Use of "S" "C" and "M" on E63
Edit: Never mind the above, I was thinking about ride settings and not shift modes. I have switched shift modes on the fly but not often.
The 500s on the other hand, I think those drop at 69MPH (my brother's CLS500 does).
I get bored, leave me alone! lol
fwiw, the manual says:
"At a speed exceeding approximately 68 mph with normal level set or exceeding 75 mph with raised level set, the ride height is reduced automatically. With decreasing speed the ride height is again raised to the normal level. These height adjustments are so small that you may not notice any change."
So you're both right
p.s., there's no issues whatsoever with changing either the Airmatic or the tranny modes on the fly. Airmatic ADS (C, SI and SII) simply changes the air volume via the valve on the strut to stiffen or soften the ride. The level control (raising the vehicle) will automatically lower at high speeds or you do it yourself before you reach that speed (over 75 mph.) And I don't think anybody here drives around with the car raised all the time
The tranny doesn't care and the manual only says that you should put the car in park first. There's no warning not to do it on the fly. If it was bad they'd have a warning in bold type. They just don't want people doing it on the fly and forgetting they're in C, S, or M, etc.. Just a typical "safety" thing for brain-dead drivers.
