05 E55 First Gear "thump" HELP!!
In first gear, from a complete stand still, I press the gas. Not floored and not light, about 35%-40%. The car starts rolling and then there is an apparent and obvious "thud" under the hood and the car takes off. If I had to compare it to anything I would compare it to engine mounts or transmission mounts going bad. If you know what that feels like, well, this is similar. I took the car to BH Benz, with a warranty, and they could not figure out what was wrong with it. They checked ALL the mounts, bushings, transmission, and a slew of other common issues. The car is tip top. Very interestingly, one of the techs asked if I've had my car tuned. The answer is yes, I got the LET tune about two months ago. He asked if I remember if the problem was occuring before the tune nad I explained that I cant remember my girlfriends name from time to time. He suspects that the "thud" could be because of the tune, not dangerous to the car at all, simply a clutch delay for more power. Anyway, I wanted to know if any of you guys have had experiance with this mysterious "thud" at low RPM's and if anyone has figured out what it is? LET guys I still love you and appreciate what you've done with the car, just want to know if anyone has an answer!?
and definitely the SUPERCHARGER clutch. I was reading that the engaging gets rough as they get older. Just got used to it... In first gear, from a complete stand still, I press the gas. Not floored and not light, about 35%-40%. The car starts rolling and then there is an apparent and obvious "thud" under the hood and the car takes off. If I had to compare it to anything I would compare it to engine mounts or transmission mounts going bad. If you know what that feels like, well, this is similar. I took the car to BH Benz, with a warranty, and they could not figure out what was wrong with it. They checked ALL the mounts, bushings, transmission, and a slew of other common issues. The car is tip top. Very interestingly, one of the techs asked if I've had my car tuned. The answer is yes, I got the LET tune about two months ago. He asked if I remember if the problem was occuring before the tune nad I explained that I cant remember my girlfriends name from time to time. He suspects that the "thud" could be because of the tune, not dangerous to the car at all, simply a clutch delay for more power. Anyway, I wanted to know if any of you guys have had experiance with this mysterious "thud" at low RPM's and if anyone has figured out what it is? LET guys I still love you and appreciate what you've done with the car, just want to know if anyone has an answer!?
I guess as they get old the components just wear out. Also, thanks for letting me know I'm not the only person who's experiencing the issue.
a freind has the same problem and when he changed the gear map. it is ok.
though maybe your car has a diffrent problem. but if there is a delay between shifting through the gear it is not a mechanical problem.
