Wheel spacer and lug bolt special
Old Aug 23, 2010 | 06:17 PM
Staff@RPM's Avatar
Former Vendor of MBWorld
Hub Centric Mercedes wheel spacers
5 on 112 Mercedes Benz 66.56mm Center Bore
Available in-
13mm thickness -$28.00 each
17mm thickness- $30.00 each
20mm thickness- $32.00 each
Conical seat lug nuts available in different lengths for-
-$3.00 each
This pricing is incredible, compare to everyone else and you will find no comparison from the competition.
Old Aug 24, 2010 | 09:03 AM
threeMBs's Avatar
Only MBs - the best or nothing
Available in-
-$3.00 each
Who manufactures these spacers? Not H&R nor Eibach, I assume, correct?
Old Aug 24, 2010 | 09:26 AM
Staff@RPM's Avatar
No, we decided that we should make some because there is not much in the way of engineering involved in these plus we have a very low cost source for aluminum through another business that we have. With our ability to get aluminum at such a low price and access to all the proper machines this is a product that we are able to bring to the market at a very low price.
H&R and Eibach just don't have the same buying power when it comes to aluminum and they cannot possibly get it at the same pricing as we do. We also have some idle 2 axis machines so it made sense to get them online and start using them.
Now you can take advantage of that and you have a source for very low cost wheel spacers. If you need any just let us know.
Old Aug 24, 2010 | 09:57 AM
blackbenzz's Avatar
haters crazy
Do they have lips on them so you can sit the wheel on it while you put the bolts in?
Old Aug 24, 2010 | 10:14 AM
Staff@RPM's Avatar
It's Hub Centric, exactly like the factory hub. I imagine you are talking about a raised edge around the inner hole that will fit in the center of the wheel? If you are the answer is yes, that is the Hub Centric part of it.
You are right though that a lot of spacers do not come with that and that can only lead to problems. By having that on the hub you are guaranteeing that the hub is centered on the wheel, without that the wheel has the chance of wobbling really badly if it is not centered correctly. A lot of people rely on lugs alone to center the wheel but that is no good.
Old Aug 24, 2010 | 08:22 PM
Silverr1's Avatar
04' E55K
What are the benefits of wheel spacers? Go? Show?
Old Aug 24, 2010 | 08:50 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Will you be offering smaller sizes? What would be great is anything under 10mm with the lip. The H&R spacers under 10mm don't come with the lip.
Old Aug 24, 2010 | 09:53 PM
Worth the wait's Avatar
2006 E55
Do you guys have these made already or is it a "pay now, ship once we actually make them" kind of thing?
Also +1 on a smaller size
Old Aug 25, 2010 | 09:19 AM
NitrogenBalance's Avatar
none
My buddy got a set from ebay and they didn't have the lips, basically a big washer with 5 holes in that case and good luck lining up 50lbs of wheel/tire without it...
Echo the statement on sizes? I need a set of 5mm spacers, +/- 1mm. Is that possible?
Old Aug 25, 2010 | 09:32 AM
Staff@RPM's Avatar
No, we do not do any of that using your money as a loan to our business stuff. We feel that if we need to borrow your money to expend our business then maybe we are not ready to expand our business. All of these parts are already made and I would say that we ship most of the parts that we advertise on the forums within 24 hours. There are some cases where that does not happen but most of the time that is the case.
As for the smaller size, which size would you guys be interested in?
Old Aug 25, 2010 | 09:44 AM
97W202's Avatar
2006 C230 6speed/14 C63
I like your bussiness approach and now u have my bussiness... well when my wheels get here ... personally I think Id be interested in 3mm spacers... I think you would double your sales if you offered 3,5, and 10mm
Old Aug 25, 2010 | 10:05 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
+1 on those sizes. Maybe even 8mm also. You start pushing out smaller sizes and you will definitely have my business. I wouldn't hesitate to recommend you. The best part is you guys are on the east coast. You will get tons of business cuz of that alone. No more waiting for guys in Cali...
Old Aug 25, 2010 | 12:31 PM
Staff@RPM's Avatar
I brought up doing smaller spacers and was told that it isnt a problem. They are going to see if they can source aluminum from, another job that get's left over and would be ideal to use to make these sizes. That is how we are making the other ones so cheaply, because we have aluminum that is almost cut to those thickness's to begin with so it takes very little work on the machine and there is virtually no waste. The first thing to determine the cost of the spacers is the initial piece of aluminum that is being used, after that it depends on the amount of machining and finishing that goes into producing each piece.
I will have answers for you in two weeks. I am sure that I will be able to accommodate you.
Old Aug 25, 2010 | 12:43 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Old Aug 25, 2010 | 12:56 PM
97W202's Avatar
Originally Posted by dynomite05
+1
Old Aug 25, 2010 | 04:46 PM
2006 E55
Thanks for the clarification. Pm sent.
Good luck with the sales.
Old Aug 25, 2010 | 05:28 PM
bmontalban's Avatar
2007 E63
do you also offer cone seat lugs?
Old Aug 25, 2010 | 05:29 PM
Staff@RPM's Avatar
Yes, we have both cone style and ball style in stock lengths and longer lengths.
Old Aug 25, 2010 | 05:35 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Awesome! One Stop Shop
Old Aug 25, 2010 | 05:39 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
do make 25 or 30mm spacers as well?
Old Aug 25, 2010 | 10:51 PM
E55amg/FD3S's Avatar
03 e55
7 or 8mm with a lip please. Ready to buy.
Old Aug 25, 2010 | 10:55 PM
Bramage's Avatar
F-250
I need some lugs for my drag set up.. I need to measure.. brb
Old Aug 28, 2010 | 01:30 PM
Staff@RPM's Avatar
Let me know what size you need and I will do what I can to accommodate you.
Old Aug 29, 2010 | 10:03 AM
Bramage's Avatar
F-250
I am running a 15MM H&R spacer on RIAL wheels. The stock lug is flush with the wheels/Spacer combo. So I am kinda guessing..
The stock Lug is about 1 1/8 inch (28.6MM)
28.6mm + 13mm
So with this bang up math equation, I think I need about: 41.5mm ?
Does this sound right. That would give me 13mm into the hub
What do you think?
Old Aug 30, 2010 | 09:13 AM
Staff@RPM's Avatar
I would suggest a 1.55" thread length for the 13mm set up, this will safely hold your wheel in place.
