hood wont open
Thanks in advance,
Johnny
Sometimes they break as well, so you need an extra set of hands to hold the cable down while you are pulling on the cable.
Good Luck!
The passenger side latch wouldn't trip. Under the valence, there's a flap that you can open. I was able to stick my arm up and find the plastic cover that is around the latch. The passenger side latch has a sensor on it, which is covered to protect it. You can basically pull down on the cover and detach it, then get someone to pull on the cable so you can feel what is supposed to move to trigger the latch. Push on that little lever towards the driver side, and it should pop. I didn't need to remove any wheel well panels- all I did was jack the car up a bit for easier access to the flap. You can also remove the lower grill to get access if you can't jack the car up.
Hope this helps!
