Star Diagnostic How To DIY with lots o pics
Rating: Thread Rating: 15 votes, 5.00 average.
Old Feb 11, 2012 | 06:12 PM
  #476
GRAFH's Avatar
2005 E55 AMG
Awesome thread, can someone list all the components needed to get this program to work?
1) program
2) cable
3) laptop
Is that it? Also who is selling the program?
Old Feb 11, 2012 | 06:21 PM
  #477
Duc1098E500's Avatar
Honda Metropolitan
Originally Posted by GregMB
Just start pushing buttons.....what's the worst that could happen?
If you are too lazy to read what already been shared, I'm pretty sure we're too lazy to spoon-feed you that same exact information.
-G
LMAO
@ start pushing random buttons.
Old Feb 11, 2012 | 07:38 PM
  #478
210e55's Avatar
Mercedes
Any way to get foglights to come on in auto light setting for w211? It was asked a few times in this thread, but was never answered. Didn't see anything in SDS for it, but maybe someone knows??
Old Feb 12, 2012 | 11:52 AM
  #479
moosejaw's Avatar
none
If you are too lazy to read what already been shared, I'm pretty sure we're too lazy to spoon-feed you that same exact information.-G
Good Line!
Old Feb 12, 2012 | 11:01 PM
  #480
Lori3657's Avatar
BMW
I think he means the fogs will work like the new cars do. The fogs don't actually turn.
They are connected to the steering sensor. When you are turning left, the left fog light will come on...etc.
At least i am assuming that's what he means.
Old Feb 12, 2012 | 11:17 PM
  #481
210e55's Avatar
Mercedes
Yeah, I saw that question, but I was referring to the other post that asked if there was a way to have both fogs turn on with the headlamps in the auto position. That way you would never have to touch the headlamp switch. Would be nice if there was some hidden option to turn this on.
Old Feb 13, 2012 | 03:15 AM
  #482
wannarace55's Avatar
Will star lower a 03 cl55
Old Feb 13, 2012 | 10:25 PM
  #483
William88's Avatar
BMW
Aleksander, is it possible for you to make DIY for -10 Mod I know that I am asking for too much
Old Feb 14, 2012 | 02:53 AM
  #484
Rmayrap's Avatar
2015 S550, 2014 640i
has anyone in the st louis area been able to lower via star yet? willing to pay obviously.
Old Feb 24, 2012 | 06:44 PM
  #485
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Lowered a members E63 amongst a few other options. Found and activated a sunroof memory function. Essentially once you open your sunroof and leave it at a spot for a few seconds, the next time you auto open, it will move to that position and stay. Pretty cool. Will check my E55 to see if it's in there also, just do not use my sunroof often.
From memory.
control units/body/overhead control/pano/adaptions
Also interesting was the fact that there was an auto close function for the pano roof listed in the menu, yet even enabled could not get it to auto close. From what I understand these cars do not have a pinch strip so auto close was not an option, yet in STAR under pano roof, it's there......
Old Feb 24, 2012 | 06:49 PM
  #486
Roverron's Avatar
ML63
What national version is this car using certain features work in certain versions.
Old Feb 26, 2012 | 04:15 AM
  #487
george7380's Avatar
2006 s430 4matic
Got a mb star c4 in long island. pm me if you need stuff done.
Old Feb 28, 2012 | 09:49 PM
  #488
Ag02m5's Avatar
stuff
Hey STAR gurus. We have adjusted my 07 e63 a few times with STAR without issue. We went for a third time to even it up and now it won't retain the settings. It isn't particularly low and the STAR system says that the settings were succuessfully saved. However, after making adjustments via the raise/suspension buttons, the car lowers back down to a point significantly lower than where we had it set. Any ideas? Thanks. RT
Old Feb 28, 2012 | 09:58 PM
  #489
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Mine will do this on ocassion
depending on what height I am calibrating for. At my current setup, I have to program the front to sit .25" higher than intended and the rear at .5" higher than intended because it lowers by that much after I use the raise button or if I shut the car off and turn it back on.
Old Mar 16, 2012 | 01:11 PM
  #490
DGSU4EA70's Avatar
2005 E55 (FST N OC)
Originally Posted by aleksandar1099
So I thought I would help out a few MB brothers with a couple star diagnostic tutorials...
