where to get led license plate lights?
2007 E63
I just bought from them.
It was around $35 including tax and shipping.
http://www.pyspeed.com/product-p/dash-8022.htm
2004 E55, 1997 E320 "Sold"
I bought mine as well as all my other lights in the past from ijdmtoy.com! I highly recommend them for anything involving led lights for cars. The exact item I bought from them is exceptionally bright and was $65, but it seems pyspeed.com has the same item for $35 so that is an absolute steal!
'13 GT-R AMS Alpha 9+, CLA45, E55
http://www.sylvania.com/ConsumerProd...RG-Results.htm
That will tell you all the bulb part numbers in the car.
Hope that helps in your search.
This is the exact bulb I purchased.
http://cgi.ebay.com/ebaymotors/USA-E...#ht_7980wt_864
Stock vs LED
![](http://img191.imageshack.us/img191/445/dsc01002g.jpg)
LED at night
![](http://img15.imageshack.us/img15/7730/dsc01004tp.jpg)
Sorry for the multiple post. Hope it helps.
Stock vs LED
LED at night
2005 Flint Grey E55
2007 E63
How was install? I got mine today and I just cannot find way to take out OEM housing.
Thanks in advance
Chang
I was told u take out the screws a little bit and pull it out by the screws. Also I was told you need to remove the rear trunk paneling to install them. Not really sure how to do it though or if this applies to your vehicle. I got some from psyspeed, but I haven't gotten around to having them installed.
haha. Let me save you all the hassle that I went through trying to figure this tricky but easy problem out. To install the led lights you obviously need to take the whole oem housing out, but not through the little hole from the outside. To take them out you must remove the trunk lid or the piece of the trunk that the license plate bolts into.
1. Remove trunk lid (There are two screws inside the trunk one on the very left and the very right). You only have to remove the trunk liner enough to get your hand inside the trunk to unplug the wiring going to the oem housing and to reconnect the wiring to the led housing at the end).
2. After removing those two bolts there is one more which is also inside the trunk and directly beneath the license plate and it also has a washer.
3. After removing these three bolts your trunk lid can now be popped off, but be careful because there are six snap connectors also holding the lid in and if you pull to hard they can break. (You still need to pull hard enough though to pull them out)
4. Now you have access to the oem housing and they should just pop out.
Stock vs LED
LED at night
Stock vs LED
LED at night
