Ecu/obd tuning question
Old 05-11-2011, 12:56 AM
tbal's Avatar
Haters crazy
I have gotten numerous pm's about this so thought i'd post this. I'm curious myself and others are curious too...
For simplicity and non argumentative sake we will have company A and company B.
Here's the scenario... I have company A tune on my car, can company B come and read company A's tune through the obd and back it up to their computer and then flash my car with the company B tune, and then finally revert back to company A's tune?
From my understanding wouldn't you require the ecu to come out to read either companies tune?
Please keep this on topic and civilized.
Old 05-11-2011, 12:01 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
+1 Curious myself.
Could a person plug in an OBD2 device and pull your tune???
In the past it was always NO, but have things changed?
Old 05-11-2011, 01:01 PM
Benz-O-Rama's Avatar
I've gone through 3 ECU tuners on my SL600. Each time, company A pulled the chip from the ECU, read the current file in case I wasn't happy and wanted to revert, and then loaded their file via OBDII.
Old 05-11-2011, 01:13 PM
tbal's Avatar
Haters crazy
So it has to be from the ecu? No way possible to do all of it from obd? Hmmmmm anyone else?
Old 05-11-2011, 03:19 PM
Jakpro1's Avatar
Just went to Tibet to speak to the master. Okay just emailed Cory at Kleemann and got a response.
Cor says he has never heard of a device that can pull the tune from just OBD2. It just reads ECU ID.
Old 05-11-2011, 03:25 PM
ssonss1's Avatar
Flying Spur
Some shady stuff going on
Old 05-11-2011, 03:32 PM
dychen's Avatar
11 QX56, 09 E63, 00 S2000
Not sure about the Mercedes line, but I know it can be done.
Softtronics has done it Porsche.
I'm pretty sure Cobb has something for the GTR that uses the ODB port as well.
Old 05-11-2011, 03:36 PM
skratch77's Avatar
2005 E55
You can read bins over obd2
Old 05-11-2011, 03:46 PM
dychen's Avatar
http://www.softronic.us/index.php
"Softronic is the first company to start flashing the Porsche DFI and LSI line via the OBD2 port. This along with our data server is another first only credited to Softronic."
Old 05-11-2011, 04:07 PM
Roverron's Avatar
ML63
I thought a tuner could flash between stock and re-tuned file. The reason I say this is I had company A file on the car which i sent ECU out to be programed. then later bought flash loader and had car flashed with a new file from company B. The one time I tried to flash back to stock with flash loader car went into limp mode so i re-flashed modded file back on. so i could drive it. if you cant flash back to stock or old file then i was misled by company B.
Old 05-11-2011, 04:13 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
flash is a flash... either way you can pull a file FROM the ECU via OBD2 and save whatever changes you find on your computer.
You do NOT need the physical ECU to change or alter anything if we're talking tuning specifically for the w211. For example if you're tuning a c63 then you'll need the physical ECU & modifications has to be done to it in order to tune it.
In your case, ECU files can be easily swapped and saved to your computer by reading and transfering data with OBD port.
Not sure if that makes sense?!
Old 05-11-2011, 04:17 PM
_AMG_'s Avatar
C63
Some tuners make a OBDII flasher which can switch between tunes.
Old 05-11-2011, 04:19 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
+1
Old 05-11-2011, 04:27 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
switching between (overwriting) tunes over obd2 is entirely different than pulling/saving ecu info...
Old 05-11-2011, 04:38 PM
skratch77's Avatar
2005 E55
There are tools out there that will read a bin file off the ecu.
I think surcharged has the Dimsport hardware that will read the file.I know because they sent me it.
Old 05-11-2011, 04:39 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
I understand but essentially from what i know is that a flash/tune is just changes done to a map. You can pull a map out as a computer file "forgot the specific type" then you can make changes to it and save it as another file which is then transferred back to your car.
Now that you have two files, one original, and one altered essentially you can switch back and forth as long as you have the tools to do so.
Old 05-11-2011, 05:01 PM
nicco's Avatar
E55 AMG
Any of the tuners out there wanna shed some light this topic?
Old 05-11-2011, 05:09 PM
Jakpro1's Avatar
Yeah, be interested in Jerrys take on this.
Unless I see it done in front of me, I won't believe it.
Been so many years we have been trying and not able to pull that tune on OBD2.
Times change though. Would love to see it done!
Old 05-11-2011, 05:22 PM
SPONSOR
sales@eurocharged.com's Avatar
C63S
I do not have access to ANY equipment that can read the ME2.8.x ECU via the OBDII port. I can read them on the bench, but not via the diagnostic port.
I can read thousands of other cars, but not those that have an ME2.8.x ECU.
I would love to know what hardware can.
Old 05-11-2011, 05:29 PM
nicco's Avatar
E55 AMG
Then how do you backup a stock file before you flash a car?
Old 05-11-2011, 05:37 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
damnn my analogy was wrong then haha its good that jerry get shed some light! please enlighten us!
Old 05-11-2011, 05:48 PM
tbal's Avatar
Haters crazy
So many mix answers, its confusing...
Old 05-11-2011, 05:54 PM
SPONSOR
C63S
Unlike other platforms, the data inside the ME2.8.x ECU will be the same from one ecu to the next, as long as the HW/SW numbers match. In other words, you only need to ID the car.
If the customer has a tune that they would like us to save, then the ECU will need to be pulled and read out on the bench.
Old 05-11-2011, 06:54 PM
ssonss1's Avatar
Flying Spur
So back to the original post, this means tbal is running company B's tune?
BOOM!!!!
Old 05-11-2011, 07:15 PM
keith954's Avatar
cls55
BOOM!!!!
Quick Reply: Ecu/obd tuning question
