Do I need a camber kit after lowering via MB Star SDS?
Old Aug 24, 2010 | 04:34 AM
dpavid's Avatar
2005 AMG E55
I had 20" Euro RS63 wheels for about 2 years. They got badly dented and unrepairable from pot holes. I'm getting Mandrus Velo wheels on 19x8.5 ET30 up front & 19x9.5 ET35 in rear. Is this setup the right size for staggered 19" wheels for an E55?
Also, I plan to lower via Star. Will I need a camber kit for optimal alignment? Thanks in advance for any advice.
Old Aug 24, 2010 | 07:48 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
I almost bought those wheels a while back before I decided to get forgestars. Post some pictures once they are installed I am dying to see what they look like on an e55. BTW, I know nothing about offsets or I would help you out.
Old Aug 24, 2010 | 11:36 AM
jangy's Avatar
2015 S212
Yes you will, depending on how tall your tires are and how low you drop it.
Old Aug 24, 2010 | 03:59 PM
dpavid's Avatar
2005 AMG E55
thank you jangy! I assume everyone is using the kmac kits. Is there another bring i should consider?
Old Aug 24, 2010 | 04:02 PM
Bramage's Avatar
F-250
Yes
Old Aug 24, 2010 | 04:32 PM
jangy's Avatar
2015 S212
I used the MB Art arms on mine and I think EVOsport also has something out. I hate the Kmac knuckles.
Old Aug 26, 2010 | 11:37 AM
brad @ evosport's Avatar
PREMIER SPONSOR
None fast enough!
(click on image to go to the page on our website)
We have had great success with these, please let us know if you need to order a set!
thanks
brad
Old Aug 26, 2010 | 05:19 PM
dsc's Avatar
dsc
2004 E55
thanks
brad
Do these adjust Camber as well. I'm looking camber adjustment like dpavid.
Old Aug 26, 2010 | 11:01 PM
jangy's Avatar
2015 S212
Dan you will have to check with Brad but I think what you see pictured is the toe link. Yes, they do make camber arms and have a sticky with pics. I have heard no member feedback at all so dunno about that part but would be very curious since EVO understands track needs.
Old Aug 28, 2010 | 08:11 PM
SurgeSi's Avatar
2005 E
im also interested in a camber kit.
but i have a E320
same kits will work?
which would you guys recommend?
Old Aug 29, 2010 | 02:03 AM
AMGPilot's Avatar
2004 E55
No you do not need a camber kit. You WILL need to have the toe redone on the real wheels since the car will toe in when you lower it
Old Aug 29, 2010 | 02:04 AM
jangy's Avatar
2015 S212
but i have a E320
Same will work accross all suspension types. MBArts seems to be the only name in the game for adjustable camber arms but I could have sworn there was more coming out left and right...
Old Aug 29, 2010 | 02:06 AM
jangy's Avatar
2015 S212
Does it? Do you know by how much? I wonder if it gets to 0 under load?
As AMGPilot posted, you can easily try checking / adjusting the toe in your lowered state, since the arms are adjustable already. Then get camber arms if that is still an issue
Old Aug 29, 2010 | 02:13 AM
AMGPilot's Avatar
2004 E55
Yes Jangy it does, anyone wanting to engineer a solution would already know by how much.
Camber and Toe curves are easy to measure, and some have....
Here's a hint, For lower control arm toe links, Rear steer will toe out in bump and toe in in rebound, Front steer is the opposite.
Old Aug 30, 2010 | 12:07 AM
jangy's Avatar
2015 S212
Why do you keep things so personal? I never claimed to involved in the design in any way. I was a guinea pig and gave feedback. MBArts does all of their own designs. Jay chats with me but I am not nearly that qualified.
No biggie dude, but you may wanna let it go. I didn't make MHP suck...
Old Aug 30, 2010 | 02:04 AM
AMGPilot's Avatar
2004 E55
Huh??? what are you insinuating?
Old Aug 30, 2010 | 04:39 AM
VCA_AMG's Avatar
2018 E63S Wagon
Doesn't read like he insinuated anything. He said straight up that MHP sucks.
Old Aug 30, 2010 | 10:50 AM
Vic55's Avatar
Administrator
Im interested for my W212 too! The car is dropped and the toe is set but it still pulls to the right and the camber is visually negative.
W212 and W211's are the same for this right?
Old Sep 4, 2010 | 11:41 AM
jangy's Avatar
2015 S212
Yes and no. Your pulling is from the front end. Take it in and it will get fixed. I had mine so neutral that it would follow a crack in the highway.
While you are there get the final print out as well just to see where your camber is.
Damn, I just remembered you swaped out front springs. They may not give you free alignment for that, but you got contacts and the cost is nil for you anyways.
Old Sep 4, 2010 | 05:12 PM
lowprofile's Avatar
E55
I just had two alignments done within a few months span. The second was performed because I replaced stock front suspension bolts the MB adjustable bolts, adding caster to the passenger side and I increased camber on both sides.
Anyway, the rear suspension did toe out with the car lowered. AMGPilot's statement is confirmed in regards to the rear suspension.
Being that I changed the bolts in the front end, which in turn changed the toe, I have no idea if the front would have done the opposite.
Old Sep 4, 2010 | 05:19 PM
lowprofile's Avatar
E55
Your car will pull to the side with less caster. Add caster to the passenger side, I just went through this on mine.
