Star Diagnostic How To DIY with lots o pics
Auto Folding Mirrors coding: Several menus required.
Information & Communication > IC Instrument Cluster > Control Unit Adaptations > Select your MY > Variant Coding > Special Equipment > Mirror Fold-In > PRESENT
Body > System Diagnosis > Control Unit Adaptations > Read Coding and Change > Programming of Vehicle Equip > Folding Outside Mirrors > FITTED
Seats/Doors > DCM-FL > Adaptations ->Read Coding and Change > Fold In Outside Mirror When Locking> ACTIVATED
You should now have the option in your Speed Cluster under Convenience.
Quick Video in action
http://youtu.be/aORp1eu3Xas?hd=1
Is this done in Monaco or Vediamo. I have not used these in a long time and can't figure out how to kick them off
After I select Control Unit Adaptations, I am not able to Select my MY. There is no option for that. This is probably what is keeping it from working.
If anyone has any ideas, I would really appreciate it.
Information & Communication > IC Instrument Cluster > Special Equipment > Mirror Fold-In > PRESENT
When I found it there and changed it, everything is working. Thanks for all of the help on this thread.
i only have a sds (china version)
this is the faultcode i have p060c00 there is an internal control unit central processing unit
i hope someone here can guide me
I also have the SRS light on and can not get into AIR BAGS on the screen. Tells me no power but there is.
All codes are clear after QUICK TEST/SCAN as well but there shows no faults when doing a scan for air bags.
Any one run into this ?
http://www.chinaobdshop.com/free-shi...48227af95bf1b2
Without knowing anything about your situation...did you set the lan ip address correctly?
The ethernet cable is plugged into your laptop and the multiplexer?
And the ODB cable is plugged into the car and the multiplexer?
Thanks for making it a sticky, I'm sure this will take out some of the mysteries people are charging big money for!
Aleks
