2004 E55 Nav questions
I've never owned a car with a Nav system, much less a MB. I am interested in putting a Nav system in my E55. I contacted my dealer in Melbourne, FL and they cannot order one as it is apparently no longer an item that is carried. I have some rather basic questions so please bear with me.
1. What MB Nav systems are available to me to install in a 2004 E55? Is it just the W211 model Nav system?
2. I have the command unit, does this mean that all I need is the DVD Nav system and wiring?
3. Do these Nav systems have audio map instructions?
4. How current are the DVDs?
5. Does anyone have a Nav system for sale ?(this is probably not the right thread for this question).
Thanks in advance,
Gregg
- rear nav dvd drive
- gps signal splitter you may have that
- cage to mount rear nav drive
- nav dvd
you dont need any wiring, you can tap into the MOST cabel under the rear drive side door.
I HAD to have oem NAV, and it was not so much for how great it works, I just needed it. It works for my purpose, but again, it is less than great. Many threads here about nav. mbenznl.nl (Steve) is a pro at this, and can provide all parts. Again, it is expensive, and you need to understand what the end result will be.
PS- Welcome to the forum!! Enjoy the new ride!!
Best,
Gregg
https://mbworld.org/forums/w211-amg/...ic-z110bt.html
Plus I wanted ALL options. Even if they are not overly usefull
