Supercharger Clutch...
Old Oct 11, 2010 | 01:39 PM
Purist's Avatar
2003 E55 AMG
Question Supercharger Clutch...
Guys:
I just got an estimate for a few things and, assuming all of these things are indeed required (I believe they are), I want to get a feel for pricing. Are these fair?
ACC Cabin Filter Set Activated Charcoal $118
Mann Oil filter kit $15
Air Filter (2) $65
Motul 8100 5w40 X-Clean (8) $80
Spark Plugs (16) $465
Antifreeze (2) $37
6.9 gal/min Water Pump upgrade $354
Supercharger Clutch $1,070
Clutch Coupling $934
Supercharger Belt $40
Shop Supplies $70
Service D (service items 4,9,10,14) $428
Replace Plugs $375
Coolant Flush $107
Replace Water Pump $214
Replace Supercharger Clutch, Coupling, Belt $535
HAZMAT $30
$3251 in parts and $1688 in labor total. Comments?
Thanks,
Matt
Old Oct 11, 2010 | 01:46 PM
lilg210's Avatar
Mercedes E55
I just bought 16 plugs from sparplugs.com for $220 shipped
Old Oct 11, 2010 | 01:48 PM
lilg210's Avatar
Mercedes E55
is the "Replace Plugs $375" the spark plugs??
Old Oct 11, 2010 | 02:02 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
from what i understand the whole s/c cluch assembly sells for 1000. dont know what the clutch coupling is or if it is even needed.
Since my car is modified I run a step colder NGK plugs and got them for 100 shipped.
you can get a meziere pump for less than 200 which is way better than any other pump
Old Oct 11, 2010 | 02:04 PM
Purist's Avatar
2003 E55 AMG
The total cost for the plugs would be $840...$465 for the plugs and $375 labor. They claim 4 hours of labor which I find hard to believe.
From what I've read it's pretty easy to replace the plugs and you can get them for $15 or so each...probably should remove this line item, although it does bring into question the other labor rates...
Old Oct 11, 2010 | 02:07 PM
Karlson's Avatar
06 E55
I don't get why is it so cheap for supercharger clutch replacement?
Coupling p/n 1130980040 and clutch p/n 1130900044 cost $2k
Old Oct 11, 2010 | 02:13 PM
Purist's Avatar
2003 E55 AMG
The parts are listed at the top of the list and labor is at the bottom. The parts for the clutch are $1,900 and the labor is $535 so about $2,400 total...
Old Oct 11, 2010 | 03:47 PM
lilg210's Avatar
Mercedes E55
How many miles do you have on your E55??
Old Oct 11, 2010 | 05:41 PM
TopGun32's Avatar
search the OEM parts on line...
and find a good mechanic.
I just bought plugs for about $100 for all 16.
btw... you can do certain things now and others can wait.
keep searching this forum.. atleast you are on the right approach.
Old Oct 11, 2010 | 06:25 PM
lilg210's Avatar
Mercedes E55
Forgot to mention the plugs I got were pulse plugs not spark plugs
Old Oct 11, 2010 | 06:34 PM
reitmeid's Avatar
2005 S55 1982 300dt
You'll only need 1 supercharger clutch assembly.
1130900044 is the improved clutch unit. Sells for around $765 at parts.com
Old Oct 12, 2010 | 02:14 AM
MBTEK's Avatar
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
I'VE GOT 2 BRAND NEW CLUTCH ASSY'S AND THE FRICTION FOR SALE IF ANYONE IS INTERESTED,INQUIRE IF INTERESTED.
Old Oct 12, 2010 | 04:13 PM
Racefiend's Avatar
Toyota Supra
As a reference, here are some hours straight from AllData for these jobs:
Spark plugs: 3.5hrs
Water pump (I'm assuming you mean SC pump): 1.1 hrs (couldn't find time on a 2003, used 2004). Add another .5 to custom wire an aftermarket unit.
Drain/refill coolant: .6 hrs (1.4 for a full coolant system inspection and flush)
Supercharger clutch: 1.8 hrs for the pulley (based on 2004). Add at most 1 hr to replace the cluth.
Also, he's putting right about a 100% mark up on the parts, assuming he's getting them from Worldpac, which I'm sure he is.
Hope that helps you make a decision on whether to use this guy.
I will say that I don't like his choice of Motul X-Clean for your car. That is a mid SAPS oil which really should not be used on gasoline engines in the USA that call for long oil change intervals. Xmax or Xcess would be a better choice.
Old Oct 12, 2010 | 07:00 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
This clutch along with a new ic pump and it will be like a new machine with no herky jerky bs.
Old Oct 13, 2010 | 02:31 AM
sgtstanko's Avatar
2006 E55
Do you have a part number for the cooler NGK's???
Old Oct 13, 2010 | 07:45 AM
reitmeid's Avatar
2005 S55 1982 300dt
I have the cooler plugs also. NGK LFR7AIX (2309). I paid $125 at Rockauto.
You can get them cheaper here:
http://ngksparkplugs.ecrater.com/p/7...idium-ix-spark
Old Feb 22, 2011 | 06:38 PM
SilverE55AMG's Avatar
E55 Amg W211
SC Clutch
I'm interested, need one for my 03 E55, How much????
Old Feb 22, 2011 | 06:58 PM
Jasoneo5's Avatar
W211 E55
x2 let me know!
Old Feb 22, 2011 | 07:57 PM
SuperchargerV8's Avatar
03 e55 amg
But at what k's will the supercharger clutch need to be changed and how or how do u no u need to change it
Old Feb 22, 2011 | 11:07 PM
Busta Riles's Avatar
1969 280S, 1991 300E
Also interested in price on the SC Clutch
Old Feb 22, 2011 | 11:14 PM
E55 Amg W211
I have P0410 Code
Secondary Air Injection Malfunction.
When reving the engine the supercharger doesn't kick in and the magnet isn't activated on the SC clutch. I was told that when reving the engine the magnet should click and get the SC on. I think this should happen around 2000rpm. Checked the clutch itself and it is working. Also checked the Secondary air pump and it is running as well (maybe unrelated to this issue).
But for some reason the computer will not activate the SC clutch.
Does any one know what else I need to check, or what else can be wrong.
Any info would be appreciated.
