E63 Stuttering Under Partial Throttle
The first sign is when merging onto the freeway and just giving it moderate throttle, say about 25-35% the car stutters, not super noticeable but very subtle, like rolling over several very small bumps in succession, and not changing gears as I can see the gear stays the same.
The second sign which is more apparent and noticeable is cruising on the freeway around 70-75 mph (in 7th gear) giving it moderate throttle (say to pass someone) 25-35%, the stuttering will start subtle but then get worse and worse to where your just starting to headbob in your seat just a bit and I 'think' i can hear the exhaust note cutting in and out too. Car also stays in 7th gear at this point. I tried changing from C to S mode, no difference. Also bumped it down to 6th gear and same result. Under WOT the problem does not seem to show up, either that or i'm too busy admiring the exhaust notes
No CEL either. I did have the intake manifold gasket changed a few weeks back at the dealer however from a CEL. On a C230 board guys were saying all differnt things like fuel filer to O2 sensor so i'm wondering if anyone here has this same issue?
15 minutes after leaving the dealership, engine starts misfiring under the same engine/throttle/tranny conditions. Although the misfiring is more subtle than when I left it at the dealership, it's still annoying as s**t. Especially when you're trying to leisurely accelerate while getting the "bobblehead" effect.
This is the second time this has happened with the previous time the condition were more pronounced and would happen through the entire RPM range and the misfiring more "violent", jerking the car back and forth when starting.
Other than changing the intake gasket, any other suggestions from our fellow MBWorlders? Is the intake gasket covered by a TSB?
I also found a thread from a previous post in 2008 which found that the root cause for the misfiring and CEL was the intake gasket.
BTW, what brand/model ODB reader do you use?
Thanks!!
Thanks!!
http://www.amazon.com/OBD-AutoScanne.../dp/B000K8S6CG
BUT also my engine isn't idling rough, it sticks on 600 with no hunting, but my car is idling rough. I'm thinking mounts. Those misfires sound bad though, hope they clear that up for you guys..!!!
Also, the misfire does not happen at higher RPM (i.e. 3500 or above), only at below and in all gears, though more pronounced in 4-5-6-7 at low RPM's.
I can tell you it's annoying as s**t when you're trying to conserve some gas and you're trying to accelerate slowly in the higher gears only to be met with misfire....which forces you to step down a couple of gears and kill a couple more trees and $$$.
Anyone have info on the TSB # for the intake gasket leak?
Thanks in advance
