anyone running a 285/30 in the rear???
Old 03-07-2010, 02:28 PM
sy1616's Avatar
2005 E55
anyone running a 285/30 in the rear??? on stock rims
...just a thought!
Old 03-07-2010, 03:09 PM
marc777's Avatar
2012 CLS
No.
285 25 20's being fitted tomorows
Old 03-07-2010, 03:17 PM
930chas's Avatar
cornfed gtr and m3
I am running 285/30-19s in the rear, and could definitely go bigger. If you are talking about stock rims, I don't have any first hand experience, so can't tell you for sure.
Old 03-07-2010, 04:44 PM
dr_brains510's Avatar
E55
How certain are you that you could go bigger? The reason I ask is because I was thinking of doing 295/30/19 with 19x10 in rear. You think there will be any rubbing issues?
Old 03-07-2010, 05:23 PM
Super Moderator
BenzoBoi's Avatar
W221
How bout a 295/25/20?
I did run a 285/30/19 on my old HRE's and they were fine...
Old 03-07-2010, 06:27 PM
Thericker's Avatar
V12-Biturbo
I know its not an E55 but I'm running 295/30/19 Vred's w/ease as soon as they wear out I can easily fit 305/30/19 (Infact anbody wants to make an offer on the 295/30/19 Vreds? they're brand new, I want the 305's)
Old 03-07-2010, 06:34 PM
sy1616's Avatar
2005 E55
sorry, i meant on stock rims!!
Old 03-07-2010, 06:42 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
If you are talking 18" stockers then the diameter is too small. Do the math.
Old 03-07-2010, 06:58 PM
sy1616's Avatar
2005 E55
WHAT, diamter is too small you mean width? Care to help me with the "math"???
Old 03-07-2010, 07:36 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
There are numerous calculator links posted on here as well as google. Please search.
Old 03-07-2010, 07:57 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
I thought you were talking 19s or 20s. They will never fit on 18s, the would be hanging over the side dude! Like amdeutsch there is a few calculators around.
Old 03-07-2010, 08:15 PM
speedybenz's Avatar
AMG C43, 1999
If a 285mm tire will fit on a 19" or 20" rim then it would fit on a 18" rim. The rim would need to be at least 9.5" wide and preferably 10" to 10.5" wide.
I am looking to get a 18x10" rim for my C43/55 and then run a 285/30/18 tire.
Jeff
Old 03-07-2010, 08:59 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
I had 285/30 on my stock 18" cls wheels. They fit fine and makes the car look very aggressive from the rear
Old 03-07-2010, 09:00 PM
emoving's Avatar
Jeff
So does that logic mean it will fit on a 17 or 16 inch rim as well?
Old 03-07-2010, 09:02 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Jeff
Jeff - speedy. You jumped the gun. Its an E with stockers. They are 9" wide in the rear. Plus there is more to it than width. Reread post #8
Old 03-07-2010, 09:04 PM
emoving's Avatar
speedy
Old 03-07-2010, 09:09 PM
RenntechE55's Avatar
CLS55 AMG 030
They should fit but if its a stock rim why not 285/35/18?
Old 03-07-2010, 09:21 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
So fit for 285/35/18 for stock rims ? some say yes and some say no....
Old 03-07-2010, 11:43 PM
jangy's Avatar
2015 S212
why go 35 series? That would be much taller than the stock diameter.
Old 03-08-2010, 12:30 AM
CLS55 AMG 030
my car game with a 295/35/18 on OEM wheel and it fit fine and didn't rub but I wasn't lowered back then.
Old 03-08-2010, 12:40 AM
speedybenz's Avatar
AMG C43, 1999
Emoving,
It seems you never purchased any tires and wheels before.
So, yes a 285mm wide tire will fit on a 15" rim, a 12" rim or a 16"-17" rim as long as the rim width is correct for the width of the tire. The diameter of the rim has nothing to due with regard to fitting a 285mm wide tire. The only thing that matters is the rim width and if there is enough room under the fender to fit the tire and wheel combination.
Normally you are going to need a 9.5" to 11.0" wide rim to fit a 285mm wide tire correctly.
Do you understand now.
Jeff
Old 03-08-2010, 05:59 PM
alextaylor29's Avatar
2004 E55 AMG
I'm looking at tires now for my stock 18"s and am only considering +1 as that's the safe bet. So 265 to 275 and 245 to 255. Those will almost always fit and you'll get most of the benefit of the 285 with no worries.
My $.02.
Old 03-08-2010, 06:47 PM
sy1616's Avatar
2005 E55
ok, I am more confused now but settled on a 275/35/18 Michelin PS2.....happy is me!
Old 03-08-2010, 07:10 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
Here it goes some numbers:
Stock
265/35-18 = 642.7mm diameter
Plus 1
275/35-18 = 649.7mm diameter
Plus 2
285/35-18 = 656.7mm diameter
Thats a difference of 14mm, divide it 2, thats a 7mm higher tire. The rear of your car would be 7mm higher. Maybe it would rubb a little.
285/30 would be too short.
And if the wheel is at least 9" wide, it would be enough for the 285s. And it doesnt look bad either.
Old 03-08-2010, 09:17 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Emoving,
Jeff
Your right the width is what matters and were talking about on a stock rim which is only 9" wide.
Quick Reply: anyone running a 285/30 in the rear???
