SPEEDRIVEN | E55 Twin-turbo PKG (feeler)
Rating: Thread Rating: 4 votes, 4.00 average.
Old 09-14-2011, 02:27 PM
  #201
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Originally Posted by V12Godspeed
Since this thread went somewhat to another topic I'll jump in.
I have not posted dynos on my current EV12 set up but the power results are astonishing to say the least. I will round, my set up is putting roughly 700rwhp at roughly 1.2 Bar...thats nothing, what makes it more interesting is the Air fuel is just in the 9.5, 9.6 range at WOT. Thats ridiculous rich. We are not even talking race gas yet, timing etc... The damn boost controller didnt let me raise the boost to 1.6-1.7 bar but I finally got it to that and threw in a new file. Just when we were about to redyno the intercoolers started leaking. we are fixing that right now and will jump right back in the dyno this weekend.
I went with this set up because I owned a 65 modded to the teeth. Everything I ran it killed at the track. While many will say its not practical having this set up, It is the best thing I could have made.
A V12 in the lighter boddy E class is my perfect recipe for a 9 second slip.
While I dont believe in bench racing and definitely dont want to run my mouth without first having this thing go on a track I will not rest until it runs 9s. Its the only reason I went this route. If you do the simple math you will see it will.
If someone has the patience, money and a good shop its definitely doable. The toughtest part is not the fabrication, its dealing with the smallest details in tuning, programming etc. Knock on wood the last gremlin I am going thru is tuning and speedriven just sent me a new file.
I am making it to MIR Oct 7th I hope to make her track debut that day.
I'm very excited for you, and I hope you get that 9 second slip! Next year I'm planning on doing the same, I just want to stick with the 55 motor. Call me sentimental. Plus I like making things nearly impossible to achieve.
Old 09-14-2011, 02:29 PM
  #202
Brian420's Avatar
e500
Originally Posted by gaspam
u really dont know what u r talkin about do you? we have 11.2 PSI on the amg s/c... there is no 7psi kleeman in the w211 e55.
also the tranny in e500 and e55 are not the same... e55 uses Speedshift 5-speed automatic transmission which has a torque capacity of 796 lb-ft while the e500 7G-Tronic which is limited to 542 lb-ft..
good luck with that custom 15psi turbo set up on stock naturally aspirated motor post videos
My e500 has a 5 speed tranny don't know were ur getting your info from! Same as the 55 seems you dont know benz as well as u think my friend! Do ur research and dont make ur self look like a A**.. Funnny
Old 09-14-2011, 02:30 PM
  #203
PACougar's Avatar
Damn my diesel truck has a 5 speed tranny as well, it must be the same one that's in the E55 as well
Old 09-14-2011, 02:35 PM
  #204
Brian420's Avatar
e500
Originally Posted by PACougar
What are you talking about? We don't have Kleeman SC's, we do have motors built for boost, and we make alot more then 7 pounds of boost. I'm starting to realize you don't have the slightest clue what your talking about. I'm guessing the biggest mod you've done to a vehicle involves taking it to a tire shop
Im not gettin into a pissin match with you. I have more mechanical skills I forgot about then you will ever know... Go work on your cougar cause thats all a mechanic like u is good for! Pa couger haha
Old 09-14-2011, 02:37 PM
  #205
MBfinatic's Avatar
e36 318i, 2004 sti
I think the C55TT is a better idea than to change the E55K into a E55TT....
Old 09-14-2011, 02:39 PM
  #206
Brian420's Avatar
e500
Ok in the beginning of the forum people were saying they were using kleemans and etc.. Ok so 11. watever and your gonna add twin turbs? On ur naturally aspirated motor? So u guys gonna add 2 psi of boost before u blow it up? Yea right ur figures make no sense to anyone logical!
Old 09-14-2011, 02:42 PM
  #207
Brian420's Avatar
e500
Your making your self look smarter and smarter! Call the dealer and ask them maybe they can fill u in..
