Help! Super rough idle/ leak?
Old Apr 29, 2011 | 09:43 PM
tbal's Avatar
Haters crazy
Read through some of the threads, going to have the car scanned to see what the CEL is for...
Car was parked for about 2 weeks, the air intake pipes on both sides were not connected, rad fan was disconnected (was waiting to install shims)...
today installed all the stuff, fired her up and BAM, was idling SUPER rough, CEL, and drove like crap...
Also noticed the magnetic pack is not spinning at idle, unless you give some gas... the clutch is spinning with the belt with no problems... my first guess is some sort of leak? I didnt disconnect anything else... any thoughts?
Old Apr 29, 2011 | 10:16 PM
E55Dimon's Avatar
E63S
Damn bro, it couldnt have just went smooth for you..always something.
Hope you get this ish figured out asap and proceed with previous plans
Old Apr 29, 2011 | 10:41 PM
03'55AMG's Avatar
AMG
I have a feeling the only response your going to get until you post the codes, will be to post the codes.. lol, sorry
Old Apr 29, 2011 | 11:06 PM
tbal's Avatar
Haters crazy
Lol damn
Seems like a vacume leak... Where are the place to check for vac leaks?
Old Apr 29, 2011 | 11:49 PM
tbal's Avatar
Haters crazy
Also i had the intake pipes unconnected, and fan. This happened all of a sudden, read a thread about unmetered air and resetting will try this...
Any pics or details on where to check for leaks? Tb, firewall, charcoal filter area?
Old Apr 29, 2011 | 11:57 PM
GT-ER's Avatar
2005 E55 AMG
The reason why the sc isn't spinning is because the second/bypass throttle is fully opened ( I've had this happen already ). I was servicing my sbc though when it happened to me and as soon as I finished messing with the sbc the issue was solved. You must have left SOMETHING unplugged somewhere...take a good look.
Old Apr 30, 2011 | 12:22 AM
tbal's Avatar
Haters crazy
Me and bro spent a good 45mins looking lol nada. Fawk gonna try to reset perhaps?
Old Apr 30, 2011 | 04:24 AM
tbal's Avatar
Haters crazy
anyone, shardul?
Old Apr 30, 2011 | 11:42 AM
03'55AMG's Avatar
AMG
Hm. do you have access to star without a dealer? If not, then repeat the same procedure you did before, with unplugging the fan, shimming it, etc, maybe youll see something you were looking for but missed.
Old Apr 30, 2011 | 01:17 PM
tbal's Avatar
Haters crazy
Could unplugging the ecu have done anything?
Old Apr 30, 2011 | 01:20 PM
skratch77's Avatar
2005 E55
I would re seat your ecu pins if you unplugged it
Old Apr 30, 2011 | 02:13 PM
tbal's Avatar
Haters crazy
ecu re-seated, problem still there
Going to head out to have her scanned... is it okay to drive like this?
Old Apr 30, 2011 | 03:16 PM
tbal's Avatar
Haters crazy
Codes
p0135 heater circuit
p0155 02 sensor
p0202 injector open circuit cylinder 2
p0413 secondary injection switch
p0302 cylinder 2 misfire
lol anyone? Could me unplugging the ecu, have possible done something to one of the relays/fuses?
Old Apr 30, 2011 | 06:08 PM
tbal's Avatar
Haters crazy
Sooooo... as per Sharduls instructions, unplugged the battery, unplugged ecu plugs, re plugged them, plugged in battery, fired it up and she was running perfect! Was a loose connection on one of the plugs after all.
Thanks to everyone, thanks Scratch, big thanks Shardul for my numerious calls over the past month lol
BTW installed the shims, and now car runs perfect!
Old Apr 30, 2011 | 06:24 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
nice glad to hear it all worked out
Old Apr 30, 2011 | 09:24 PM
tbal's Avatar
Haters crazy
thank you yaar!
Old Apr 30, 2011 | 09:28 PM
03'55AMG's Avatar
AMG
Great! I was hoping it wouldn't have forced you to take it to the stealer!
Old Apr 30, 2011 | 11:05 PM
tbal's Avatar
Haters crazy
I was more pissed/stressed because our dyno and eurocharged tune day is in a week lol
