Evosports Brake Rotors
Old 11-06-2010, 06:57 PM
Forrest Gump 9's Avatar
shrimp boat
Just wondering if anyone use the Evosport brake 2-piece rotors on their car?
How do you like it?
Are they ok to run as DD?
And are there any other options beside Evosports?
Thanks in advance.
Old 11-06-2010, 07:00 PM
Tom_Boy's Avatar
2003 CL55
Wayall, that's what mama always said.....
They should be fine...Don't see any reason why not.. Any other options out there yet?
Old 11-06-2010, 07:42 PM
E55Dimon's Avatar
E63S
I have them, they are perfectly fine for a daily, at least they have been so far. I havent tracked her or anything yet though.
Old 11-06-2010, 08:33 PM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
Great to hear you like them how are the akebono pads treatin em?
Old 11-06-2010, 08:39 PM
E55Dimon's Avatar
E63S
Thanks Tal, should've mentioned I got them from you.
They are a lot softer than I thought (not a bad thing) but certainly get the job done .
So far - no squeeks which is a HUGE plus. I had brembos on my last car and those loved to shoot a high pitched squeek, especially at traffic lights. Whew.
Old 11-06-2010, 09:09 PM
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
i wanted the weight savings so i went with them and stayed with OEM brakes . Car feel fine .
Old 11-06-2010, 09:31 PM
tgoss's Avatar
I'm really glad to hear that there is no squeaks brother! Enjoy the benefits of non-existent brake dust too
I'll definitely have to pick up a set after the winter has passed.
Old 11-07-2010, 08:37 AM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I'm going to replace my OEM rotors, with Evosports when it's time. To my knowledge Evosport are the only non-OEM direct replacement rotor on the market.
Old 11-07-2010, 03:05 PM
E55Dimon's Avatar
E63S
I haven't had em on long enough to tell yet, but if it eliminates brake dust then I'll be a very happy camper! Tired of that ish.
Hah, thanks again Tal.
Old 11-07-2010, 03:59 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Do you know who manufactures them? I get nervous with any aftermarket rotors that have been drilled and the quality of steel used. I'm also curious why Evosport didn't just slot them instead of both drilled and slotted (?)
Also are the vents opposite vents on left and right rotors? What's odd about the OEM rotors is that the vents are identical; it's one rotor for both sides with the same vent direction.
I do like the idea of less unsprung weight. Where is the weight reduction on these primarily? Is it in the hats?
Old 11-07-2010, 05:13 PM
KLR CLS's Avatar
CLS63 PP
If only they made P030's I would have a set already!
Old 11-07-2010, 10:23 PM
PREMIER SPONSOR
Simon @ evosport's Avatar
We drill and slot them to maintain the same design that came from the factory. We do offer SLOTTED only as an option if you prefer, but 98% of all customers will purchase DRILLED/SLOTTED. Quality of the rotors are as good if not better than any OE or aftermarket. We have been selling these for many years.
The OE rotors vent the wrong way on one side. They do this so they only have to cast one part that can be used left or right and save money on having to make another part. Our rotors are unique left to right so they are always venting the correct way.
The weight savings is huge and noticeable. Yes, the gains are primarily in the hat, although the disc itself is also lighter.
Old 11-08-2010, 05:03 AM
yooker's Avatar
a durr
Do you guys also make blanks, no slots or drilled holes?
Old 11-08-2010, 08:59 AM
shrimp boat
Any special going on? May be a group buy?
Old 11-08-2010, 09:12 AM
beauphus's Avatar
CLS55 & CL CK60
i have had them for the last 300 miles with porterfields. performance is good and less dust. weight savings is definitely a plus and they look awesome.
Old 11-08-2010, 09:18 AM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
I've had them on my E55 for over 3 years with Porterfield brake pads...no worries here...
Old 11-08-2010, 03:03 PM
PREMIER SPONSOR
No we do not offer blank rotors.
Not on the rotors.
Old 11-08-2010, 03:59 PM
Sunir's Avatar
SL55 AMG
Simon and Brad have been in the racing game for years...I am a BMW CR as well and the 2 pc brakes are good for everything he mentions...weight reduction, specifically unsprung weight which helps for braking and accelerating. The viens on thise rotors should identify left and right and should be correspondingly directional as Simon mentioned. Also the slotted only are just fine as far as performqance is concerned, drilled are more for looks, outgasing on the street is not a relevent factor. I agree the hat is the critical element of advantage in a 2 pc rotor.
My questions are (1) can these be run with factory pads or are there better options from a dusting, longevity, and performance standpoint that no not squeal for a road car (2) the price is very high, are there alternative kits or manufacturers?
Old 11-08-2010, 04:13 PM
220S's Avatar
fwiw, it wouldn't bother me if they cost the same as OEM providing they have better performance. Esp the weight. (also the vent issue is just plain odd as I mentioned already with the OEM rotors.) I'd prefer them not drilled just due to possible cracking/fatigue, etc., and as Sunir says, it's really just for show. You see slotted rotors on the track but rarely drilled.
I heard the OEMs are 'gray iron.' Steel versus pig iron versus gray iron. You hear a lot about the pros and cons. I don't know enough about materials, but am curious about the Evosport material and if they are sourced domestically, etc..
In the end, weight is def an issue. Probably well worth it for that alone, imho.
Quick Reply: Evosports Brake Rotors
