Airmatic....WTF?????
Old Nov 8, 2010 | 07:46 PM
930chas's Avatar
cornfed gtr and m3
I despise my airmatic. Why can't my car have the same stance on a daily...make that hourly basis? Does anyone else put up with this bull****? I have had the air suspension checked and tested, no leaks, no problems, no codes. Yet one minute my car is rocking the perfect stance, then it is notsomuch, and after that it is slammed and tucked..all without touching the elm or the factory settings. It is pissing me the **** off. Could my Renntech ELM be screwy or is this just the nature of the beast?
Old Nov 8, 2010 | 07:53 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i'd check your elm...
Old Nov 8, 2010 | 08:04 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
mine does that all the time. in fact when i parked at the gym the front driver side was 1/4 higher and when i get home it was equal to the passenger side. i am lowered via star
Old Nov 8, 2010 | 08:06 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
If you've had the car on the alignment rack and they went through the SDS protocol and the level sensors work, and no leaks, etc., then like Mikey says "it's the ELM."
The car should sit fine as long as you don't have a leak and/or the sensors work. At least mine does.......
ps., I'm at stock and not lowered.
Old Nov 8, 2010 | 09:01 PM
AWOL's Avatar
e55
Ive never had my car sag to one side, or front to back. it stays put. Im using the "washer" method
Old Nov 8, 2010 | 09:06 PM
930chas's Avatar
cornfed gtr and m3
I should state that the car is never sitting lopsided from side to side. It is only that the front and back will be sitting perfectly, and then a short time later they aren't, ie the back is sitting a little higher or the front is a tad lower, etc. No one else would notice this stuff, but it really bugs me. I think I am going to rip out my ELM and rewire it to see if that makes a difference.
Old Nov 8, 2010 | 09:15 PM
cahiil55k's Avatar
Mine does this when I am parked on uneven grade. Once my front-right tire was on a grade roughly 3 inches higher than the rear and sure enough the front was noticeably slammed and the back was raised a bit. I think this is nature of the beast for stock cars, not sure about cars with ELM though.
Old Nov 9, 2010 | 01:13 AM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
I'd be a little circumspect here. These cars are sensitive (& sometimes temperamental) beasts. Suspect this is normal, just more noticeable with your lowered stance. Learnt a long time ago that some things are best left alone.
Brgds
Old Nov 9, 2010 | 03:14 AM
BenzoBoi's Avatar
Super Moderator
W221
Screw it. Just slap some coils and get rid of the problem all together once and for all!
Old Nov 9, 2010 | 06:19 AM
930chas's Avatar
cornfed gtr and m3
Now that is what I am talking about!!
Old Nov 9, 2010 | 09:00 AM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
+1 on that as well. Mine does the same thing. One hour it will be down and tucked and the other it will be up an inch or so. Sometimes I swear it has the same ride height in comfort as it normally does in Sport 2 when I get out of the car. Other times it is riding higher like you would expect.
Seems like it's always been like this though so whatev. I just tell people my car and raise and lower at the touch of a button and they are impressed lol
Old Nov 9, 2010 | 11:40 AM
Forrest Gump 9's Avatar
shrimp boat
I think because the E55 have the self leveling system, so sometimes when you park on un-even ground your wheel-gaps are out of whack.
To the OP, may be you can give Bruce a call and see if he can put together a coil-over set-up for our cars.
Old Nov 9, 2010 | 01:31 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Bingo!
Old Nov 9, 2010 | 01:37 PM
930chas's Avatar
cornfed gtr and m3
Flat as hell where I live. My car is pretty much on level ground 95% of the time.
Old Nov 9, 2010 | 01:39 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Sometimes I feel like I a tripping in my car. You are sitting at a redlight and all the sudden you are looking through the Benz hood ornament (at the car in front of you) and see it moving either down or up. Feels really strange if you forget about airmatic. Must look weird to people checking out the car.
Can't imagine what it looks like for you ELM guys.
Old Nov 9, 2010 | 01:55 PM
shrimp boat
It's the automatic aim-ing option. The car zero-ing on the nex target.
Old Nov 10, 2010 | 09:37 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
was told there is a new rebuilt kit for the air shock from mercedes for around 300$ is this true?
Old Nov 10, 2010 | 10:03 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Im all stock and its got to be the ground, mines all over the place but still rides grade, i do have after market wheels and tires, I wonder if this has anything to do with it!?
