Largest throttle body kit for 55
Old Apr 23, 2013 | 11:29 PM
  #76
KenH's Avatar
2007 E63 AMG, 2009 ML63 AMG
This might be a stupid question, but would it be possible to mount two TBs on the two intake tubes at the front of the engine where there is more room? That is how my Viper twinscrew SC is setup and it is similar to the basic e55 layout with the exception of the location of the TB.
You would need to mechanically link the two TBs and figure out how to run the TPS off one of them. It doesn't seem like it would be that hard to do but I am also not very familiar with the e55 SC setup.
Old Apr 23, 2013 | 11:32 PM
  #77
KenH's Avatar
Actually, now that I take a closer look, the TBs would be difficult to link together on the e55 due to the wide spacing that the intake pipes must follow.
Old Apr 23, 2013 | 11:42 PM
  #78
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Originally Posted by Crissus
Hmmm... if i was aware that there is a fitting 90mm TB, i wouldnt have bought that 82mm one... Of course custom Y-Pipe, but well... why not?
36whp from 82mm to 90mm... I somehow cant believe that, i would have waited until my ECU has adapted itself and measure again.
I've been running the 90mm for about 2 months now and my car is a daily driver. I didn't see 36whp with the 90, but closer to 15-20whp over the 82mm. When I dynoed, I had made a few other changes so its my best guess.
My 82 was actually ported by maxbore and measured 85mm and I also did the shaft grind so that could have played a part. The 90 had no work done to it. No CEL's and I did do the rpm increase thru star and also reinitialized the adaptations as well so that it could properly calibrate. The good part of the 90 is that it holds the peak power longer since before it my peak would drop off at around 5800rpm but with the 90 it now happens at 6300.
Old Apr 23, 2013 | 11:46 PM
  #79
adianaty's Avatar
I mocked it up so it can fit. Problem is getting it to idle which will be next to impossible. You don't need more than a 90 with the stock blower anyway. It will run out of air before the TB does.
Old Apr 24, 2013 | 12:45 AM
  #80
MAN55LE's Avatar
04 E55 AMG
Old Apr 24, 2013 | 01:49 AM
  #81
cm60k's Avatar
15-20whp over the 82mm is a great result...,,
where can we get the 90mm connector plug from....?,
and do you use some kind of adapter or spacer then welding it to the snout....??
ZAYED,,
Old Apr 24, 2013 | 01:55 AM
  #82
cm60k's Avatar
Originally Posted by berti_00
sure are and here is another sneak peak :P
going from 3"-4"
What a great welding Albert,, its better that factory weld touch either.....
ZAYED,
Old Apr 24, 2013 | 02:21 AM
  #83
adianaty's Avatar
The 90 is nothing like the 82 conversion and requires basically 1.5-2" worth of the inlet to be refabricated. The 90 is so big that it is actually larger than the MB casting. You can see it in the pictures that I posted earlier in the thread. The connectors can be purchased from a dodge and mercedes dealership and need to be soldered together. It is not a plug and play situation like the 82 but obviously not impossible either. As mentioned, you will need a custom Y-pipe as well.
One thing to note, is that in order to get these gains, you have to be "choking" the 82mm. I believe Forrest is running a 180mm crank with the smaller upper pulley which would be equivalent to a 195mm. You shouldn't expect to achieve similar results with just a 180mm or smaller pulley since its likely that the 82 tb is enough.
Old Apr 24, 2013 | 03:22 AM
  #84
cm60k's Avatar
Thankss for this info.,
Do you have the part # for this connector....?
did MB using the same connector in some of their sensors....??
ZAYED,,
Old Apr 24, 2013 | 05:55 AM
  #85
Hulk's Avatar
A Merc
The plug is the easy part
You realize that the fab work to make the 90mm work is the hard part and not cheap
Old Apr 24, 2013 | 08:32 AM
  #86
cm60k's Avatar
There are many types of a T/B connectors, which one for a BBK T/Bs......??
Name:  TB connector 1.jpg
Name:  TB connector 2.jpg
Name:  TB connector 4.jpg
Name:  TB connector 5.jpg
Name:  TB connector 6.jpg
ZAYED,,
Old Apr 24, 2013 | 10:37 AM
  #87
Forrest Gump 9's Avatar
shrimp boat
Attachment 258008
Attachment 258009
Attachment 258010
Attachment 258011
Attachment 258012
ZAYED,,
Go to the dealer and ask for the srt8 throttle body plug. It should have six wires.
Old Apr 24, 2013 | 11:14 AM
  #88
cm60k's Avatar
Which dealer...?
"Jeep/Dodge/Chrysler/Chevrolet"
ZAYED,,
Old Apr 24, 2013 | 11:28 AM
  #89
shrimp boat
Which dealer...?
ZAYED,,
Anyone of those should be fine. Better yet, buy the correct tb, bring it to the dealer and order the plug.
Old Apr 24, 2013 | 11:47 AM
  #90
cm60k's Avatar
Thanks, i will try that,
we don’t have a people in the dealer here, we only have a green Zombies here....,
im afraid when i asked them about the connector, they will said; the pharmacy two buildings beside as....
ZAYED,,
Old Apr 24, 2013 | 02:15 PM
  #91
adianaty's Avatar
ZAYED,,
If they can't help you, PM me and I will get you sorted. The connector isn't that cheap from MB and Dodge isn't that much better. It will be about $100-$150 when all said and done. Also, if you need an inlet done for the 90, I have a shop that can do it but as Hulk said, its not like an adapter plate and costs some $$$.
Old Apr 25, 2013 | 04:51 AM
  #92
cm60k's Avatar
I will try to go to green Zombies here,, if can’t help, i will contact you,
Thankss for your support....
ZAYED,,
