MY ENGINE WENT KA BOOOOOOMMM !!!
. As for logging, MB straight sucks going through the OBD and the sample rates are very slow when compared to other cars
. I believe the best I've seen is 3 samples per second while logging 3 parameter, less than impressive. I basically log AFR's, Boost, Knock sensors 1 and 2, fuel pressure, EGT's, and TPS directly. Timing and IAT's are done through the OBD but that is in the process of being changed. Here's a sample of a 1/4 mile run.
The logging I did was pretty crappy. I can't really tell where I was WOT and the data collection rate was so slow I only got a few points on a 3rd gear pull. I will try to get some more runs in and log timing. At higher rpms the timing isn't very agressive at all like Tony said. My car hasn't blown up yet with EC tunes and it has been running pretty good at the track. I do change my oil/filter every 3k miles and check on things pretty often. I'm very paranoid when it comes to that stuff lol.
Also if my tune blows up cars, I would have hundreds of blown up engines out there.
In many years of collaboration with not only enthusiasts, but professionals, I’ve realized that there is a diametric opposite understanding of vehicles. Misinformation, bad advice, blatantly wrong advice, how ever you want to term it. What this leads to is a disproportionately large base of people who are completely ill-equipped to care for their vehicles.
So exactly how many tunes has Eurocharged done for 55 motors ? Is hundreds figurative ?
While your informative... the condescending tone takes away from your actual message, nice try though.
Lets do what has been said before remove timing and fuel and make much more power so you can pick up 7mph on the back half and run in the 9's
Normal for the bottom end to be that sludgy running synthetic? How many miles on that car? Not that it looks that bad, we've all seen much worse, but I'd figure it to be a bit cleaner.
Loco there are so many parameters to look at in your situation, when the last time you had your plugs changed? How many miles did you have on the oil during that time? What was each cylinders CR? I’m sorry if you did have all this work done on your car and your mechanic and tuner then did not provide this info to you before your car went under the knife. When I have cars in my shop these measures are done making sure things are solid before hand. You did mention you had all this work done by TTM and never had the car on the dyno how do you know the tune you had in the car wasn’t the cause of this issue and giving the car the power it should have had didn’t just make that issue worse? I happen to see the competitor’s tune and I showed you and the other guy the tune, there was absolutely no timing nor was fueling changes in that tune, only torque management and a few things in the background done. But since I was the last one to tune it I am being blamed for it. I know you are doing your homework which I do appreciate very much but I don’t really think the true answer will come from it and if it does I can’t wait to see the results. Good luck with everything and I hope you find the answer you’re looking for.
except for that V12 twin turbo!!So now my car is a hooptie?
Seriously Tony i thought you and your company were going to show a little more class on this..
And yes me and Bruce data logged the car two weeks before your tune..right after the TB install.
Not going to start this back and forth BS
This thread is for anyone who may
be considering using your company for modification. It is not
my intention to have a debate here because the raw facts in
the matter are crystal clear. I will start where Tony left off. In
regard to any surgery the patient is almost always given a list
of pre-surgical preparation. I say almost always because this
patient was not given any instruction, or warning as to what
may, or may not be it's outcome other than positive. Next a
real surgeon would not proceed in the absence of this presurgical
data. As you have all read for yourselves directly
from the surgeons mouth that he did not have this data.
The next raw fact is that the car was performing flawlessly
prior to the surgery. It was my intent to squeeze a few extra
horse power, that's all nothing more nothing less. Well the
surgery turned out to be a failure, and I am blaming the
surgeon. I believe that the surgeon was more interested in
collecting his fee on the spot rather than taking the time to
do_the necessary pre-surgical research prior to surgery.
This reminds me of an old song titled" Take the Money and
Run" . You know it's not a big deal for this surgeon to just
give my claim to his insurance company and let them handle
it. Any reimbursement determined is not going to be coming
out of his pocket. It is his responsibility to act in this fashion if
he is in fact a reputable business business man, that is if he
has insurance to begin with and is not just a traveling gypsy.
Lets face it , there is not one human alive thats perfect, thats
why we have insurance companies. Personally I can only
hope that your company has a change of heart and begins to act like
a professional.
The logging I did was pretty crappy. I can't really tell where I was WOT and the data collection rate was so slow I only got a few points on a 3rd gear pull. I will try to get some more runs in and log timing. At higher rpms the timing isn't very agressive at all like Tony said. My car hasn't blown up yet with EC tunes and it has been running pretty good at the track. I do change my oil/filter every 3k miles and check on things pretty often. I'm very paranoid when it comes to that stuff lol.After looking at your logs your timing seems only slightly higher than what I'm seeing but I'm running 91 compared to your 93. I also don't have any logs in 3rd gear below 4k and that's were you're seen the higher numbers. I'm sure Tony could better explain what his timing tables mean when compared to your logs.
Yes sir that is normal!! when there is a hole in the block that is... I mean you guys keep asking the miles on the car, so that means all of you out there with 30-40 thousand miles will blow up by the time you reach 60-70k ???
Car had almost 70k
i mean that depends, i think a car is a car, it has mechanical parts as long as you keep is running and maintain it you should be fine, part will go out it is a machine but ive seen cars with 300k miles still running strong
I know this is weird !!! how about adding some "hooptie" sound to it!!
http://www.youtube.com/user/eliseome.../0/yABk4cRtaFc
However, there has got to be a way to find out what happened and the cause. We have pictures of the engine. And, there is the ECU or black box? Maybe the last few minutes of the engine before, during and right after it blew up are recorded on the ECU? If so, then maybe there is a way to see the parameters of the car, the sensors and etc. Take that info and the pics of the car and maybe the cause can be determined? Is that possible?
I can post up the dyno if people want to see it.maybe his car was lean maybe his car was tuned right,but if I didnt put my car on the dyno,I would of 100% melted my engine if I drove it the way you guys had it with your base tune.
14.08 409ftlb
14.03 437ftlb
13.99 472ftlb
13.79 533ftlb
ect.the dyno guy was afraid to do another pull on my car and said i will blow the thing up with that a/f
. Wayne even posted up in that thread and told his side but now you say "you haven't really told the whole story on your part". Please feel free to elaborate and tell me what I haven't openly posted. I have no intention of getting into a debate over this because I already posted my opinions on this matter. Like I always said, you guys gave me great customer service but I wasn't personally satisfied with your tune, that's all. I'm just sharing my own personal experience from LET.
I just reread you post and yes I did want Wayne to personally tune my car do the success stories I heard but in the end both you and Jerry tuned my car...right? Over compensated??? Do you think it's a possibility that you over compensated once again with Loco's tune? I understand mistakes happens and if it did owning up and taking responsibility would be a great step in the right direction.
Well again as I tell all my customers I will be starting out with a base tune which is on everyone elses car with those specific mods and really go from there, If I was radical on his tune I would admit that and I would have done so before this even got to this point but I know thats not the case. Oh and again your wrong Jerry only made sure the fuel was good on your car nothing else, and your right no need to debate I am just stating facts.
There are always risks in modding, especially when modifying high performance AMG's. It sucks, but good luck to all parties involved.
Serious question: with modern full-synthetic oils and iridium plugs, what is the recommended change interval on a modded engine? Your post seems to suggest that 8k oil changes and 25k plug changes is negligent... I wouldn't have thought that prior to reading your post. So, what're acceptable intervals? TIA.
he a freaking great guy! helped me from the start! before i had my 55 when i was still with the bimmer crowd, great guy!
