Scanguage installed for IAT's and Boost monitoring et
I can now see:
IAT's (Intake Temps) VERY IMPORTANT ON OUR 55's!
Boost pressure in PSI
Timing
coolant temp and much more
The color matches our dash perfectly as you can see from the pic. Easy to install. Just plug it into the OBDII port.
Here are more details.
http://www.scangauge.com/features/
If I can get 10 people we can have them for $149.99 each plus shipping. No tax.
The sample rate is slow, but for a dash type gauge mount its fine. I use it as a guage and not a datalogger. If you want a datalogger you should get Autoengenuity or similar.
The ideal setup is an OBD2 data "driver" that outputs to composite video - you can then attach to you cars aux video input. Simple but no one has done it yet.
