anyone have a hook up for an amg 80mm tb?
Old Jul 11, 2011 | 10:31 PM
skratch77's Avatar
2005 E55
IM trying to hunt one down so if anyone has one laying around send me a pm.
Im also going to do something that I dont think has been done before and I think it will pick up 30-40whp.
I dont want to spill the beans yet but its going to work on stock cars.
Old Jul 11, 2011 | 11:28 PM
BenzoBoi's Avatar
Super Moderator
W221
Check you box brother!
Old Jul 11, 2011 | 11:35 PM
skratch77's Avatar
2005 E55
Thanks bro ill call the shop tom!!!.
Here's is a hint if what im doing...I just got a stock sc inlet and im going to cut that huge chunk of metal out of it that directs the air.
I don't know if its going to cause any drivability issues but im willing to try it out for the forum.
Ps thanks chad for getting me your inlet that fast!
Old Jul 11, 2011 | 11:56 PM
GT-ER's Avatar
2005 E55 AMG
pics....yesterday!
Old Jul 12, 2011 | 12:00 AM
AWOL's Avatar
e55
One would think that has to be there for a reason
Old Jul 12, 2011 | 12:02 AM
skratch77's Avatar
2005 E55
Ill find out soon but that sucker is blocking like half the airflow
Old Jul 12, 2011 | 12:07 AM
GT-ER's Avatar
2005 E55 AMG
any pics of what you guys are talking about? How about also eliminating the bypass valve...I think it's pretty useless.
Old Jul 12, 2011 | 12:13 AM
skratch77's Avatar
2005 E55
Ill take a pic for you
Old Jul 12, 2011 | 01:11 AM
tbal's Avatar
Haters crazy
Props for trying this! Looking forward to the results!
Old Jul 12, 2011 | 01:28 AM
AMGPilot's Avatar
2004 E55
That "Blockage" is needed. Cut that out and you're going to lose boost and supercharger efficiency
Old Jul 12, 2011 | 01:34 AM
KLR CLS's Avatar
CLS63 PP
I tend to agree. It's not like adding the part of the casting was easy. They must have done it for a reason.
Old Jul 12, 2011 | 01:41 AM
Forrest Gump 9's Avatar
shrimp boat
That's wild. I was just about to do the same thing. Well, i guess I'll be waiting for your result instead. Good luck.
Old Jul 12, 2011 | 01:49 AM
shrimp boat
But to validate the gain I think you should do it with the stock 74mm tb instead.
Old Jul 12, 2011 | 01:56 AM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Anytime!
Old Jul 12, 2011 | 09:11 AM
skratch77's Avatar
2005 E55
Just to be clear,Im doing this to the STOCK s/c inlet,here is a pic of chads old stock inlet that I am going to mod.
Im also goin to bore the tb opening part out as much as I can and make a few holes to be able to swap from the stock tb or to a 80mm.Thats why Im looking for an 80MM also
Here is a picture of what I want to cut out.
Old Jul 12, 2011 | 09:30 AM
GT-ER's Avatar
2005 E55 AMG
You can't cut that out, it's going to either kill boost entirely or affect it REALLY bad. The inlet of the sc screws is in the above area, the hump block reversion and also help make a smooth transition to the inlet of the screws. I've never disassembled an E55 supercharger, but I have disassembled other SC's and that hump is mandatory.
What I DO wish to do is block the lower throttle body.
Old Jul 12, 2011 | 09:35 AM
skratch77's Avatar
2005 E55
How will I loose boost?
Old Jul 12, 2011 | 09:48 AM
GT-ER's Avatar
2005 E55 AMG
Because of reversion. That humps helps keep boost inside the screws trapped. It's also aerodynamic.
Old Jul 12, 2011 | 09:51 AM
shrimp boat
The hump is not air-tight again the sc though. There's a gap between the SC and the hump (the gasket only outline the sc inlet, not the hump, hence the gap).
Old Jul 12, 2011 | 09:56 AM
skratch77's Avatar
2005 E55
That hump might be there to help off boost throttle smoothness,like if you went wot for 2 seconds and then let off the gas 100%
I cant see us losing boost as the twins are sucking air in,I will look at the setup closly when the blower is off the car and might just cut out a small chunk and see what happenes
Old Jul 12, 2011 | 10:06 AM
GT-ER's Avatar
2005 E55 AMG
Well, there isn't a single SC ( roots or screw ) that I've worked with that doesn't have this hump. I'm all up for testing new ideas so you definitely have my vote for testing if you have the time to spare...but the theory is that it'll lose a lot of efficiency without that hump.
Old Jul 12, 2011 | 12:20 PM
AMGPilot's Avatar
2004 E55
It's not a theory it's a fact. that "Hump" is what keeps the pressure in the screws
Old Jul 12, 2011 | 03:02 PM
E55W's Avatar
E55
i say go for it, see whats the out come
Old Jul 12, 2011 | 03:07 PM
skratch77's Avatar
2005 E55
plans have changed a little,going 80mm inlet with 80mm amg tb from benzoboi.
Old Jul 12, 2011 | 03:47 PM
GT-ER's Avatar
2005 E55 AMG
Can you unplug the bypass throttle body to see what happens? Or is the plug accessible enough that I can do it without pulling the inlet? I think we can get full boost at all times with it disconnected and cheat the torque management.
