e63 2007 transmission fluid leaking and other problems
Old Dec 8, 2010 | 01:26 AM
2007e63AMGnyc's Avatar
2007 E63 AMG
i find out today that my e63 amg is leaking transmission fluid and the other problem is that it doesn't perform from gear 1-2. while at a red light today when it turned green i pressed the gas normally and the car just jumps and started to shaking which got me worried. if someone could help me out i would appreciate that
Old Dec 8, 2010 | 02:47 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Have you ever had the transmission fluid changed?
MB made it impossible (nearly) to do yourself, so take it to the dealer.
If it has been changed recently, then hope the leak is the oil pan and the dealer warrantees their work.
If it needs changing, once again hope it is the oil pan, because the gasket is changed during an oil change on the tranny.
If it is a gasket on one shaft or the other, then you are indeed "shafted".
I myself have a slow leak somewhere I need to track. It is so slow that it simply wets half of the back panel under the engine after 6 months. About a tablespoon maybe. Good luck.
I understand posting here. Although the 2007 E63 and the 2010 E63 do not share a transmission, neither does it share with the E55. You are likely to get a better answer in the C63 forum.
Old Dec 8, 2010 | 06:19 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
is the car jumping itself into C mode ?? if so right ot the dealer .
Old Dec 8, 2010 | 10:33 AM
Vic55's Avatar
Administrator
You posted this in the W212 forum... you have a W211- Ill move it now.
Members take note, it was in the wrong forum and because I clicked on the move button its now in the correct forum.
Old Dec 8, 2010 | 04:18 PM
2007 E63 AMG
it jumps in C,S and in M mode so i hope it is not the tranny and no i never changed the transmission fluid
Old Dec 8, 2010 | 04:45 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
That was happening to me @ the track last weekend . Still ran a 12.0 in C mode .
My trans is pretty much done again , Alot of slipping and jerking .
go to dealer
Old Dec 8, 2010 | 06:37 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
You crack me up Jon
Old Dec 14, 2010 | 12:29 AM
2007 E63 AMG
i just got the news from the dealer and its a transmission problem they said that gears 1-2 blew out and need to be changed along with the transmission valve so it doesn't look good
Old Dec 14, 2010 | 09:11 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
As long as its under warranty dont worry . MAke sure you check the car out when picking up and take for a short spin and bring back too dealer to make sure no issues before you leave.
When my car was picked up after trans replacment it was gushing oil and had to be brought back , Good thing Bruce from TTM video taped it so dealer could not try and bs their way out of it .
i had almost similar issues , 1st and 2nd slipping .
Old Dec 14, 2010 | 09:20 PM
2007 E63 AMG
yea thanks man i know im going to take it around the block before leaving with it and did you have any transmission problems with your car after that?
Old Dec 14, 2010 | 09:25 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
300 miles and trans is toasted again .
Old Dec 14, 2010 | 09:28 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Wow, sorry to hear of your woes....I'd thought the 7G was proving fairly robust?
Old Dec 14, 2010 | 10:47 PM
2007 E63 AMG
yea than that does not sound too good for mine but its w.e. now
Old Dec 15, 2010 | 02:11 AM
bce63's Avatar
e63
I have had the same. My car had the oil leaks fixed from the smaller pan and sensor last week. 2 nights ago at a light I pressed the gas and the car rpm raced up and the car went very slow, I was surprised for it was an odd feeling. As I figured out something off I realized my paddle shifters did not work nor my transmission button. I inched the car until I could pull over. I turned of the car waited a few min. and restarted and everything seems to be fine. Almost seemed like a clutch slipping but when restarted not any different from before. 2 weeks ago had service E done
Old Dec 15, 2010 | 02:14 AM
bce63's Avatar
e63
For info I have 55,000 KM on car.
Old Dec 15, 2010 | 11:28 PM
2007 E63 AMG
yea its bad man my clutch burnt out its costing me big time for the transmission but mine was bad i had the gas pedal halfway and the car wouldn't move at all
Old Dec 16, 2010 | 07:43 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
i found a shop in jersey that sells rebuilts for 3600 .00 hopefully i dont have too go that route .
