This Throttle Body is kinda BIG :)
Old Jan 25, 2010 | 11:46 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
more soon.
Old Jan 25, 2010 | 12:16 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
105 is a good start.
Old Jan 25, 2010 | 01:18 PM
blackbenzz's Avatar
haters crazy
Its kinda hard to tell from that pic since there is nothing to reference it to. Looks like you got it ported out, nice
Old Jan 25, 2010 | 01:19 PM
prodigymb's Avatar
It'a 90MM
Old Jan 25, 2010 | 01:26 PM
blackbenzz's Avatar
haters crazy
Originally Posted by prodigymb
It'a 90MM
Kinda big? That's huge! You get it on your car and running?
Old Jan 25, 2010 | 01:27 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
That's what she said?
Old Jan 25, 2010 | 01:30 PM
BenzoBoi's Avatar
Super Moderator
W221
Must resist...
Look forward to seeyin how it all works out for you!
Old Jan 25, 2010 | 01:31 PM
prodigymb's Avatar
I have the following sitting at home...
-90mm tb
-90mm adapter plate to be welded to a modified inlet
-wiring harness that takes care of needed pin swapping
At this point this setup is not bolt-on and I will be cutting and welding to an OEM mercedes SC unit. We will either use an 80mm inlet or maybe even the spare stock one - since it has to be cut anyway.
Planning on doing it this Saturday.
Old Jan 25, 2010 | 02:25 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
Cool stuff! Maybe this can help take it to the next level like the 82mm did.
Old Jan 25, 2010 | 02:30 PM
ABALONE's Avatar
2001: Supercharged E55 AMG
Interesting! I'll be looking forward to see what the 90mm can to
I'm only on the jump from 74mm to 82mm
Old Jan 25, 2010 | 02:40 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
NICE!!!!! Looks like somebody is going all out
I think we may see another E55 in the 10s
Old Jan 25, 2010 | 02:59 PM
prodigymb's Avatar
That is the ultimate goal. I am looking to do either ...
A.
-90mm TB
-190mm pulley
-Water/Methanol (To compensate for the poor OEM intercooler)
B.
-90mm TB
-stay with my current Evosport 175mm pulley
-Nitrous Express 75 or 90 shot with progressive controller
Old Jan 25, 2010 | 03:01 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
-90mm tb
Going to need good headers and free flowing exhaust to maximize that intake flow.. Very pretty though! I am holding out for the 105mm!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 25, 2010 | 03:12 PM
prodigymb's Avatar
I have Evosport headers and dual 3" Seamless Motorsports exhaust with X-Pipe. No kittens in it either
I read that going too big can cause undesireable driveability issues, and weird throttle response. I am not saying that 105 is too big, I guess we'll find out. I can always upgrade
Old Jan 25, 2010 | 03:20 PM
MB_Forever's Avatar
A.
-90mm TB
-190mm pulley
B.
-90mm TB
I like option A.... but why not 180mm pulley? It's been proven by all the 55s that are currently in the 10s (without NOS) and you would not need the extra water/methanol route given you have the heat exchanger and rear reservoir mods. Many of the members who are currently running the 180mm and rear reservoir seem to have very reasonable IATs
Old Jan 25, 2010 | 03:44 PM
Sunir's Avatar
SL55 AMG
As with any mechanical systems there are always engineering tradeoffs. One has to wonder what is the largtest size TB and/or pulley compared to what is optimal for the rest of the system while minimizing tradeoffs and maximizing overall sytem (in case engine and driveline) performance...just a thought
Old Jan 25, 2010 | 03:55 PM
prodigymb's Avatar
My IATs are reasonable with my 175. I have cooling mods...
-Code 3 Heat exchanger
-CM30
-9 gallon rear mount ice box
190 hasn't really been done and documented. One of the reasons people stayed away from it is that with higher boost, the air just gets too hot and the intercooler is not efficient enough to cool it. I saw some IAT logs of water methanol on an E55 that have me convinced that 190+W/M will make a lot of power over my current setup. We are talking IATs of under 85 degrees.
180 just would not be a worthwhile step from my 175
Old Jan 25, 2010 | 04:09 PM
PLATINUM SPONSOR
2003 CL55
The 90mm may have some calibration issues too (code P505 and P106) .. Once the tuners start looking in this area, they will be able to calibrate our codes and idle.. Then we can get real big!
__________________
www.ultimatepd.com
Old Jan 25, 2010 | 04:13 PM
prodigymb's Avatar
Question is - when the extra size will stop yielding extra power. In theory the answer is: once you eliminate any vacuum prior to the throttle body in the air intake. Either way I hope that this will work out.
Old Jan 25, 2010 | 06:04 PM
MB_Forever's Avatar
Very interesting project.... good luck and keep us posted I can't wait to see the results
Old Jan 25, 2010 | 07:08 PM
Worth the wait's Avatar
2006 E55
Something tells me you will be getting a larger pulley soon......
GL with this project I am eager to see the results.
Old Jan 25, 2010 | 11:20 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
I have been very curious why not very many people have been removing the stock intercooler and putting large top mount ones similar to the slr? It seems that both flow and cooling capacity would be increased. I agree with the water/meth injection but at some level your pressure drop across the i/c core has got to be a lot.
Old Jan 25, 2010 | 11:50 PM
BenzoBoi's Avatar
Super Moderator
W221
Do you know how much they are charging for them?
Old Jan 26, 2010 | 12:59 AM
bassn_07's Avatar
2006 E55 AMG
Bingo! We tested this going from the 78 to 82mm and we only saw minimal gains. I can't quite remember the numbers but I want to say that the 78 was pulling 2 lbs and after the 82mm was installed it dropped .5.
Old Jan 26, 2010 | 01:15 AM
prodigymb's Avatar
Add more boost to that equation and things will change
I just found out we can't do it this Saturday, so its getting pushed back more. Kinda upset, but it gives me more time to decide on whether I want to do spray.