2006 e55 has a 722.6 tranny... 2003 e500 has a 722.6 tranny WIS/ASRA tells the truth
Old 09-14-2011, 02:49 PM
  #208
Brian420's Avatar
e500
If you even have Wis/ASRA to look it up ! Know what you talking about before u try and bash me.. LOL
Old 09-14-2011, 03:05 PM
  #209
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
wow ur a smart one .. the e55 is not a n/a motor, its a f/i motor that is built for boost from the factory.... ur e500 motor is the n/a motor and not built for boost so adding 14-15psi will be a lot more likely to blowup the e500 motor than 14-15psi on the e55 motor
  #210
PACougar's Avatar
If by same transmission you mean the outside of the case, then yes your correct. However the internals between the two transmission are very much different and the 722.6 in your E500 can't handle anywhere near the power of the 722.6 behind a E55.
Old 09-14-2011, 03:12 PM
  #211
gaspam's Avatar
ur still wrong as they are still different... the non-AMGs use the 5G-TRONIC while the AMG's use the 5G-TRONIC with SPEEDSHIFT A version with mechanical lock-up of the torque converter from first gear, steering-wheel-mounted shifter
just because they have the same 722.6 cast doesnt mean all internals are the same
Old 09-14-2011, 05:58 PM
  #212
Brian420's Avatar
e500
Both of you dont know what your talking about! Rather funny how u defend ur 55 as being this special motor and tranny car... I sit and talk with certified renntech installers that own a certified MB shop. I dont get my info from joe blow cause it sounds cool. You can argue till you both turn blue in the face in the end it's the same exact tranny and motor minus the supercharger. The m113 5.4 is the exact same engine with a slightly longer stroke. If you think mercedes built this special 5.4 any diff than every other m113 I assure you are WRONG. Your gonna be really sad when u blow this special engine with boost + SC.. You both already made a A** outta yourselfs. Keep thinkin your m113 is this one off special motor maybe you can tell your wife that and she will believe yea. There is a rentech tranny upgrade that you can add to the 722.6. Funny how u bounce around from saying its 7 gear tranny , to ok ur right it 5 speed on the outside. To yea it same but has speed driven bs! Who is tellin you this ? ? And were are you getting these bogus facts. I had my tranny replaced and requested the e55 trans thinking there was a difference . Every shop told me there is no diff in the two trans.. Hilarious
Old 09-14-2011, 06:01 PM
  #213
Brian420's Avatar
e500
Congrats man your tranny is ready for what they call paddle shifters .... Thats ur speedshift probaly! You can play with your steering wheel while i just press the gas.. Dont get to full of urself again its what they call a 722.6 tranny and thats all it will ever be.. Relax
PS Renntech offers a tranny upgrade which is simple to install from what i heard- You should install that to make this 722.6 diff cause nothin else is! Atleast then u can honestly say its diff
Old 09-14-2011, 06:06 PM
  #214
MBfinatic's Avatar
e36 318i, 2004 sti
Can we just make a TT kit for the N/A 55 crowd?!?!
Old 09-14-2011, 06:15 PM
  #215
Brian420's Avatar
e500
http://www.freddiestransmissions.com/html/mercedes.html
Look how many vehicles use your special 722.6 tranny. Look on the list here to state facts. EXACTLY THE SAME
Old 09-14-2011, 06:16 PM
