your post to the same design X-Pipe (post#2, in case you cant find it)
https://mbworld.org/forums/w211-amg/...s-special.html
Old Feb 2, 2009 | 05:57 PM
  #102
Vadim @ FD's Avatar
S600TT, R350
Part of designing new Mid-Section was creating new flanges. Stock flange, on the right is 55 mm in diameter and only allows 51 mm (2'') pipe to be bolted on to the manifolds, new flange is 63 mm and allows 2.25'' pipe to be bolted on.
As I mentioned before the front section will be modular, allowing one to bolt it to stock, evosport, renntech or our shorties. There is also will be a front section for Kleemann headers, as well as full 3'' race setup. Either will be available with or without metal catalytic converters.
First prototype will done later this week.
I will have more pictures and pricing as well.
Old Feb 4, 2009 | 03:37 AM
  #103
abakja1's Avatar
2009 Nissan 370z Sport; 2005 AMG E55; 2005 Subaru Legacy GT LMT; 2004 Honda Element EX
Subscribed and waiting to see if this is a true bolt on for DIYers at home with a floor jack, jackstands, and hand tools (ie no torches,,etc).....My oem e55 sounds sedate....
Old Feb 4, 2009 | 03:58 AM
  #104
Ohbev's Avatar
E55 AMG Kompressor
y do e55's need x pipe's how come you cant just run 2 pipes all the way to the mufflers with out the 2 pipes touching ?
Old Feb 4, 2009 | 10:04 AM
  #105
bobgodd's Avatar
2004 E55
Not just E55's. Almost all cars can benefit from crossover pipes.
Old Feb 4, 2009 | 10:18 AM
  #106
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Well you can run 2 straigh pipes to the muffles if you retain the stock H pipe before the secondary cats.
IMO X pipe is the way to go.
Old Feb 28, 2009 | 09:26 PM
  #107
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
Any updates???
Old Mar 1, 2009 | 12:30 AM
  #108
bassn_07's Avatar
2006 E55 AMG
I have Vadim's mid section X-pipe and it definitely sounds mean. At first I thought it was little on the loud side but after driving with it couple of weeks I'm really beginning to love it. It got a little louder inside but definitely no too bad, but when you get on it....wow! I'll post up a sound clip when I get a chance.
Old Mar 1, 2009 | 04:59 AM
  #109
storm's Avatar
Mercedes,Porsche etc
. With the metallic catalysts, you remain emissions compliant and you don't have to clear CEL codes. Random has a nice selection of universal fit round metallic catalysts in tube sizing compatible with what VRP is doing. Lot's of us already have X-pipes or straight pipes in lieu of the factory resonator, so why force us to redo that section of the exhaust (i.e., no need to have TWO X-pipes in the system)? Plus, some of our X-pipes are superior to what's shown in the VRP photo above. Just sayin' . . . . .
Agree with you about keeping cats and just using racing cats,
however its is NOT true that racing cats like Kleeman or RANDON will not thrown cells,, they do and can,, I asked Kleeman and know like 2 people that have had this happen..
it all depends on the CEL count of the replacement CATS,,
the OEN mercedes puts on the car is 600 count,, primary and secondary,
so if you use a 200, cell, count I know this will throw a cell..
if you use a 400, I think you can get away with them,, without cell warning..
the way around this is to either clear them in ECU< or just put a spacer on the O2 sensor location to move O2 sensor a few MM's awaay from the hole out of the direct flow.. of the air..
I am looking at getting the Kleemans headers, and they say that their 200 cell cat will likely throw a cell warning but can fix it,,
I suspect if you use their headers and 200 cell primary, and then use a 400,or 600 seconday, perhaps this is avoidable.. though
Old Mar 8, 2009 | 09:55 AM
  #110
NSX2NV's Avatar
03' E55 Techtite Grey
[/QUOTE]
Anyone know who makes this X-Pipe?!?
Old Mar 8, 2009 | 06:07 PM
  #111
05VENOM's Avatar
Originally Posted by NSX2NV
Anyone know who makes this X-Pipe?!?[/QUOTE]
I'd also like to know!
Old Mar 8, 2009 | 06:39 PM
  #112
bobgodd's Avatar
2004 E55
https://mbworld.org/forums/w211-amg/...ry-delete.html
Old Mar 8, 2009 | 06:42 PM
  #113
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
not 100% sure but seems to me it was from "Kompressed"
Old Mar 8, 2009 | 06:45 PM
  #114
E55Pilot's Avatar
2004 E55
Not VRP....
Old Mar 9, 2009 | 06:09 AM
  #115
NSX2NV's Avatar
We need to find out. That seems to have the perfect combination of strait pipe, x-pipe, and large enough cross-over. Whoever posted it needs to give it's source cause I'm sure they will sell a few of them.
Old Mar 10, 2009 | 01:34 AM
  #116
Vadim @ FD's Avatar
S600TT, R350
Please provide data proving above statement.
Old Apr 1, 2009 | 04:22 PM
  #117
Scorcher's Avatar
2004 E55 AMG
Any news Vadim?
Old Apr 6, 2010 | 06:40 PM
  #118
Freshly's Avatar
E500 "The Diplomat" W211
Is this a quality X-pipe for my E500?
I am not sure what makes a "good" X-Pipe. I am thinking about buying his 1 month old X-Pipe that was installed on his 72 SS El Camino. It was professionally built in a local muffler shop. The X-pipe itself is 2-1/4 inches in diameter. When I tried to look up the specs for the OEM E500 exhaust Diameter to make sure it will fit, I found inconsistant numbers. Some said it was 3in some said it was 2.36in (60mm x 2mm). I need some help to try and figure this out. Thanks,
here are the pics:
