car is nose diving when i try to slam the throttle
Old Jun 30, 2011 | 08:54 PM
saleen01's Avatar
2004 E55
2004 e55 , haven't driven it in a few days, took it out, its about 80 degrees in toronto, car has a 180mm pulley and eurocharged intercooler pump, tried to full throttle it on an open road and the car bogged, basically nose dived.......no back fire, but noooo power, let off the gas, car drived normal...its only at full throttle..............
any ideas????
Old Jun 30, 2011 | 11:12 PM
nicco's Avatar
E55 AMG
What are you IAT's at?
Old Jun 30, 2011 | 11:29 PM
jwoodcl55's Avatar
E55 AMG
Make sure to check your fuses... If the pump was not installed correctly you may have blown a fuse and the "nose dive" is because the cm30 pump is not even on
I believe eurocharged pump is the Johnson Cm30
Old Jun 30, 2011 | 11:45 PM
GT-ER's Avatar
2005 E55 AMG
Is it immediate? Or after a few seconds going WOT?
Old Jul 4, 2011 | 07:34 AM
saleen01's Avatar
2004 E55
I have no way on checking the IAT's
car nose dives instantly, feels like it wants to take off, but something is holding it back...check engine light is also on.
where is the fuse for the CM30?
thanks
Old Jul 4, 2011 | 09:14 AM
GT-ER's Avatar
2005 E55 AMG
Scan it. If it's instant then I doubt it's your pump.
Old Jul 4, 2011 | 10:22 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
check engine light could be related somewhat related. Get it scanned>
Old Jul 4, 2011 | 02:22 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Visual inspection? Check blower belt, and other loose items such as connections, etc.
Old Jul 5, 2011 | 07:36 AM
saleen01's Avatar
2004 E55
yesterday the check engine light suddenly went away ...very weird.....friend came over and scanned the car, this is what he pulled out...any ideas guys? I have a feeling it may have something to do with the fack that the last tank i let the car go all the way down to reserve and then some....maybe some sediment at the bottom of the tank got picked up? anyway thankfully it runs ok now....
Attached Thumbnails car is nose diving when i try to slam the throttle-img00389-20110704-1819.jpg   car is nose diving when i try to slam the throttle-img00390-20110704-1819.jpg   car is nose diving when i try to slam the throttle-img00391-20110704-1819.jpg   car is nose diving when i try to slam the throttle-img00392-20110704-1820.jpg
Old Jul 5, 2011 | 09:43 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
what is the stored fault in the ECU?
Old Jul 5, 2011 | 10:09 AM
GT-ER's Avatar
2005 E55 AMG
That's not likely since the fuel pump is ALWAYS sucking fuel from the bottom of the tank so going low of fuel doesn't make a difference.
Also, those pics really don't tell me much...I need to know the codes stored as shardul stated.
Old Jul 5, 2011 | 10:30 AM
saleen01's Avatar
2004 E55
We're fairly new using the Star, can you tell me where we have to go to see the stored codes? is there a step by step somewhere?