  #216
Brian420's Avatar
e500
722.6xx - 5-speed - (722.625 Pictures)
  • 1997-2005 Mercedes C230 - L4 1.8l or L4 2.3l (Pictures)
  • 2002-2005 Mercedes C240 - V6 2.6l
  • 1997-2000 Mercedes C280 - L6 2.8l
  • 2006 Mercedes C280 - V6 3.0l - RWD or 4x4
  • 2000-2005 Mercedes C320 - V6 3.2l
  • 2006 Mercedes C350 - V6 3.5l - RWD or 4x4
  • 1997 Mercedes C36 - L6 3.6l
  • 1998-2000 Mercedes C43 - V8 4.3l
  • 2005-2006 Mercedes C55 - V8 5.5l
  • 1998-2004 Mercedes CL500 - V8 5.0l
  • 2001-2007 Mercedes CL55 AMG - V8 5.5l
  • 1998-2006 Mercedes CL600 - V12 5.5l or V12 5.8l or V12 6.0l
  • 2005-2007 Mercedes CL65 AMG - V12 6.0l
  • 1998-2005 Mercedes CLK320 - V6 3.2l
  • 1999-2003 Mercedes CLK430 - V8 4.3l
  • 2003-2004 Mercedes CLK500 - V8 5.0l
  • 2001-2006 Mercedes CLK55 AMG - V8 5.5l
  • 2006 Mercedes CLS55 AMG - V8 5.5l
  • 1997-1999 Mercedes E300 - L6 3.0l
  • 1997-2007 Mercedes E320 - L6 3.2l Diesel - RWD or AWD
  • 1997-2006 Mercedes E320 - V6 3.2l - RWD or AWD
  • 2006 Mercedes E350 - V6 3.5l - RWD or 4x4
  • 1997 Mercedes E420 - V8 4.2l
  • 1998-2002 Mercedes E430 - V8 4.3l
  • 2003-2004 Mercedes E500 - V8 5.0l
  • 2005-2006 Mercedes E500 - V8 5.0l - RWD or 4x4
  • 1999-2006 Mercedes E55 - V8 5.5l
  • 2002-2007 Mercedes G500 - V8 5.0l - RWD or 4x4
  • 2003-2007 Mercedes G55 AMG - V8 5.5l - RWD or 4x4
  • 1998-2002 Mercedes ML320 - V6 3.2l - RWD or 4x4
  • 2003-2005 Mercedes ML350 - V6 3.5l - RWD or 4x4
  • 1999-2001 Mercedes ML430 - V8 4.3l - RWD or 4x4
  • 2002-2005 Mercedes ML500 - V8 5.0l - RWD or 4x4
  • 2000-2003 Mercedes ML55 - V8 5.5l - RWD or 4x4
  • 1996-1999 Mercedes S320 - L6 3.2l
  • 2006 Mercedes S350 - V6 3.7l
  • 1996-1999 Mercedes S420 - V8 4.2l
  • 2000-2006 Mercedes S430 - V8 4.3l
  • 1996-2006 Mercedes S500 - V8 5.0l
  • 2001-2006 Mercedes S55 AMG - V8 5.5l
  • 1996-2007 Mercedes S600 - V12 5.5l or V12 5.8l or V12 6.0l
  • 2006-2007 Mercedes S65 AMG - V12 6.0l
  • 1996-2003 Mercedes SL500 - V8 5.0l
  • 2003-2006 Mercedes SL55 AMG - V8 5.5l
  • 1996-2006 Mercedes SL600 - V12 5.5l or V12 6.0l
  • 2005-2006 Mercedes SL65 AMG - V12 6.0l
  • 1998-2004 Mercedes SLK230 - L4 2.3l or V6 3.2l
  • 2002-2004 Mercedes SLK32 AMG - V6 3.2l
  • 2005-2007 Mercedes SLR McLaren - V8 5.5l
  • 2004-2007 Dodge Sprinter Van 2500 / 3500 - L5 2.7l Diesel
  • 2006-2007 Dodge Charger, SRT - V6 3.5l or V8 5.7l or V8 6.1l
  • 2005-2007 Dodge Magnum R/T - V8 5.7l
  • 2005-2007 Dodge Magnum SXT - V6 3.5l
  • 2006-2007 Dodge Magnum SRT-8 - V8 6.1l
  • 2007 Dodge Nitro - V6 4.0l
  • 2005-2007 Chrysler 300 and 300C - V6 3.5l or V8 5.7l or V8 6.1l - RWD or AWD
  • 2007 Chrysler / Plymouth Aspen - V8 5.7l - RWD or AWD
  • 2004-2007 Chrysler Crossfire - V6 3.2l
Old 09-14-2011, 06:24 PM
  #217
Brian420's Avatar
e500
Sorry I'm done did'nt mean to thread hijack. I been doin this for a long time and hate getting talked to like I'm the idiot.. People can learn if they open there ears. God Speed I apologize... Yea make the kit so I don't have to make it myself!
Old 09-14-2011, 07:03 PM
  #218
gaspam's Avatar
i am convinced you have no clue what you are talking about and after this i am done with you
EXACTLY the same you say? interesting the gear ratios are not the same ... hmm, meaning different gears.... hmm, meaning , NoT EXACTLY tHE sAme
Mercedes-Benz 722.6 Transmissions
Gear 1 2 3 4 5 R Final
5G-TRONIC 3.59 2.19 1.41 1.00 0.83 3.16 ?
