PULLEY IN STALL HELP!!!!!!!
CLS55 AMG 030
Ok so my friend is removing my pulley for me but cant find the tensioner to loosen the belts any help would be appreciated. thanks
^ very true.
Anyway, when facing the engine compartment. S/C belt tensioner is toward the upper left. The accessory belt is more difficult. The tensioner is at the right side of the waterpump. 17mm iirc, for the tensioner. On both there is a hole to place a small punch or even a allen key which will lock the tensioner in an untensioned position.
CLS55 AMG 030
Well he is a FERRARI mechanic so Im guessing if he has worked on $60k bottom ends for 3 years I''l trust him with a mercedes engine , and if anyone has worked on a Ferrari you will know how much less complex and simple it is , THANK YOU to the people who had some thing use full to say.
Well he is a FERRARI mechanic so Im guessing if he has worked on $60k bottom ends for 3 years I''l trust him with a mercedes engine , and if any has worked on a Ferrari you will know how much less complex and simple it is , THANK YOU to the people who had some thing use full to say.
If you don't mind me asking what pulley did you go with?
CLS55 AMG 030
No not yet , he decided to just do it at my house so he went over and pulled the engine cover , intake tubes , and radiator fan , then he was going back tomorrow with a crank pulley tool and finish it up. I decided to go with a 180mm LET pulley
2015 S212
Don't have it done at the house. Has he done SC pulleys? Not being rude, but you really do need a lift to TQ the bolt proper like.
I am in no way doubting his skills or anything. I just think you should MAXIMIZE your chances of success.
Hope you enjoy..
Hope you enjoy..
CLS55 AMG 030
ok , thanks for the help , i guess I'll have him take it to the shop he works at I didnt know you need to lift it to torque it properly. thanks
CLS55 AMG 030
I have a Floored Fab. HE . Im doing floored Fab. long tubes , VRP intake along with the 180mm pulley and Dyno Comp here in AZ is having a RENNtech tune special on custom tunes , so thats what I will be going with I will post dyno results in August when its done. Thanks
FWIW, I have worked on my Ferrari myself when I had it and the E55 motor is an antique compared to a modern V8 Ferrari motor so i would still be skeptical about someone that can't find a tensioner on a belt.
THat being said, I am sure he will do I fine job as long as he is careful and torques it properly.
2015 S212
SWEET!!!!! Nice gear.
1 Post
2004 S55 AMG
Cut the guy a break. Its not like the people havnt asked about this in the past.
This is what a forum is about. Asking questions and getting help.
I have done my pulley change myself without a lift but have come on here to ask questions on the install.
For the OP there are 2 tensioner
CLS55 AMG 030
Everyone can calm down now he found the both tensioners. But all you guys might be right he should pry stop working on my far superior Mercedes and go back to the inferior $500,000 Daytona in the shop or go back to maintaining the two $250,000 F430 Challenge race cars.
Good luck and I'm sure your car is in good hands.
CLS55 AMG 030
no its all good , thanks. He did most of the work last night he just has to pull the actual pulley this morning.
CLS55 AMG 030
