wheel BT.
Old Jan 19, 2010 | 12:13 PM
Taso's Avatar
04 e55
wheel BT.
Just want to make sure... Do the cl/sl 65 amg wheels fit the e55? I know I have seen pics of them before are they direct bolt on? Thanks in advance.
Old Jan 19, 2010 | 01:22 PM
dkallencat1's Avatar
I have the wheels on my car, perfect fit.
Old Jan 19, 2010 | 01:24 PM
Taso's Avatar
04 e55
nice! even with the stock bolts? what tire sizes are you running? can you postup some pics please thanks !!!!
Old Jan 19, 2010 | 05:55 PM
Lopes80's Avatar
E55 AMG
I have them on mine also. The correct off set for the W211 is 30/31, I think SL65/CL65 are different but should still fit ok.
Nice wheels, I chose PS2 for rubber and I coud not be happier.
Paul
Old Jan 19, 2010 | 07:55 PM
efivefiveamg's Avatar
2004 E55
I'm running the CLS wheels and they fit nice and snug. I believe SL offset is just a tad less aggressive than CLS, if not the same. I do, however, believe the CL offset is much different than either (much less aggressive, similar to the S offset, IIRC). So I'd check this out to be sure.
In the end, many members here will tell you...you can't go wrong with CLS or SL wheels on the w211 E55.
...oh...and I had to change the bolts b/c of the more aggressive CLS offset
Old Jan 19, 2010 | 09:41 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
CLS offset is the way to go 28 in front and 25 in the rear.
I have 18" CLS55 wheels on my car. I did not have to change the bolts.
Old Jan 20, 2010 | 02:40 PM
Taso's Avatar
04 e55
these wheels are offset front 25
rear is 31. Are the cl/sl 65 wheels the same et? i think these are off of a sl65. The front seems to be agressive. those with these wheels what are your offsets? what tire sizes are you running?
Old Jan 20, 2010 | 02:48 PM
I have the sl65 wheels 30/31 et. fit fine looks good. I don't no about the cls wheel.
Old Jan 20, 2010 | 02:53 PM
Taso's Avatar
04 e55
Im not talking about cls. These sl65 wheels have a 25 offset in the front. Are you sure yours is a 30? the rears are 19x9.5 et31 fronts are 19x8.5 et25. I just dont want to rub what are your tire sizes?
Old Jan 20, 2010 | 03:04 PM
I have the sl 65 amg wheels front offset is 30et rear 31et I've never seen a offset of 25 et front I don't no how that would fit or look.
Old Jan 20, 2010 | 03:05 PM
Taso's Avatar
04 e55
i know im confused.
https://mbworld.org/forums/wheels-ti...ml#post3902450
Old Jan 21, 2010 | 02:55 PM
Lopes80's Avatar
E55 AMG
Havea look at this link, maybe it will help.
http://www.alloywheelsdirect.net/mer..._2pc_wheel_289
