Houston Caravan to the Texas Mile 10/17
Would anyone be interested in forming a caravan from the south west houston area?
We could meet up and then drive down all together. They have some pretty good breakfast places in the country, probably make a pitstop there.
Does anyone know if rick aka rarfinancial is participating this year?
Shardul, thought you were leaving early for a little side Dyno action??
They may have a spot for me, if I decide to run last minute.
I fear the extreme heat backed up by these damn stock manifolds!! May have to run in March..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
He said he was and a few others. Jcart?
I fear the extreme heat backed up by these damn stock manifolds!! May have to run in March..Trending Topics
www.ultimatepd.com
Hey Brooke if you are headed down early you better stop in Hillje and pick up some Jalapeno, sausage, cheese bread
http://www.texasmile.net/
it is a lot of fun!
I was going to stop and pick up some bread for you, you read my mind.
Scott,
Can you bring your camera, a photoshoot is required.
Ok so what would be a good time to leave hoston.
Also if the weather predictions are correct - cars are going to have a 10mph tail wind. Not as good as the tail wind in March but, will allow 5-10mph faster speeds than normal Texas Mile conditions.
See y'all there. Bring your sun screen.