5G-TRONIC (Mercedes-Benz R170 SLK 200 KOMPRESSOR) 3.95 2.42 1.49 1.00 0.83 3.15 3.46
5G-TRONIC (Mercedes-Benz R170 SLK 230 KOMPRESSOR, 320)[2] 3.95 2.42 1.49 1.00 0.83 3.15 3.27
5G-TRONIC with SPEEDSHIFT (Mercedes-Benz R170 SLK 32 AMG)[2] 3.59 2.19 1.41 1.00 0.83 3.16 3.06
AMG SPEEDSHIFT R 3.56 2.19 1.41 1.00 0.83 ? 3.06
and you think the 2007 Dodge Nitro has the EXACT same tranny as the E55 according to your list
but then again who cares about the tranny... we are talking boosted engines here... and back to original point is 15 PSI on stock e500 motor without proper internals... good luck like i said before, post vids
Old 09-14-2011, 07:06 PM
  #219
gaspam's Avatar
the e500 2004-2009 has the 7-G tranny and i thought you had a 2004 so yeah that was my mistake in assuming you didnt have older version.. but anyways if you see above not all 722.6 trannies are EXACTLY the same as you think they are
Old 09-14-2011, 07:27 PM
  #220
Brian420's Avatar
e500
Talking
Forget about the rest of the trannys the 55 and 500 tranny is exactly the same! Atleast the 2003 version for a fact is the same. As for the psi thing, my lil bro runs 15 psi in a 2.5 srt 4 engine! I can't run 15 psi on a v-8 motor without causing issue's ???? I can bolt on a kleeman sc and get 500 hp wihout ecu tune or nada! I plan on doing 7-7.5 psi on each side of the motor. NOT 15psi a side which would be a combined 30psi. Maybe u miss interpreted what I meant on that.. I've already talked to many people I'm gonna have to change injectors fuel pump and many other things. Anything will work you keepin throwin money at it... Hey if my engine blows gives me a reason to buy a new one right! Atleast everything is there already for the new motor and perfected so to speak on the old.
Of course a neon does'nt have the same tranny are cars have ! Just saying I was in tranny shops and asking for any tranny upgrade money can buy. Everyone told me there's nothin diff but the renntech tranny upgrade.
Don't want to keep havin a pissin match here, so lets try to stay on Topic.
Old 09-14-2011, 07:53 PM
  #221
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
Everyone agrees -- just not the easiest or efficient way to go about it --- Good luck -- we are all eager to see the results !!!
Old 09-14-2011, 07:57 PM
  #222
Awesome -- You keep throwing your money at it -- You use that lottery winner mentality. I am poor and that is too difficult for me to comprehend.
Good luck
Old 09-14-2011, 09:04 PM
  #223
Brian420's Avatar
e500
Transmissions
Model Standard Optional E 200 CDI ? ? E 220 CDI ? ? E 280 CDI 7G-TRONIC ? E 280 CDI 4MATIC 7G-TRONIC ? E 300 BlueTEC 7G-TRONIC N/A E 320 BlueTEC 7G-TRONIC N/A E 320 CDI I6 5-Speed Automatic N/A E 320 CDI V6 7G-TRONIC N/A E 420 CDI V8 5-Speed Automatic ? Model Standard Optional E 200 NGT ? ? Model Standard Optional E 220 KOMPRESSOR 5A/6H|? E 230 7A/6H|? E 280 7G-TRONIC ? E 280 4MATIC 5-speed automatic - E 350 7G-TRONIC ? E 350 4MATIC 5-speed automatic - E 350 CGI ? ? E 500 (2002-2003) 5-speed automatic - E 500 (2004-2009) 7G-TRONIC - E 550 4MATIC 7G-TRONIC - E 55 AMG 5-speed automatic N/A E 63 AMG 7G-TRONIC with AMG SPEEDSHIFT N/A [edit] Safety
http://en.wikipedia.org/wiki/Mercedes-Benz_W211
Again ONLY E63's and such have speedshift... Should be called slowshift compared to the e55.
Old 09-14-2011, 09:15 PM
  #224
Brian420's Avatar
e500
Good luck
My pockets aint that deep but I like custom!
Old 09-14-2011, 09:37 PM
  #225
e500slr's Avatar
2011 E63, 2013 CLS63
No offense but the C55 is a girls car, it was one of Mercs ugliest designs. They fixed the C class with the C63 era C Class but the old one is just stupid. The interior is depressing too. Why would anyone spend money on that car?
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
Quick Reply: SPEEDRIVEN | E55 Twin-turbo PKG (feeler)
