CEL Code & Trouble Shoot ?
P0128 - Check Coolant Valve (something along those lines for the message)
http://www.obd-codes.com/p0128 (some info related to the code, i've found)
I know the code does not in essentially hurt anything in the engine so I've reset it considering it's telling me my engine isn't up to normal operating temperature in a set amount of time. I was wondering what are the necessary steps to fix this CEL?? Changing a faulty thermostat?? Even though my car is running fine... I'm kind of lost on where to start on such a broad CEL code.
TIA
Craig
First question, are you the original owner?
Second question, Did you know some of the early LOW temp thermostats (aftermarket) would throw this code.
Here is a link with some info,
https://mbworld.org/forums/w211-amg/...hermostat.html
Quick check of the code on search engine only turned up a handful of people with problems.
Benz sensors go bad all the time so if it's not your thermostat, I would replace the sensor next.
Not sure where the darn sensor is for that but if it's cheaper, maybe swap the sensor first.
Any overheating problems?
This is a little off topic but here's a link to my pictures of the car 3 weeks before it got macked by a drunk driver head on at 80MPH - the car saved my life.
http://www.audizine.com/forum/showthread.php?t=241670
Here is a goodly amount of information for us Tech/diyers.
http://www.startekinfo.com/StarTek/
