Transmission thump
Old Feb 16, 2009 | 12:38 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Transmission thump
When the car is cold, I get a thump when I shift into reverse or drive.
Also in 3 gear when I gently press on the throttle I get a vibration comming from the drive line. Could this be transmission mounts going or a flex disc going bad.
Old Feb 16, 2009 | 01:28 PM
Finny's Avatar
03 E55 AMG
It's the diff.
Oh yeah... or water in the Tranz.
Old Feb 16, 2009 | 01:39 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
it absolutely could be the transmission mounts. i had similar problems after someone at the dealer forgot to tighten all 6 of the crossmember bolts down on my car. it's any easy place to start so check them asap!
Old Feb 16, 2009 | 01:41 PM
shardul's Avatar
Originally Posted by Finny
It's the diff.
wow how can water get in the transmission.
Old Feb 16, 2009 | 01:42 PM
shardul's Avatar
will check them asap.
Old Feb 16, 2009 | 01:53 PM
chiromikey's Avatar
there was a known problem with coolant lines leaking into the trans on older models.
Old Feb 16, 2009 | 01:58 PM
shardul's Avatar
Physically can I check this?
As far as I know my car is not leaking any fluids. Coolant level is constant.
Old Feb 16, 2009 | 07:22 PM
Finny's Avatar
03 E55 AMG
Internaly through the radiator core.
There will be no sign of leaking so you will need to check the tranz oil color by using a dip stick tool or undo the tranz sump and get a sample from there.
If your under warranty, no probs... if not, then get ready to get ripped a new one.
Old Feb 16, 2009 | 07:27 PM
jangy's Avatar
2015 S212
On the opposite side, is it normal to see oil floating in the radiator reservoir?
Old Feb 16, 2009 | 07:30 PM
chiromikey's Avatar
i think you know the answer to that...
Old Feb 16, 2009 | 07:42 PM
Finny's Avatar
03 E55 AMG
No... that doesn't appear to be healthy but could it be due to after market additives.
If there is frothing in the water, a whitish brownish color then it's hit the fan.
Old Feb 16, 2009 | 08:07 PM
jangy's Avatar
2015 S212
I didn't think it was either, but a number of cars at Famosa had some drops of oil floating at the top when the radiator cap was removed. It wasn't a load, but like a mL max.
Mine is clean but I wondered if it is something that comes with age...
Old Feb 16, 2009 | 08:55 PM
shardul's Avatar
Thanks finny. What color of fluid should I be looking for, if there is water/coolant in the tranny. Also what is the color of regular fluid.
