Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Mercedes-Benz C-Class AMG: How to Replace Crank Shaft Position Sensor
Step by step instructions for do-it-yourself repairs
Crank Shaft Position Sensor DIY with PICS
#127
06 Mercedes CLS 500
1. No, there was no check engine light when the car was last running, now since the car does not leave from key position 2 its impossible to tell which light is actually on since ALL are on!!
2.Yes, the car does crank but seems like the engine does not want to start.
3. Yes, the car is parked on an incline but I have filled it up with gas when AAA came and filled some up more with a buddy of mine... almost half a tank!!
#130
06 Mercedes CLS 500
#132
Location: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
How many miles on your car? If it's a decent amount, I'd honestly order a Crank Sensor and see if that clears it up. I say that because the CPS failure is heavily documented as an issue in these cars. Consider the fact that the sensor is cheap in comparison to fuel pumps/senders and diagnostic charges, and I'd be swapping this sensor for giggles. Takes almost no time with the right E8 socket and some 1/4" extensions. You're looking at under 50 bux to find out. Hell, I can't even get STAR/DAS hookd to my car for less than 105 here in town. If you've never replaced your CPS, to me, this is a no brainer. Just do it. It may just fix things, and it can't HURT in the long run.
http://www.ebay.com/itm/Crank-Shaft-Sensor-Mercedes-E-class-W211-E500-Top-/310841347766?pt=Motors_Car_Truck_Parts_Accessories&hash=item485f968eb6&vxp=mtr
Good luck!
Good luck!
#133
06 Mercedes CLS 500
Crank Shaft Sensor Mercedes E Class W211 E500 Top | eBay
Good luck!
Good luck!
#134
Well for the record you can scrap anything i said about that s/c water temp sensor sorting my cars cutting out problem.
cut out on the free way on the way home tonight............ so i guess its back to the drawing board for me.
will post up what ever i find and the fix for it..................
#135
06 Mercedes CLS 500
The CrankShaft Sensor did not work for you??
#136
Don't get me wrong...........it has helped me in the past,
but this time i fear the problem is far worse than a bad CPS, i agree with typhoon its an easy enough sensor to change and for the money you cant really argue?
I have recently been changing sensors and fuel pumps/sender etc...
and believe me the cost of the parts are frightening.:eek
change that CPS sensor first then check from there and keep your dollars for upgrades
#137
#145
06 Mercedes CLS 500
Alright guys, so I changed the cps and still nothing. once in a while it turns on for a second and turns off other times it tries but does not succeed. Any suggestions?
#148
06 E55 AMG, 13 C63 AMG
There I was, 100 miles from home and WHAM, the engine shuts off. Would not restart. I was able to pull the P-0335 code with my scan tool and found it was a problem with the crank angle sensor.
Did a search here and found this thread. Let it cool down for 30 minutes and fired right up and got my another 5 miles down the road and WHAM shuts off again.
This time I had it towed.
Got on the phone with MB of Annapolis MD and they had 17 of these sensors in stock and had one to me an hour later. 20 minutes I had the sensor swapped out and had a lot of fun on the test drive.
Everything I drive this car it puts a smile on my face!!
G
G
#149
03 W211 E55
Hi
I took my car for a 4 hour drive on the highway yesterday and it was the longest drive my car has been on. When I got to my destination and went to start the car after sitting turned off for about 30 minutes I had this issue again of the car ticking over but not wanting to start.
I had these exact issues nearly 12 months ago and I replaced the crank position sensor and everything cleared up perfectly. Could I be having the same issues again with the newer crank position sensor?
The car will start once I try about 3 to 4 times of turning the key.
Regards,
OZZYAMG
Regards,
OZZYAMG
#150
w211 E 320 base
Hey guys great DIY but I still can't seem to find the cps on my car I've been looking and looking the pics seem a bit different then my engine most of it looks the same but I don't see it so after a scratching and a half on my arm I'm thinking of going to my indie with the cps I bought and get him to put it in the pics aren't as clear as to where it is unless I'm blind lol so ill post a reply to if it fix the code p0335 crankshaft position a circuit
This pic is the clearest I have seen on location but its foe a cls 600 I think the guy said its in this thread Muk I think his name was
