Two Heat Exchangers
Old 02-03-2009, 06:26 PM
aleksandar1099's Avatar
Mercedes
Two Heat Exchangers
So I was bored yesterday and walked in the garage. I started eyeing the stock HE just sitting on the self not doing anything, so I figured I would put it to work. I put it underneath the front bumper and it amazingly clears it with no issues. I think that it holds the same amount of coolant that adding a BMW powersteering resovuar would, plus it cools it...
After the bleeding the system (which took forever!!!), I decided to take it for a ride. The results are amazing!!!! The temps fall from 4 bars over 80 to two bars over 80 in less then 30 sec!!!!
If you have your stock HE laying around try it, it costs $10 in hose and clamps and makes a huge difference!!
Here is a pic of what I am talking about...
What do you think???
Old 02-03-2009, 06:30 PM
V12Godspeed's Avatar
Your worst nightmare...
That is very creative and an amazing idea. I am sure many will benefit from this. Extra cooling never hurts in these cars...
Old 02-03-2009, 06:31 PM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
Nyce... hope you dont bottom out!
Old 02-03-2009, 06:32 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
Very "cool" idea!!...
The only problem that I see is that you will have to be EXTREMELLY carefull not to run the car into something that can only SEE close that OE HE, because if it touch it just a very small touch....well...you probably know the rest if that can happen.
Besides that... It is good to spend our relaxing time thinking in DIY upgrades like this.
Keep it thinking!
Old 02-03-2009, 06:36 PM
Marcus Frost's Avatar
Real Cars
I think with the position of that h/e you are begging to puncture a hole in that unit, have your coolant leak all over (possibly without you knowing), and blow up your engine
Interesting idea though...
-m
Old 02-03-2009, 06:43 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
No doubt that’s a lot of cooling. Looks vulnerable though.
Old 02-03-2009, 06:56 PM
Ohbev's Avatar
E55 AMG Kompressor
did you feel any hp gains ?
Old 02-03-2009, 07:12 PM
alltrac's Avatar
2004 E55
i know of an E55 a upgraded HE in series with the stock HE. The stock HE is in the stock location with the upgraded HE in front of it. Its shoehorned in there but it fits. He also has the coolant/res tank in trunk separated...great setup...
Old 02-03-2009, 07:22 PM
Super Moderator
BenzoBoi's Avatar
W221
Nifty idea...
If you don't mind me asking...who is this?
Old 02-03-2009, 08:34 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
-m
That's ok, he's got plenty of coat hangers and baling wire to fix anything!
Sorry Aleks
Nick
Old 02-03-2009, 10:47 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Good idea. Now I presume you are not using the belly pan.
If the belly pan is modified to protect and still allow air to flow to the stock heat exchanger this will be a good upgrade.
Nice work again
Old 02-03-2009, 11:13 PM
shardul's Avatar
Nice work. I presume you are not using the belly pan.
Would this setup help if you have a stock heat exchanger.
Old 02-03-2009, 11:19 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Nice work again
The angle of the photograph may be deceiving - but judging by aleksandar1099's sig pic, he has a CF front lip, correct? It looks like the OEM HE hangs down ~1 inch LOWER than the CF lip... is that accurate, or is it an optical illusion from the angle of the pic?
If that's the case, I agree w/ others... one wrong crunch on a speed bump or piece of debris, and you'll be losing coolant in a hurry Props for the ingenuity, but I'm not sure this is a safe DIY set-up to run - YMMV.
Old 02-04-2009, 01:00 AM
Jspeed's Avatar
E63 biturbo
My friend did that too but with 2 same sized heat exchangers one in front of the other, won't the front one be totally blocking the air from the second one?
Old 02-04-2009, 01:07 AM
OXOJE55's Avatar
///AMG
interesting
Old 02-04-2009, 04:13 AM
dpavid's Avatar
2005 AMG E55
my thinking exactly...
Old 02-04-2009, 04:19 AM
dpavid's Avatar
2005 AMG E55
So you changed the Stock HE for an upgraded LET HE replacement, then added the stock one back on under the motor in series with CM30 pump?
That's it?!?! Would a CM90 pump make a bigger difference with increased volume? Someone's gotta have a creative way to protect the HE in this setup...
Anyone know how many passes the coolant makes in a stock HE and an aftermarket one? 2 passes? 4 passes?
Old 02-04-2009, 04:44 AM
The Godfather's Avatar
4 wheeled car.
Originally Posted by BenzoBoi
Nifty idea...
It's some ASian dude on the internet!
Old 02-04-2009, 11:36 AM
intellilogic's Avatar
'12 E350 Coupe (3rd Benz)
bars
You should put thin bars across the unity going from front to back, so they can slide. Don't attach the bars to the unit, attach them to something else that will hold during the hit. Once you have hit once, it will probably **** on these bars... but they will be cheap, so replace them. I would also put a bar that connects the 4 bars, on the inside, as to not touch on the sled effect, just before and after the heat exchanger.
Now the question is where do you attach those bars? Weld them to 'Happiness' and use a good metal like 'hope' LOL
Green is HE, because it costs money - heh
As thin as these bars that attach to the pipes, just a little insurance, w/o compromising.
Just a random idea
Old 02-04-2009, 01:00 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
not sure how an additional h/e on the i/c circuit can show significant results on engine cooling???
Old 02-04-2009, 03:18 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
need to split the circuit for better cooling results?
Old 02-04-2009, 06:06 PM
bobgodd's Avatar
2004 E55
Old 02-04-2009, 06:13 PM
Mercedes
The intercooler clears the bottom of the car flush to the carbon fiber lip....
I think I am going to split the circut, because it is still tied together with the cooling system.
intelligic- I like the idea of the cage around it! I might have to try to do something like that!
Old 02-05-2009, 02:57 AM
alltrac's Avatar
2004 E55
Nifty idea...
its a wht e55 here in south fla. Im not sure if hes on the forums or not, but his friend is JBMFCAR is his screen name. Its seems to work pretty good. As far as the front HE blocking the air flow to the rear...probably to some extent, but it should get decnt flow. Many high performance cars have huge intercoolers in front of the radiators...the radiators get decreased, but adequate airflow at speed...probably the same situation with two HE...
Old 02-05-2009, 09:43 AM
J 2OOI's Avatar
2012 JDM
Hey MacGyver, I mean Sasa, I suppose you want a re-match now that you have the extra goodies.... Spring just can't come soon enough!
Quick Reply: Two Heat Exchangers
