My Dyno day results on Long tubes
After testing these long tubes, I feel they are worth 60-70 RWHP over a stock exhaust system. I already had picked up 15 rwhp on taking stock cats off and adding race cats/x pipe last fall.
Second thing that could effect my numbers, is that I running stock air boxes again and my last numbers were with CF 82mm airbox. Never knew what the box was worth but it is gone now..
Third, my last dynos were done in cold weather, low humitity and IAT on the pulls were 30 degress lower!
Picked up some nice torque , even though many wrongly belive that we loose TQ with long tubes..
Whats next?? Well injectors and more tunning! My CL also has some brutal TCU torque mgt that needs to be corrected before my track times can really drop..The E55`s do not have this but I have it bad. Thinking of using a TCU code from an E55 and load it in my tcu..
Thanks to Jerry Thornton for a great tune day and Kurt Decker for use of his dyno / nice shop.. We had 6 e55`s, one c63 and one M5..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
They are the Eurocharged LT`s but custom made with larger primaries and collector. I heard they are selling this larger size now..
www.ultimatepd.com
Sean , thanks man
Hadi Law car is real strong but he is the one to ask about his car..
Oh yeah, he also had the double bag ice mod.
www.ultimatepd.com
Problem with maxing out and swapping injectors is that your entire file will need to be re-mapped.
Thats the one mod that I dreaded the most because it took forever to get it dialed back in correctly.
Our mods are simulair but still different.. He has no cats, kleeman mid tubes and a CF airbox. He also dynoed his car different than me on the numbers you listed. I was there to tune and not got for the best number I could get. I stopped after I saw that I was not getting enough fuel to feed the power the headers wanted to add.. Others on the board are also running low on fuel in this HP range.. I just post the information I have based on average pulls. Doing battery re-sets on the dyno or lot of ice will easilly make a 15HP difference...If you want small primaries and mid tube headers, then by all means go out and get them! That is what forums are all about, sort through the stories and build your car!
What are your plans to fix the problem? Pat over at PTE suggested having the injectors clean, calibrated, and increase the the flow. This is by far the cheapest and IMO will resolve some of our issues. Just a thought and good luck!
Ok, back to your question.. Fuel is tricky and you have to figure out if it is pump, line size, line restriction area, dirty parts, injectors or all the above.. Going to change fuel filter and then check fuel PSI. Injectors do not cost that much , if you don`t buy the SLR. Off the shelf injectors are in the 300 range, unless I am missing something. I am also looking at the kenny bell boost a pump but would prefer to get buy with injectors.. 48lb injectors seem to be the range I am looking for, maybe even 45lb..
I was hoping someone would chime in , that has done all this on our car already???????
Right now, I could give back some HP and fix this frickin CL Torque managment; then still ET a lot quicker.. My TQ mgt, is limiting my car from anything over a 1.72 -1.74 sixty.. More power helps on rolls but not helping much at the track.. Even with TCU off, I can hardly spin the tires in the water box...lol
www.ultimatepd.com
