air box mod
Old 03-11-2011, 08:37 PM
black05scamg's Avatar
2005 e55 black on black 07 e63 po30
air box mod
i ve been reading about the hi flow air boxs on here and i seen that the rest of the world gets the boxs with out the plastic covering the the port
in the box cant we just mod the box by cutting off the piece if so can somebody ppost some pics thanks
Old 03-11-2011, 09:16 PM
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
PM TTM he does it . Also you can remove the baffles on the intake tubes located under the hood behind the grill but added air flow you will most likely have to tune the car eventually . MOst cases will throw a CEL light
Old 03-11-2011, 11:28 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Replace the highly restricted left side intake pipe with an unrestricted right side intake pipe (about $15); drop in a couple of K&N's; remove the intake baffles and you will be amazed at the improvement.
Old 03-12-2011, 12:25 AM
where are the intake baffles
Old 03-12-2011, 12:35 AM
03'55AMG's Avatar
AMG
+1, what baffles
Old 03-12-2011, 12:36 AM
03'55AMG's Avatar
AMG
Or do you mean the plastic cover on the intake behind the grill? I noticed an increase by removing just those restricting flaps
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
follow the intake tubes right on top of the radiator and there are your baffles or snorkles or scoops as some like to call them . run right thru the radiator support
Old 03-12-2011, 12:38 AM
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
dingding ding ! also TTM makes a modified scoop and RPI sells a piece of metal to help direct air flow too
Old 03-12-2011, 12:40 AM
03'55AMG's Avatar
AMG
Yea, ttm has some really nice ones. I was thinking about re-routing the tubing down into the h/e grill, but it'd just be more restrictions.
Old 03-13-2011, 09:26 AM
munich55's Avatar
E55 AMG W211 - sold, CLS 500 C219, E63S AMG W212
Can somebody take a picture or are this these one behind the grill?
Old 03-13-2011, 02:23 PM
AgSilver's Avatar
Exactly!
Old 03-13-2011, 02:46 PM
03'55AMG's Avatar
AMG
just pop the hood, and on each side of the grille where the snorkels go, there will be a bunch of plastic junk and flaps that just constrict air flow. i cut mine off with a utility knife
Old 03-13-2011, 07:01 PM
AK-AMG's Avatar
E55 AMG
Are they different?
Old 03-13-2011, 07:04 PM
03'55AMG's Avatar
AMG
lmao, YES! the left one is about an inch and a half all the way into the filter, the ds is all indented and very restricting
Old 03-14-2011, 04:47 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
Why would they design it that way?
Old 03-14-2011, 05:12 PM
03'55AMG's Avatar
AMG
to save space and costs most likely
Old 03-14-2011, 05:22 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
I put an s55 one on mine. the stock one is so restrictive and i think they did it to fit around some kind of hose.
Old 03-14-2011, 05:36 PM
03'55AMG's Avatar
AMG
yeah the coolant hose is a lil in the way but theres plenty of slack to fit a bigger snorkel
Old 03-14-2011, 05:44 PM
BenzoDoc's Avatar
2015 E63S 4Matic
I'm running an S55 pipe and it's more of a mental crutch than functional I think. It's larger, yes, but the inlet is still crimped like the original driver's side pipe. Also, if you've felt the pipes before, you'll know that there's not a very good seal being created at either end [into the filter housings or at the front pass through near the headlights].
With that said, I built my own metal intake scoops in place of the OEM plastic ones, and removed all that plastic junk over the weekend.
I've learned 2 things so far. 3 minutes of idling heat-soaks the metal that I fabricated my scoops from to a temperature so hot it burns you when you touch it, even with high temp paint. Additionally, it's a damn ***** to get them to seal properly without being able to properly weld oval loops to stick into the front of the pass-throughs.
I'm going to try and rectify the bad seals at the filter housings with a metal hose clamp to compress the plastic intake tubes at that end. At the other end, I'm going to start with 3M double sided tape, if I can't think of a better binding agent that will better hold up to the extreme heat. Like a silicone intercooler coupler wedged in there and over the collector of my intake scoop.
Old 03-14-2011, 05:53 PM
03'55AMG's Avatar
AMG
I was going to see if i cant make my own long tube snorkels and just get rid of the stock inlets all together.
Old 03-14-2011, 05:59 PM
AWOL's Avatar
e55
the difference between s55 and e55
Old 03-14-2011, 06:00 PM
BenzoDoc's Avatar
2015 E63S 4Matic
If you took that picture [Scott W? ] - are you running exhaust-wrap on your intake tubes.
If so, did you change your factory inlets behind the grill or were they on when you ran your 11.5?
Old 03-14-2011, 06:10 PM
AWOL's Avatar
e55
I did take the pic.
I wrapped the tubes and made my own "scoops" for the 11.5 run.
Old 03-14-2011, 06:13 PM
BenzoDoc's Avatar
2015 E63S 4Matic
I did take the pic.
Good enough for me. What all did it take to go from 12.0 to 11.5?
I'm the Michael that randomly fb'd you btw.
Old 03-14-2011, 07:07 PM
ertech's Avatar
Ate we talking about the e63 or e55?
Quick Reply: air box mod
