Coolant Temps and IAT temps
Old Feb 28, 2011 | 04:56 PM
chawkins2001's Avatar
2006 E55 AMG
I have been watching these two with the Torque app and was wandering what you guys are seeing with yours?
Old Feb 28, 2011 | 05:06 PM
randallaguirre's Avatar
2010 Silverado, 03 H2, 66 Nova SS, 03 E55
So what you're saying is to go play with my car for a little bit.... and report some findings.
Great idea!!!
Old Feb 28, 2011 | 05:22 PM
izzyz28's Avatar
2004 E55 AMG
With an ambient temperature of 29 degrees I was seening coolant temps rock solid at 186. IAT's were around 60 to 70, would dip a bit when I got into the throttle, and then would begin to quickly rise if I stayed in it. I did a 0-90ish run and saw IAT's hit 138. I'm sure my cruising IAT's would have been lower if I had started logging with the car cold, but I drove home from work, parked the car, and then went for a drive about half an hour later.
Old Feb 28, 2011 | 05:27 PM
KLR CLS's Avatar
CLS63 PP
With ambient at 30 degrees, I see about 50-55 IAT's cruising, and 170ish on the coolant.
Old Feb 28, 2011 | 05:47 PM
Wow my numbers are looking a little nutty. (all stock)
61 Ambient.
190 coolant
127-180 on the AIT's....
HHHMhhhhhmmm
Old Feb 28, 2011 | 05:50 PM
KLR CLS's Avatar
CLS63 PP
See it has paid off already. Your IC pump is certainly dead.
Old Feb 28, 2011 | 05:54 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
usually 15 over ambient.
recovers back in about 10 secnonds.
Old Feb 28, 2011 | 05:57 PM
Dammit.... Brand new J-CM30 too.
HHhhmmmm
Old Feb 28, 2011 | 06:14 PM
KLR CLS's Avatar
CLS63 PP
HHhhmmmm
Did you bleed it correctly after the install?
Old Feb 28, 2011 | 06:32 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Used torque today and with 72 ambient, IATs stayed around 98 - 103 and shot to 130s when i floored it. can't recall exact coolant numbers but looked to be 190 area. Was more excited to finally see boost as my last datalogger didn't show me that.
Old Feb 28, 2011 | 07:24 PM
I believe I have.... I just got under there and jumpered it, crimped the return hose below the alum tube, and it's not pushing anything thought the nipple, even after 1/2 hour not even a drop.
I'm thinking I have DOA J-CM30.
Nothing worse then when your johnson wont work.
Ohh man...... I'm sorry this is looking like a thread hi-jack.
Old Feb 28, 2011 | 08:02 PM
03'55AMG's Avatar
AMG
Warranty maybe? Whend you but it?
Old Feb 28, 2011 | 08:11 PM
2 months ago.
I'm going to Home Depot to get some 3/4 in clear tubing... I'm gonna test this dude just to be sure.
If it's bad, then work the warranty route.
Old Feb 28, 2011 | 11:22 PM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
Ambient 25C, IAT 32C when KC off. but when KC on IAT 20-21C while cruising.
when kicking it hard to 320km my IATs reachs 78C (172F)
engine temps while cruising 73-75C ( i have 71C thermostat). @ WOT 320km 90-91C.
Old Feb 28, 2011 | 11:32 PM
Todd Edge's Avatar
E55
2 months ago.
I had issues when I installed mine and the H/E. I ended up using a battery jumper and direct wiring the CM30 to the jumper and I could then hear the pump turn on and knew it was working. Once you do that and run the clear hose to the resevoir, you'll see the coolant start to flow. I found it easier to fill the resevoir and let it sit for a while with the cap off and then to remove the nipple cap to further relieve the pressure in the system and let the coolant flow. Once I couldn't get any more coolant in the resevoir, then I turned the pump on and about 30 minutes later, no more bubbles. I'd check to make sure the pump works by wiring it direct first.
Todd
Old Mar 1, 2011 | 09:03 AM
2006 E55 AMG
IAT's around 127*
COOLANT 186*
AMBIENT 50*
This is strictly stop and go traffic. What should IAT's and coolant be?
Old Mar 1, 2011 | 09:24 AM
Is this without ever hammering it?
this is very similar to mine....
IAT's around 127*
COOLANT 186*
AMBIENT 50*
Old Mar 1, 2011 | 09:30 AM
2006 E55 AMG
Just driving in stop and go, no hammering at all.
I have hammered it quite a few times before on other occasions with no supercharger shut down, car feels very strong.
Old Mar 1, 2011 | 09:32 AM
nanayaw6's Avatar
^^ Those IATs look to be very high cos I didn't climb that high yesterday until I floored it for a while. I'm still stock cooling with dealer bosch replacement for what its worth.
Old Mar 1, 2011 | 09:35 AM
shardul's Avatar
Craig those IATs are way to high for 50F ambient. If you have replaced the pump you probably have air pockets in the system
Old Mar 1, 2011 | 10:19 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
I'm driving now.......46 ambient......IATs at 60 normal running two hard pulls to 100 highest I saw was 101iat....coolant around 180 solid. I'm on a new Bosch factory pump.
A few more hard pulls and it jumped to around 97 but I could not get it over 100 again.
Old Mar 1, 2011 | 10:42 AM
Evolved8's Avatar
AMG Fam
What are you using to monitor Marcus?
Old Mar 1, 2011 | 11:09 AM
emoving's Avatar
Torque on my DROID......it plugs in to any car if you want to check yours feel free.
Old Mar 1, 2011 | 11:47 AM
2006 E55 AMG
Guess I will get a new bosch. Where is the best place to get one and what is the part number. My pump has not been replaced since I bought the beast last year.
Old Mar 1, 2011 | 11:50 AM
emoving's Avatar
Mine was done under warranty last month and I do not know the part number. They just told me with was a brand new pump BOSCH just came out with to replace the old one with. I have a new Johnson I brought in but they said the new BOSCH is much better and Jerry at EC and Craig at RPM concurred.
