Airbox possibilities
Old Sep 17, 2010 | 03:13 AM
alroumi's Avatar
G55, G500 & SLK55
Hello,
Basically I have a 2006 SLK55 AMG, I've recently got the Kleemann K2 kit which gets the e55 airbox, sparkplugs, ecu flash, Roots type Kompressor on 0.45 bar of boost equivalent to 6.5psi, additional radiator, y-pipe and clamps etc.
I had green filters on my oem airbox, should I re use them on the E55 airbox or the oem's ?
I was wondering if there is a larger airbox for the E55, since my car can use the E55 airbox now with the compressor.
Any thing with CF that can accommodate for more airflow.
Old Sep 17, 2010 | 03:35 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
very expensive renntech or a little less expensive vrp are the only slightly larger carbon airboxes available and both have been shown to give a mild hp increase. i'm not a fan of the green filters as they've had some failures and would go with k&n's.
Old Sep 17, 2010 | 01:18 PM
alroumi's Avatar
G55, G500 & SLK55
Thank you, where can I get the best CF engine cover and airbox regardless of power.
Old Sep 17, 2010 | 05:31 PM
cls55's Avatar
carbonio.
Old Sep 17, 2010 | 08:23 PM
320 dreamer's Avatar
2003 porsche 996 turbo
look at the needswings dual cai. it flows almost 200 cfm more than the 55 airbox. its teflon coated and you may be able to get in fornt of your rad. im not sure. rob would know
Old Sep 17, 2010 | 11:46 PM
Karlson's Avatar
06 E55
Carbonio want $450 USD for an engine cover, they don't have airbox on their web-site
Old Sep 18, 2010 | 12:26 AM
07g55's Avatar
G55 - R500
Was checking the needswings website but didn't see anything offhand for the dual CAI - would you happen to have more info on that?
TY
Old Sep 18, 2010 | 01:47 AM
alroumi's Avatar
G55, G500 & SLK55
Couldn't find what you suggested in Needswing, they only offer it for the SLK32.
Old Sep 18, 2010 | 06:40 PM
07g55's Avatar
G55 - R500
I had a Renntech CF airbox a couple of years ago but sold it immediately because I didn't think I would get any benefits ( aside from looks ) from it as it appeared to be pretty much the same thing as a stock airbox.
Getting a needswings setup would be very interesting - has anyone managed to get this installed for the 55k? I think the SLK32 can run with a 74mm TB - might be compatible.
I was looking too at the carbino website - anyone got some pics of that one for the 55k?
Old Sep 18, 2010 | 09:14 PM
the slk32 setup is what you want. ask rob about any mods needed to fit into the slk55.
theres a fellow that put a s/c sl55 engine in a chrysler crossfire and rob said he could make it fit. the n/a slks use the dual cai also. i would think the only issue would be is there enough room in front of the rad.
heres the flow # from rob
so to get the important numbers together...
stock srt6 intake = 446cfm
sl55 intake = 514cfm
sl55 with devil horns = 531cfm
single CAI with teflon = 602cfm
dual CAI with teflon and big filters = 748cfm
for comparison the srt-6 intake is the same as the slk32 intake. as you can see the dual cai that rob makes flows like a beast!!
Old Sep 18, 2010 | 11:54 PM
Ohbev's Avatar
E55 AMG Kompressor
I just wish the work shops would start making the intake tubes and the airboxs from fiber glass and not carbon and charge us half the price
Old Sep 19, 2010 | 12:36 AM
07g55's Avatar
G55 - R500
Sounds really promising - I'll give Rob a call Monday, hopefully we can work something out for my car. Price seems much more reasonable compared to some of the CF stuff! For me there will be no chance whatsoever to pass the rad, it will just have to sit in the engine bay, but I might be able to open up my hood for air inlets
Old Sep 19, 2010 | 08:41 AM
im not sure thats what you will want. the whole concept of robs dual cai is to bring in air from outside the hot engine bay. thats why the tubes run to the front of the rad. he teflon coats the inside of the tubes for a smoother cooler flow but taking the air from inside the bay may defeat the purpose.
rob is a stand up no bs fella. if it wont help he wont sell it. he built me the first c3 pulley saver kit and i have been a happy customer for a long time. theres a # of his products on my car. never an issue
