Anyone every explored the avenue or getting a custom ring and pinion made
Old Jan 19, 2011 | 09:30 AM
chawkins2001's Avatar
2006 E55 AMG
I believe ours is 2.81 or there abouts, has anyone upgraded to say a 3.73 or 4.10 ring and pinion gear I know you can step up to a SL55 rear, but that is such a small jump it would not be worth it.
Imagine with our tq monsters what that would feel like and how it would improve 1/4 mile times although the top end would suffer a little. Would we be able to calibrate our speedo's as I am sure the computer would freak out?
Old Jan 19, 2011 | 09:54 AM
skratch77's Avatar
2005 E55
My first and second gear is a joke depending on the temp out side.im sick of driving on drag radials lol put me on the list for longer gearing
Old Jan 19, 2011 | 11:46 AM
Flight Test's Avatar
Buick T-Type, 70 cuda, S65 and a very FAST Truck!
I believe the SRT8 Dodges have the same differential. I wonder if the 3.55 and 3.73 gears that they offer would interchange.
http://www.mylrs.com/blogs/lrs/archi...ing-gears.aspx
Old Jan 19, 2011 | 12:02 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Stock is 2.65 , SL is 2.82 and then there is a 3.06, although I cannot recall from which car its from, could be G55/DTM...
Anyhow ... the hardware (being non trivial) is a walk in the park compared to getting the EGS to play ball... Even though my car with a 2.82 runs OK - I still think there is room for EGS improvements ...I am convinced the ECU/EGS pull performance somewhere along the line especially when speed climbs as the system sees larger delta differences between expected wheel speeds and actual wheel speeds...
I have yet to hear of one 3.06 running 100%, while there are a few 2.82's running reasonably ok.
Anyhow, some free advice ... dont go there.
Old Jan 19, 2011 | 01:26 PM
blackbenzz's Avatar
haters crazy
Kleemann offers TCU tuning but don't know about gearing changes of that magnitude. I foresee alot of spinning and if it hooks, alot of breaking
CLK Black. Cory is selling a used one with TCU tuning for it
Old Jan 19, 2011 | 01:38 PM
2006 E55 AMG
You are refering to Kleeman Cory right??
Old Jan 19, 2011 | 04:05 PM
NCE500's Avatar
2007 E63, 2006 C55
Re: Diff Ratio
+1. As of a few days ago I believe that Black Series diff was still available at Kleemann. I'd venture going much past that ratio would be a challenge with anything other than drag radials for your car anyway.
Old Jan 19, 2011 | 05:45 PM
blackbenzz's Avatar
haters crazy
The one and only
Old Jan 19, 2011 | 07:52 PM
320 dreamer's Avatar
2003 porsche 996 turbo
we tried this on the xfire forum to go from a 3.07 to a 3.27 gear. car hits limp mode every time in 2nd gear. to date no one has figured out how to get the tcu to play nice
Old Oct 24, 2011 | 04:51 PM
xpl0sive's Avatar
CLS55 AMG
Has anyone figured out the TCU tuning for the higher ratio gearing?
Old Oct 24, 2011 | 05:09 PM
2006 E55 AMG
It would be shweet to step up to a 3.55 IMO.
Old Oct 24, 2011 | 06:59 PM
KLR CLS's Avatar
CLS63 PP
Jerry has it the tuning sorted out. I am going to try to instal my 3.06 this month..
Old Nov 6, 2012 | 05:30 PM
mikesanto70's Avatar
06' SL600 03' C230K
Who is Jerry and can I have his contact info please, I'm interested in a ring &pinion change!!!
Thanks,
Mike
Old Nov 6, 2012 | 06:50 PM
e55amgrocket's Avatar
Dirt Scooters
Jerry from eurocharged.
Old Nov 6, 2012 | 07:13 PM
2006 E55 AMG
No one that I know of has gone above a 2.82 ring and pinion which is the stock sizing for sl55's. Jerry from eurocharged performance has the tcu tune for the gear swap.
Old Nov 6, 2012 | 07:20 PM
justinwrock's Avatar
Ducati
PAcougar has 3.55s....
Old Nov 6, 2012 | 09:45 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
I do have 3.55's, and we're still getting the shift tuning dialed in. I'll let everyone know once it's working correctly.
Old Nov 6, 2012 | 10:01 PM
Hulk's Avatar
A Merc
+1 for info PACougar
Old Nov 6, 2012 | 10:58 PM
GT-ER's Avatar
2005 E55 AMG
Whoa....you must do 4th gear burn outs...lol.
I'd hit shorter gears for sure, but no more than 3.0x.
Old Nov 7, 2012 | 12:48 AM
PACougar's Avatar
Ahhh, you're a boring person Plus I'm running ET Streets on my stock 18's
Old Nov 7, 2012 | 08:20 AM
2006 E55 AMG
Haha.
Old Nov 7, 2012 | 04:35 PM
06' SL600 03' C230K
Do the SL's have the same rear diff? I have a 97' R129 M119 and I'm trying to make this thing get up a little better and a 3.55 would def do that!!!!
So do the E55's and SL's share the same diff?
Old Nov 7, 2012 | 04:43 PM
PACougar's Avatar
I think some came with the 215mm dif and some came with the 210mm diff. If it has a 215mm ring gear in it then it should work.
Old Nov 7, 2012 | 05:20 PM
06' SL600 03' C230K
Thanks, I'll research it and see if the 97' R129's came w/ a 215mm ring gear!
Old Nov 23, 2012 | 11:00 AM
2006 E55 AMG
Can anyone verify if these are the 2.82 215mm gears we need that will work with our diffs:
http://www.ebay.com/itm/REAR-DIFFERE...torefresh=true
http://www.ebay.com/itm/REAR-DIFFERE...36a3ba&vxp=mtr
http://www.ebay.com/itm/05-10-Dodge-...b4651b&vxp=mtr
http://www.ebay.com/itm/06-10-300C-M...9fa507&vxp=mtr
