Old 06-10-2015, 01:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Crank Shaft Position Sensor DIY with PICS
Rating: Thread Rating: 8 votes, 4.88 average.
Old 06-07-2013, 06:52 PM
  #101
scottmlew's Avatar
Looking! (previous: CLS55)
Hi guys, I wanted to thank everyone who contributed to this thread...I just replaced my sensor, and it went smoothly.
I bought a genuine Bosch replacement for less than $40 on eBay, and was outside working for less than an hour. Removing the airbox is key, imho. I used a 6" extension and a tiny ratchet and had no problems (I do have small hands though, and space is very tight).
Old 07-09-2013, 02:21 PM
  #102
easyaccess2me's Avatar
I drive 2002 s600 and a 97 s500 also have a 2000 jaguar xj8 vdp
What type of Benz is those instructions for, I have a 2002 s600 and my cps is going bad I bought a new one but can't seem to find where it goes can you guys help me please.
Old 07-09-2013, 05:24 PM
  #103
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
same general area. but more towards the center of the engine.
Old 07-10-2013, 09:59 AM
  #104
I just located my cps on the 2002 s600 , thanks for the assistance, my new problem is getting to it. I removed the air filter housing but there is virtually no room , is there away to remove it without having to remove the intake? I sure hope so because I hate to have to take it to the shop I was quoted 6 hrs of labor at 110 pr hr plus 150 for the part they want install customer parts that's like $810 plus tax
Old 07-10-2013, 10:13 AM
  #105
shardul's Avatar
i would start removing the intake to get to it
Old 07-10-2013, 03:35 PM
  #106
scowil's Avatar
e55
wow, I just had mine done today and it was $275 total out the door and the dealer.
Old 07-10-2013, 05:46 PM
  #107
shardul's Avatar
on a w211 it takes 10 mins to swap out.
Old 07-28-2013, 12:38 PM
  #108
kyuskaitis's Avatar
E55 AMG
Could you please tell me the exact position of the CPS? I have an E55 AMG 1999. Have part and tools in hand but can find it. I have gotten conflicting reports as to where it is. Some say access under frt bumper, others say between fire wall and engine it frt of drivers side???
It it easier to access from under car. Appreciate your help!!!
Old 07-30-2013, 09:38 PM
  #109
CerBErusM113's Avatar
2015 CLS63 S AMG
Its on the transmission bell housing, its right above the driver's side cat. Just did this on my c55 a few days ago, car runs great now:-)
Old 08-01-2013, 09:07 AM
  #110
meridien's Avatar
e55 amg 2003
Can someone send me video how to replace crank postion sensor on e55 amg 2003 tks
Old 10-17-2013, 10:12 PM
  #111
sl5dave's Avatar
96 SL 500 05 E 500
Great Help!! Needed to see the location. Also text helps.
Old 11-03-2013, 05:35 PM
  #112
sircl55amg's Avatar
2006 cls 55 amg
nice DIY...thank you !!!!
Old 12-25-2013, 03:23 PM
  #113
winefan94941's Avatar
05 W211 E55 Estate ( sold)
Just changed CPS in 211 E55 Wagon THANK YOU
45 Min and done..You guys are all the greatest!!
Merry Christmas!!!!!
Old 12-26-2013, 07:25 PM
  #114
rios's Avatar
E55 AMG
Just changed mine an hour ago. ALL the tips etc. you guys have here saved me a boatload of time. Took longer for the car to cool down than it took to change it. Few weeks ago car would not fire up IMMEDIATELY so I knew something was coming. Easy search here , you guys got all this **** on LOCK! Makes me happy saving dough and the zen of twisting a wrench getting things done for yourself is
priceless.
Old 12-26-2013, 08:59 PM
  #115
shardul's Avatar
Old 12-29-2013, 10:37 AM
  #116
jay_55's Avatar
E55 AMG
here is a new one to pick your brains with,
I have changed Lp5 (crank) sensor twice as well as a brand new fuel pump.
but when the car gets to 90 degrees (normal operating temp) it looses power cuts the fuel and sputters to a holt.
once the engine shuts down it wont start up again until it cools down .
