Old 06-10-2015, 01:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Crank Shaft Position Sensor DIY with PICS
Rating: Thread Rating: 8 votes, 4.88 average.
Old 07-26-2014, 07:37 AM
  #151
Shemar01's Avatar
1997 E420
2003 S600, show picture of crankshaft position sensor. What's the best way to get it off?
Is there a video on the S600?
Old 09-06-2014, 07:14 PM
  #152
Bramage's Avatar
F-250
Bump: Doing mine again Glad I remembered this thread.
Originally Posted by Bramage
I just did mine last Friday.
Symptoms:
Hard start when hot (even if just hot sitting in sun) - Car would turn over for 5-6 seconds before firing
On some starts, Idle would be very low 400 - 500 RPM for a few seconds before coming up to normal.
Based on all the treads, I did the CPS- All problems resolved. I am glad I did not wait for it to die.
Old 09-12-2014, 09:32 AM
  #153
wes459's Avatar
2006 SL65 AMG, 2014 E350, 2012 ML350 Bluetec
Thank you Shardul for this thread!!! The car wouldn't start this morning, when it finally did I got the P0335 code.
Ordered through amazon this morning for $38...dealer wanted $154
Old 09-12-2014, 10:27 AM
  #154
Cashville's Avatar
2004 E55
Just did mine too! Great thread and bought from Amazon for cheap.
Old 10-19-2014, 06:21 AM
  #155
oldrevhead's Avatar
W210 1998 E240
CPS bolt
Hi Guys Mine was a pain to get out,using extensions and uni joints.So when i put it back in i just used a 6mm allen key head bolt,Plenty of room for tightening with the key.
Old 10-24-2014, 11:03 AM
  #156
03svtkiller's Avatar
2011 Cadillac CTS-V
So is this the correct part#0031532828 for this sensor
Old 10-24-2014, 11:19 AM
  #157
berti_00's Avatar
2016 Cls63s AMG
Crank Position Sensor Bosch Part#0261210170
Old 10-24-2014, 02:04 PM
  #158
2011 Cadillac CTS-V
Thank you.!
Old 11-07-2014, 04:41 PM
  #159
I Like Soup's Avatar
2003 E55 AMG
CPS dead, at least it is an easy fix!
Just wanted to thank shardul for this thread and the pictures. It really makes things so much easier!
Anyway, I jumped in my car to head home after a Dr.'s appt and my car just sat there trying to turn over but couldn't. It sounded like when your battery isn't strong enough to turn the enginer over. I stopped and opened the hood to look inside and make sure everything was tight (because this always works roadside!). Tried to restart it after about 10 minutes and it started on the second try. So I headed home and pulled the codes before I shut the engine off. Yep, the P0335 Crankshaft Positioning Error. I had happened to buy the CPS at the stealer last December and never got around to putting that and a couple of other goodies on my car. So I had the part in the garage. Swapped the CPS out, which took about 20 minutes and I was good to go. The location is a real pain in the *** and I can't imagine how hard it would be for someone that has big hands. I had 100,018 miles on the clock, so it would seem my CPS lasted longer than most. I'll most likely get a spare the next time I'm at the stealer.
I'd like to mention, I'm pretty down on Mercedes for "engineering excellence" and so many items that can simply leave you dead in the water for an error; namely the CPS, airmatic, brakes, and I'm sure there are others. Mercedes may be on the leading edge of introducing new capabilities to vehicles, but the flipside is they are terrible as far as when an issue happens and the reliability that doesn't come with it.
Old 11-21-2014, 08:43 AM
  #160
cij911's Avatar
one car at a time
What a PITA to get to....I found the sensor, but cannot get the connector off (ughhh)....Getting the bolt off won't be a piece of cake either....
