Old Jun 17, 2015, 07:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering and Suspension Guides
Print Wikipost
W211 KW Coilover Swap Part 3
Rating: Thread Rating: 10 votes, 4.90 average.
Old Nov 7, 2013 | 12:27 PM
  #351
AutoLuxury's Avatar
2013 GLK 350 2013 GL450
I prefer BC Racing!
Old Aug 11, 2014 | 10:14 PM
  #352
Bipasha493's Avatar
CLS 55 AMG
can anyone please tell me if the E55 and CLS 55 suspension is different from each other?
Old Aug 12, 2014 | 04:56 AM
  #353
masterross's Avatar
w211 '04 Avangarde
I used before front suspension from CLS to my E-klasse, so I tell, yes they are identical.
Old Aug 12, 2014 | 02:39 PM
  #354
Bipasha493's Avatar
CLS 55 AMG
thank you
Old Nov 2, 2014 | 12:51 PM
  #355
underdogg's Avatar
2006 cls55
help needed coilovers swap for cls55
Can someone give me a part list an what coilovers I can get please
Old Nov 2, 2014 | 06:53 PM
  #356
kponti's Avatar
E63
I don't know about the KW kit, but with the BC, it's the kit plus the rear lower control arm from the e350 and it's corresponding bolts.
Old Nov 2, 2014 | 07:36 PM
  #357
underdogg's Avatar
2006 cls55
Do you know where I can get the parts from e350 , I see d2 have a set of coilovers on ebay
Old Nov 2, 2014 | 07:43 PM
  #358
kponti's Avatar
E63
I got it from Amazon. The w211 E350
Old Nov 3, 2014 | 10:25 AM
  #359
MJ50's Avatar
Super Moderator
bone stock E55 AMG
autohausaz.com, parts.com...
Old Nov 3, 2014 | 02:54 PM
  #360
SICAMG's Avatar
2005 e55 AMG
This swap is easy. EBAY....BC coil over kit 900.00 EBAY E350 rear lower controll arms 50.00 to 80.00 dollars easy almost every day. Done . Pop them in and you are trouble free for years to come.
Old Nov 3, 2014 | 03:55 PM
  #361
underdogg's Avatar
2006 cls55
I need some part # because I don't know what I'm looking for I went on ebay an them other sites
Old Nov 3, 2014 | 07:00 PM
  #362
sergs99m3's Avatar
M3, E55, SL55
BenzWorks has everything in stock
Old Nov 4, 2014 | 11:30 AM
  #363
AutohausAZ-Mike's Avatar
Former Vendor of MBWorld
Thank you for the shout out MJ50, it's much appreciated.
Old Sep 29, 2015 | 05:50 AM
  #364
PSH72's Avatar
E220 CDI Avantgarde
Hi
I have a S211 2003 Avantgarde, I just made the air leveling suspensior conversion for the Arnott coil springs.
But im having some issues, according to Arnott instrutions it says to turn off the module that lies at the feet of the passenger, but doing that my bi-xenon doesn´t make the 4 leveling mods.
But if I plug the module back on, it makes all the 4 leveling setps, but doing that I have the error message saying that the wagon is down.
Has any one done the coil spring conversion on the wagon and if so, how did you reset the error.
(will be possible to disable the compressor)
Old Sep 29, 2015 | 06:17 AM
  #365
masterross's Avatar
w211 '04 Avangarde
You mean air compressor?
I'm not sure how i did it but i had same issue when I disabled some modules in SDS.
Anyway at the end i removed the relay of the compressor out.
And the auto leveling is working.
Old Sep 29, 2015 | 06:23 AM
  #366
PSH72's Avatar
E220 CDI Avantgarde
Yes the air compressor
When you say that the auto leveling is working, do you refer to the xenon leveling ?
You removed the the relay of the compressor did it apear error, and did you still disconet the module under passenger side, our just as said the the air compressor relay?
Old Sep 29, 2015 | 07:11 AM
  #367
masterross's Avatar
w211 '04 Avangarde
Hi,
yes. bi-xenon auto leveling.
i didnt remove any module under passenger side.
I just removed the relay and after that the compressor too (sold).
I also played with SDS modules settings but dont remember what exactly (it was few years ago) and i dont have any warning after that.
Old Sep 29, 2015 | 07:22 AM
  #368
PSH72's Avatar
E220 CDI Avantgarde
Hi,
I have the Active Headlights Bi-Xenon on my S211, that dont work with the passenger module disconected like said on arnot instrutions, if I plug it on agian it works, but it makes apear the information of wagon with the up arrow.
My mecanic tryed to reset it with sam unit, but without success.
I may try and remove the relay, do you remember were is the compressor relay and what collor?
Old Sep 29, 2015 | 07:43 AM
  #369
masterross's Avatar
w211 '04 Avangarde
Dont remember where it was but here is the pic of it:
https://www.dropbox.com/s/d9ikhu9zzv...254-1.jpg?dl=0
But you NEED to do coding in SDS to disable warnings.
Look in the first post.
I suggest you to do it one by one and test it.
If i remember right, you should NOT change Airmatic suspension setting to Coil suspension setting in SDS.
Old Sep 29, 2015 | 07:58 AM
  #370
PSH72's Avatar
E220 CDI Avantgarde
I dont have airmatic suspension, I have rear air suspension only, And I cant change it to coil suspensio, because there is only that possibility for the cars to the wagons (S211) does not exist on the SDS
Old Sep 30, 2015 | 05:16 AM
  #371
masterross's Avatar
w211 '04 Avangarde
Hi mate,
even if it's only air suspension the modules should be listed in SDS.
Check carefully.
Old Apr 4, 2017 | 01:26 AM
  #372
hellah fresh's Avatar
Was 89' 300E, Now 93' 500SEL
That relay location is the one inside the engine back that is located in the back towards the windshield?
Old Oct 6, 2018 | 07:53 AM
  #373
ponderingnugget's Avatar
2004 e500
Thanks for such a detailed post, and for sharing your knowledge. That E55 looks amazing! I just ordered a coil over kit for my w211 e500. Do you have any suggestions about where I can find the torque specs for all the parts?
Old Dec 4, 2020 | 06:43 PM
  #374
AMGALBO's Avatar
2003 Mercedes-Benz E55
Coilovers $?
Originally Posted by sergs99m3
Hello fellow members, As some of you may know my name is Serge. I own a shop in SoCal that specializes in Mercedes Benz. Wanted to share with you another Coilover swap on a 211 E55 AMG. This is the 3rd one.
First, released air in suspension with SDS. Removed all struts and bellows. Ordered the correct parts for installation. Installed Coilovers, adjusted height and dampening. Re-programmed the Instrument Cluster, Central Gateway and EIS. No gremlins or problems with install.
Here are some pictures.
Attachment 381394
Attachment 381395
Attachment 381396
Attachment 381397
Attachment 381398Attachment 381399
Attachment 381400
Attachment 381401
Everything went smooth, install was great. Since there is a lot of people that want the parts list. Please PM me and i will gladly pass it on. There is a total of 12 parts. If programming is needed I can also help. Enjoy and Thanks
what is the price tag at your shop. And in what city in California are you located?
You have already rated this thread Rating: Thread Rating: 10 votes, 4.90 average.
