Star Diagnostic How To DIY with lots o pics
#176
I was at the dealer today and asked if the tech could lower my car using SDS. The advisor asked the tech who said that using SDS (Star) to lower my E55 would work, but that I would get error messages due to the ride height sensors.... Is this true?
#177
No error messages at all.
#179
#182
Is it possible in Star to disable the malfunction message "Headlt. Cornering" ? The repair bill on my e55 is close to $2000.00 to fix this small feature and I would prefer not to be reminded of it everytime I get in the car.
Thanks so much.
Thanks so much.
#183
Hi Guys. Quick question. I printed this guide out for lowering the car with SDS and sent it to my SA. I am dropping the car off this morning to hopefully have it lowered. I would only like to lower it by a small amount possibly an inch. How low have you all gone with yours and what are the settings that you recommend using in Star? Thanks!
#184
Well, after 3 days in the service dept, the techs said that they couldn't lower the car. They set the car to the ride height defaults, aligned the car, then lowered it and they say that they could not get the car to align properly when it was lowered. I guess I will just have to be happy that I can pick up my car and drive it for once. Fingers crossed I go more than a week before I have to take it back in.
#185
Super Moderator
bone stock E55 AMG
#186
I spoke with the service manager and he said that they had the car on the rack with the ride height set to default. He explained that as they lowered the car, the alignment would go out of specs. He did say that they aren't experts at lowering since it is an "unusual request". I will put my lowering on hold. -Anyone in St. Louis have a source?...apparently Plaza Motors can't do it.
#187
If you want to lower, go with Lowering Links or ELM. Links will run you $300 and ELM more around $1000.. Mixed feelings on the links, but a lot of people run them with no issues. If you are handy, you could make a set for about $20...
#188
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
So I read thru all 8 pages and did not see it...
Do I have to realign my e63 after lowering it?
Do the voltage settings as noted earlier for the E55, apply same for the E63?
My local perf shop just acquired STAR program and we will using my car as a guinea pig. We will also do the other things noted:
Seat belt chime
155 Limiter remover
Key fob chime
Thx for the helpful thread guys!
Seat belt chime
155 Limiter remover
Key fob chime
#189
97 Volvo 850, 05 E500
Seat belt chime
155 Limiter remover
Key fob chime
Seat belt chime
155 Limiter remover
Key fob chime
How do you remove the limiter and the seat belt chime?
#190
Seat belt chime
155 Limiter remover
Key fob chime
Seat belt chime
155 Limiter remover
Key fob chime
#191
Sasha: no idea, we have not dived into it yet. My car is in storage right now. It's winter time here in MN.
Mike: ahh, good to know that the 55 an 63 are different. I will have to find the proper voltages then. I believe another forum member has lowered their 63 via star, I'll find who it was. Thanks for the advice!
#192
I am trying to lower my car via star and am having some problems. I have followed the instructions the best I can on the e55 page but the S65 w220 seems to have some different steps. I can get the car to lower by pushing the appropriate function keys but it will not save the values if you lower it more than a half an inch, even though the angle values entered are with in spec. Then if you do lower it star makes you perform a load adjustment test that once completed puts the car right back to the original height.
Can some one please give me a quick tutorial on how to lower on S or CL via star?
It also does not list the ride height voltage value range like on the E55 cars, it just gives the angle spec. Does anyone know what. Voltage values are acceptable? It seems to fail below around 2.2 volts.
Thank you.
Thank you.
#193
For those of you working on CL's and S classes (W215's and 220's), please see this thread for issues I have been having.
If anyone has some pointers for CL's and S's on lowering and the 10C mod please let me know.
https://mbworld.org/forums/s55-amg-s65-amg-s63-amg-w220-w221/383387-need-star-lowering-help.html[/URL]
#195
1 Post
E320 CDI
no extra sbc functions can be added in DAS dev mode. Tank Info can be added.
http://www.digital-kaos.co.uk/forums...21-more-89321/
#198
1 Post
CLS 55 AMG (Fully branded CLS 63 AMG / Special Color Ferrari Grigio Titanio)
top thread, will try this tonight!
theres a few other things you can do with star in dev mode which may be of interest
1. Activate VIM
2. Remove VMAX (speed restriction)
3. Activate Remaining fuel display in IC
4. active cornering fog lights
5. Alarm beep on activation
5. Seat belt alarm deactivate
6. flashing brake light on hard brake\flashing hazards
I will add locations in star for these functions over the next few days after i have confirmed them!
Any other functions which should be in the list, add away!
Alps
1. Activate VIM
Alps
I have a MB Star C4 but do not speak a german word...
Could you please tell me what is the option on that screenshot to disable the speed limitation (enable V-Max) ?
Regards
#200
1 Post
Hi,
I found the appropriare option for V-MAX with the DAS SIM... Thanks
But I would like someone to confirm there is no need to power the C4...
Actually, my C4 does not power ON when connected to ODB plug...
I tried to power it with a 12V power supply using the wire attached to RS232 cable, and LED light is turning on but still have a "voltage" error message when trying to enable connection with control unit...
Is the C4 supposed to be powered by the car when plugged into ODB plug ?
If yes, what is that female Jack plug attached to RS232 cable ? Is it to power a touchscreen or a laptop ?
Thanks for your help !!