Old 11-21-2014, 08:54 AM
  #161
Hulk's Avatar
A Merc
Pinch it top to bottom, 12 o clock
Took me an hour simply because the space is so small and gotta do most of it by feel
Old 11-21-2014, 01:58 PM
  #162
2000UZJ's Avatar
E55
What does this look to be? I changed both batteries, starter relay and inspected everything near the starter. It went away for 2 months and never gave me any issues. It's now back and does it constantly. To the point where I leave the car running and lock the doors with the mechanical key. It took me over an hour the over night of flicking the key back and forth. No pending CEL, no drivability issues once started.
Starter "bumps", then nothing, then starts like all is normal.
I have a new CPS ready to go in tonight. Just wanted to see if anybody has had this same issue. The malfunction is low washer fluid.
Old 11-21-2014, 03:06 PM
  #163
cij911's Avatar
one car at a time
Thanks...I tried and tried and almost gave up....then I used a very long skinny flat screwdriver to push down on the clip while pulling the connector at the same time and success ....
I did not have any trouble getting the bolt out and used a piece of black electrical tape when installing the new CPS with the bolt (to keep the bolt from falling out)...
Put everything back together and car started just fine....
Thanks Shardul / Hulk / and others for the helpful thread!!
Old 11-22-2014, 07:09 AM
  #164
Hulk's Avatar
A Merc
Np bro, it seems everyone has their own little ways of doing this replacement lol bottom line it's done and don't have to think about it for a while lol
Old 12-31-2014, 12:28 AM
  #165
Joelima's Avatar
2003 cl55amg
Sr
I replaced a cps at fortmyers fl dealer for $730 after driving for 3 hours the engine failed to start, the next morning after cooling all night it wouldn't start, unplugged the wire from the cps and plugged it in again and then the engine started,went to autozone and purchase a new cps for $50
And replaced it my self, I noticed the as I removed the cps Installed by the dealer it was wet with oil residue , proceeded installation of the new cps, after driving for about 200 miles it's failed again, can anyone help me why is the cps failing
Thank you
Old 12-31-2014, 01:06 AM
  #166
berti_00's Avatar
2016 Cls63s AMG
Autozone cps's are junk
Old 12-31-2014, 09:20 AM
  #167
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Thank you
you need to see where the oil residue is coming from. try cleaning the CPS and installing it again
Old 01-30-2015, 06:21 PM
  #168
noodleman2u's Avatar
2004 E320 4MATIC
CPS connector issues
Had a CPS issue and swapped out the sensor; car ran fine. I noticed that if I touch the wiring harness the engine shuts off. Has anyone had connector/harness issues? Has anyone replaced the CPS wiring? If so, where did you purchase the connector? I appreciate any and all leads. . . . .
Old 04-08-2015, 10:22 PM
  #169
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Replaced mine today. My hands never want to go down there again. Way too many stiff wiring looms in the way. I also couldn't get the plug off the sensor, so I removed the sensor still attached, then unplugged.
Old 09-28-2015, 11:06 AM
  #170
Mackhack's Avatar
Just FYI: OEM Bosch at Amazon $31 not $85 from some cousins Same updated part number and without the A number in the housing for a fraction of the overinflated MB price.
Just wondering what would a dealership charge MSRP and what for labor? In the E320 it's a 10 minute job. Now on the AMG I have to find out the hard way how long it's gonna take since everything is way tighter in there.
Old 09-28-2015, 11:14 AM
  #171
E55Freak's Avatar
2005 E55 silver
same...took me 40 my first time..i could probably do it in 10 now...
Old 09-28-2015, 11:19 AM
  #172
Mackhack's Avatar
Did you remove the air filter box to have more space?
Old 09-28-2015, 11:33 AM
  #173
HeissRod's Avatar
I did
Old 09-28-2015, 11:40 AM
  #174
Mackhack's Avatar
Ok.
Old 09-28-2015, 10:38 PM
  #175
Jawzey's Avatar
CLS55 AMG
I did this job recently on my CLS55 and you will have a much easier time if these are removed before hand. You can do it quickly with a ratchet and a T25 socket.
You have already rated this thread Rating: Thread Rating: 8 votes, 4.88 average.
Quick Reply: Crank Shaft Position Sensor DIY with PICS