First, Lowering the car.
Get to the 211 Section
You will get to the main menu
Then go to Func perf by more than...
Then Chassis
Then Level adj
Then Suspension
And here is where people have problems, they just go to actuations and then lower it, IT WILL NOT STAY LOWERED this way, you have to go to initial startup
Then Initial with manual settings
Then F2
Here you will see a screen that shows the voltages which correspond to the height of the vehicle. they must be within the given ranges in the left hand column. use the + and - buttons to lower the car (In my screenshot I am in the car with a friend in the back seat, so that is why it is at 3.27, it should not exceed 3) Then hit F2
Enter in these inclination angles and if the car is within the voltages supplied in the page before, the car will accept the new lowered setting, if not it will reject it.
Now, how to activate the unlock and lock beep (honestly, one of the best mods to do if you have an older model e55 )
First Control units
Then Body
Then rear SAM
Then Control unit adaptations
Then national version of ATA function
At this screen you will see a pull down menu with a list of different regions on it. The only ones you need to worry about are USA with buzzer and Netherlands. If you choose USA, i will give you three short quick beeps when you lock the car and one short when you unlock it. Netherlands will give you three longer beeps when you lock the car and one long when you unlock it. Personal preference on which one you like. Then hit F3
Then F3(YES)
Hope this helps out some people. I really did not find a good DIY for Star Diagnostics, so I thought I would help out!
Aleks
EDIT: Info for -10 Mod added
Alek: Do you know how much dealerships usually charge for this lowering?
DG
Old Mar 22, 2012 | 02:01 PM
  #491
cwmateiuc's Avatar
2006 E55 AMG
Did you really have to quote the whole thing?
If you read, you'll see how much dealers charge on average for it.
Old Mar 22, 2012 | 03:37 PM
  #492
DGSU4EA70's Avatar
2005 E55 (FST N OC)
I admit that was pretty stupid!
My MB mechanic is going to do it for a bottle of JW Blue....
Old Apr 12, 2012 | 09:45 PM
  #493
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
From memory.
The sunroof memory is an annoying feature - I would not recommend you turn that on. It pretty much kills the one touch open feature - prevents the roof from opening all the way.
And you are correct, there is no way to enable the pano auto rain close.
Old Apr 13, 2012 | 01:24 PM
  #494
Benzer0matic's Avatar
08' E350 4matic
One thing I haven't tried yet is to set it to ROW to get the pano roof auto rain function to work.
Old Apr 13, 2012 | 11:47 PM
  #495
Polar Bear's Avatar
I don't think that will work either because you have to have the CGW in RoW to get the rain close feature to appear in the UCP.
Old Apr 17, 2012 | 06:50 AM
  #496
aleksandar1099's Avatar
Top Answer: 1
Mercedes
Been getting a lot of PMs lately. If anyone is interested let me know if you are in the Chicagoland area. I would love to help out!
Aleks
Old Apr 21, 2012 | 01:01 AM
  #497
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
Where can one buy or obtain a true OEM Unit? Or at least a real good copy Money is not a factor if its $12,000 its 12 grand....Autologic you get what you pay for thats why I drive a benz not a toyota...
Old Apr 22, 2012 | 03:41 AM
  #498
mercedesfreak29's Avatar
C32 AMG
Hi all. Maybe someone can help me. I am from Germany so my English is not so good.
Have the following problem:
When I go to my Star Diagnosis on ECU diagnostic 2.8ME Drive Motor Controller Implicit coding, I'm only in 0224 several 250 km / h versions to choose from, but it should also be other possibilities exist. It's all coded in RDW.
Star Diagnosis Version 11/2011
Is there a solution?
Stephan
Old Apr 23, 2012 | 05:38 PM
  #499
munich55's Avatar
E55 AMG W210 - sold, E55 AMG W211 - sold, CLS 500 C219 - sold, E63S AMG W212 - sold, C63S AMG A205
Can somebody explain me how i can Eliminate the Seat Belt alarm ?
Thx
Old Apr 24, 2012 | 01:50 AM
  #500
C32 AMG
Thx
Dann kannst Du zu mir kommen, ist von München 50 min. weg.
Gruß Stephan
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
