EPIC FAIL Seat Position!!! PLEASE HELP
I am an adult and can figure out how to adjust a seat appropriately with what is in the back seat of the car without the car doing it for me. This feature is awful, dangerous and grossly dumb. I want to have this removed ASAP what do I need to do.
Regards,
KC
or get the seat into a comfortable position with the rear seats up, then unplug all the cables from the underneath of the seat so it won't be able to move forward when you bring the rear seats down.
KC
What's going on is that the safety switch on the rear seat indicates that the rear seat isn't in correct position. It then assumes that the rear seat is folded and adjusts the front passenger seat to make room.
The best solution would be to fool the switch in the rear seat physically in some way. But make sure it is properly locked each time you have had the back seat lowered since you wouldn't get a warning if not. You don't want to be in a crash with the seat not properly locked...
I typically run without the driver side seat bottom in place.