I'm thinking of four possible options:
1. Coil packs acting up
2. Wrong fuel pump (overheating under fast driving)
3. Engine sensor that needs replacing (but which one?)
4. Throttle body acting up
I have been battling with this for a while and its getting frustrating as well as dangerous, as it happens anywhere (i.e freeway, residential roads, intersections etc.) and as well all know once the engine shuts off so does the steering & brakes.
if anyone has some knowledge or has dealt with a similar problem please can you chime in thanks.
Old 12-29-2013, 01:51 PM
  #117
rios's Avatar
E55 AMG
My two cents, if there is any question in your mind as to it being the wrong fuel pump you should address that imediatly. Custom tune, fuel might be something to take a look too if possible. I had a car that had the timing advanced and when I put in an inferior or low octane fuel the car would act the way you describe. It was a Mustang. So like I sad my two cents.
Old 12-29-2013, 03:01 PM
  #118
jay_55's Avatar
E55 AMG
Hey Rios,
the part numbers on the fuel pumps were identical as well as the pump fitment and plugs were all exactly the same.
as for the the fuel the car only runs on pump gas 95 octane I'm taking it in tomorrow to a mechanic that only deals with A.M.G's and apparently has an up to date star system, so I'm hoping he will be able to tell me whats happening.
I will post up what the problem is and how to fix it in case this ever happens to any other owners.
holding thumbs that its an easy fix, but i somehow get the feeling that its not gonna be.
Old 01-03-2014, 08:40 AM
  #119
jay_55's Avatar
E55 AMG
okay so picking up my vehicle this afternoon from the mechanic.
he has informed me that the fuel pump relay as well as the fuse need to be changed once a new fuel pump is installed.
so both have been changed and is apparently working well and pulling like a freight train.
I will test the vehicle once I have collected it and will revert back to you all.
have a wicked weekend guys!!
Old 01-09-2014, 09:06 AM
  #120
jay_55's Avatar
E55 AMG
Okay so received the vehicle back from the mechanic and I still had the same issue with the vehicle dying once it had reached operating temperature.
the mechanic plugged the vehicle back into the star diagnostic system and found that the water temperature switch for the s/c was giving a reading of -257 degrees Celsius.
which means the s/c has its own water temperature sensor.
now I didn't take the sensor our or replace it myself so I'm not sure what tools to use to remove it but I did take some pictures of the offending sensor as well as the location of where it sits.
so if any other members ever get a similar issue they know where to start looking and not do costly replacements like I did.
Attached Thumbnails Crank Shaft Position Sensor DIY with PICS-dsc06269.jpg   Crank Shaft Position Sensor DIY with PICS-dsc06268.jpg   Crank Shaft Position Sensor DIY with PICS-dsc06267.jpg   Crank Shaft Position Sensor DIY with PICS-dsc06270.jpg   Crank Shaft Position Sensor DIY with PICS-dsc06271.jpg
Old 01-14-2014, 02:21 PM
  #121
MUK
MUK's Avatar
06 Mercedes CLS 500
Unhappy
Hi Fellas,
Few days ago my car stoped in the middle of the highway with no warnings. I tried to restart the car but it would not turn on. During that time I had 23 miles remaining for the gas to end. I later noticed a warning of "Low Battery" so I took my battery to Auto Zone to get it recharged and tried to turn the car on and still no nothing. Could this be the CPS, Fuel Pump, or something else?? Please Help
Old 01-14-2014, 04:32 PM
  #122
shardul's Avatar
does the car start when it is cold?
Old 01-14-2014, 04:34 PM
  #123
typhoon43's Avatar
Location: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Just wanted to say I did my CPS this weekend, and this write-up helped a ton. Car is running so much better now.
Thanks!
Old 01-14-2014, 04:48 PM
  #124
MUK
MUK's Avatar
06 Mercedes CLS 500
No, it refuses to start at all. Does not matter hot or cold.
Old 01-14-2014, 05:16 PM
  #125
typhoon43's Avatar
1. Do you have an actual Check Engine Light on?
2. Does the car crank at a decent pace but just not "kick over"?
3. Are you parked on an incline by any chance? *
*only asking that because you say you're extremely low on gas.
You have already rated this thread Rating: Thread Rating: 8 votes, 4.88 average.
Quick Reply: Crank Shaft Position Sensor DIY with PICS
