Dealer says new SC pulley/bearing needed
Subscribe
Feb 26, 2010 | 07:06 AM
$500 is about right for this yes? I don't want to mod the car so guess I'm going this route.
Thanks!
Reply 0
Feb 26, 2010 | 10:38 AM
If you're talking about the S/C clutch assembly, DEALER COST in Canada is about $1000 plus install.
Reply 0
Feb 26, 2010 | 10:47 AM
500 is cheap if it is the s/c clutch assembly.
Reply 0
Feb 26, 2010 | 06:09 PM
no, just the pulley...where the belt rides on.....i'm new and not sure what a clutch pack is????
Reply 0
Feb 26, 2010 | 07:42 PM
Quote: no, just the pulley...where the belt rides on.....i'm new and not sure what a clutch pack is????
the s/c pulley and s/c clutch is built into one assembly, for what i know mb does not sell different parts of the assembly it is sold as one unit.
Reply 0
Feb 26, 2010 | 09:06 PM
Well, if they put a new one on, I would like the old on,,,, so PM please
Reply 0
For that amount, I would bet they are referring to the s/c idler pulley.
Reply 0
Feb 27, 2010 | 06:20 AM
Quote: Well, if they put a new one on, I would like the old on,,,, so PM please
I have the original SC clutch assembly from my SL55, but the bearing is toast and the clutch chirps. I think they are the same on all 55 kompressors. PM sent.
Reply 0
Explore
Feb 27, 2010 | 06:27 AM
Quote: For that amount, I would bet they are referring to the s/c idler pulley.
+1
My recall is the SC clutch assembly was $1,200 installed at the dealer here in Indy. I bought the part online for about $800. The dealer will not sell just the bearing.
Reply 0
Feb 27, 2010 | 10:00 PM
Bingo - Idler pulley assembly is ~$500u.s. I fixed the bearing in mine for about ~$5. Check this thread.
https://mbworld.org/forums/w211-amg/...2-03-19-a.html
Reply 0
Feb 27, 2010 | 10:03 PM
And this one. You can send the check for the remaining $495 to mbworld.org...haha
https://mbworld.org/forums/w211-amg/...ng-repair.html
Reply 0
Feb 27, 2010 | 10:07 PM
dont you folks have warranty on your cars. Mercedes changes my stuff out for free. no charge to me. One day with a pos ford rental they provided but beats walking.
Reply 0
Mar 11, 2014 | 02:19 PM
I have one 2002 c32 amg w 50k , and my supercharger having this noise like in this video from YouTube , 3 mechanics 3 different opinions first to replace the all spcgr and pulleys for 4500$ second to change the inside BS part for 1300$ minimum and a third just waiting ,what did you think I can do ? car in excellent condition except this issue , no personal experience with garage and hand work at cars , thanks
Reply 0
Mar 11, 2014 | 02:34 PM
Quote: I have one 2002 c32 amg w 50k , and my supercharger having this noise like in this video from YouTube , 3 mechanics 3 different opinions first to replace the all spcgr and pulleys for 4500$ second to change the inside BS part for 1300$ minimum and a third just waiting ,what did you think I can do ? car in excellent condition except this issue , no personal experience with garage and hand work at cars , thanks
http://youtu.be/5CL4aqgGlRs
I'm sure you will get tons of good advice from the guys on this board, but I will throw out a few thoughts.
First, if the C32 SC is like the 55ks, the SC is not engaged at idle so the noise in the video is not telling us much about the SC itself. Second, I just lost another clutch pack bearing and I can tell you it does make a chatter sort of like in the vid, but I don't think it was that loud. A telltale sign of a bad clutch pack bearing is blown out bearing race seal and usually a few of the little ***** are missing. Here is a pic. The seal or cover on your bearing looks fine.
I suggest you sit tight and wait for some good info from the guys on the boards. It will sure suck for you to replace the SC if it is not necessary. By the way, what are you calling the "BS" part?
Reply 0
Mar 11, 2014 | 03:30 PM
sounds like your s/c pulley bearing.... take the belt off and spin all the pulleys by hand, one by one to find out which one is making the noise... if its the idler or tensioner pullies then its just easy bolt on replacement for under $100 used.... if its the main s/c pulley then you can replace the bearing and its a $80 diy job... i did mine a while ago and worked like a charm
you can also take the s/c pulley off the car and spin it in your hand as well to further verify that it is in fact the s/c bearing once you isolate that the noise is coming from that area and not the other pulleys
https://mbworld.org/forums/w211-amg/...g-install.html
Reply 0
Mar 13, 2014 | 01:26 AM
thanks guys I really appreciate it , I will check the pulleys and bearings first before I do anything is not about the money but to treat the amg the best I can
Reply 0
Subscribe
Currently Active Users (1)
