FANATICS, please help!!
Old May 21, 2010 | 01:59 AM
TheVazha's Avatar
W213 E63
I've had my 05 E55 for about 6 months. I have Eisenmann/ResDelete/Tune/ and my car is fast. However, I really have no clue on how to launch it. People talk about taking down very fast and expensive cars but I'm scared to race these things for the fear of failure. My problem is that whenever I wanna go fast the tires spin and then the computer comes on to rob me of my power. The engine revs hard but I can feel the computer steping in to take power.
Sometimes, by accident, on WOT, the car just pulls and pulls like a filthy pig. It feels like you're in a hot rod.
So, I need to know how to get that launch all the time. If you know how to launch this car, PLEASE help out and post. I'm sure there's got to be more then one of us on this forum who will read it. Tell what you know about launching this car, in detail, paint a picture.
I thank you for the advice.
Old May 21, 2010 | 02:32 AM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
https://mbworld.org/forums/w211-amg/...nique-e55.html
https://mbworld.org/forums/w211-amg/...acing-how.html
Old May 21, 2010 | 04:56 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Good performance tires are a must.
Old May 21, 2010 | 06:48 AM
ryan b's Avatar
'05 E55 AMG
You might want to invest in some drag radials. They're unbeatable for off the line performance. You can usually hammer it off the line without problems unlike a lot of street tires that will go up in smoke. Just make sure to heat em up first
Old May 21, 2010 | 08:35 AM
cal1's Avatar
SL55, ML500 & Acura TL
Definitely an ultra high performance summer tire or drag radials. I have been running Toyo T1Rs for the last two summer seasons and find they stick nicely both dry and very good wet traction so long as it isn’t too cool. I notice a big drop off in traction when the outside temps drop below 60 degrees. When it is 80 and wet like after a summer storm, the tires stick amazingly well for wet traction.
Keep in mind, you will still have to get good at throttle management because mashing it on these beasts break most any tire loose. I like to run without traction control because it forces me to get good at throttle control under different circumstances.
The big trade off on these tires is tire wear. I just make it through a summer season with a set of T1Rs. Maybe it is because I enjoy leaving a little rubber now and then. One last point. IMHO drag radials give you more straight line grip, but you give up a bit of cornering traction in the process.
Old May 21, 2010 | 08:48 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
never fully step fully on the accelerator. powerbrake to 1100rpm then 1/2 down on the pedal then fully on the pedal.... it takes some time alot of practice!!!
Old May 21, 2010 | 09:37 AM
bjr7141's Avatar
03 E55 AMG - 01 996 TT
ive been beating the crap out of my car in prep for summer runs at the air strip
seems i can get a better launch with traction on
am i doing something wrong
with traction off ... im spinning all over the place haha, right through my first set of tires
Old May 21, 2010 | 12:28 PM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
+1 just ease into full throttle a bit. It takes some time but practicemakes perfect.
And as far as breaking something goes... It seems the harder I drive the car the more she likes it give her a little abuse, she might like to be wined and dinned but every girl has a naughty side. The 55k is no different
Old May 21, 2010 | 12:41 PM
TheVazha's Avatar
W213 E63
Thanks for the advice. Ya it seems like there is a sweet spot in between 1200rpm and 1600rpm (depending on how fast you get to that rpm) that if you squeeze at the right moment the car literally launches...
Old May 23, 2010 | 01:57 AM
gonzjed's Avatar
germans
Which drag radials are you running in the pic on your signature??
Old May 23, 2010 | 09:56 AM
cal1's Avatar
TheVazha, just curious, what tires are you currently running?
