- Mercedes Benz E Class AMG: How to Install Coilovers
Step by step instructions for do-it-yourself repairs
W211 KW Coilover Swap Part 3
I might pull the trigger on all the parts from spinn's post just to give the conversion a shot.
The list of parts I used was that sent out by Serge as well as a parts list posted here by spinn. A few of the parts I ended up requesting to be purchased were not needed at the end (and I can find that out later this week what they were--cost was minimal <$20 iirc)
Thanks, Serge/Benz-Works, for your guidance on the install as well.
I haven't spent much time doing the background research, but I remember reading that the 2005 and 2006 E55s had some upgraded front suspension parts over the '03 & '04 models (CLS steering rack, and possibly different front A-arms?).... I was curious if those changes would have any effect on this parts list or if it's 100% identical for all years ('03 - '06)???
-G
-G
Incidentally, I do not rub either.
Most importantly though is that the car is predictable. I'm more confident that it will go where I want it to rather than where it might "lean over to".
I currently have my compression & rebound settings set to 6/12 in the rear and 5/12 in the front. If I set it back to a 6 or even dial things up to a 7/12, then the car will have that same highway feel as it did with the airmatic. Those people that are running 20" wheels with very low profile tires may want to set it up that way. I, on the other hand run the continental extremecontact dws's with the forgestar 19's and so what I have it set to right now feels good for highway/city driving.
Going by the photos (and obviously there may be a pound or two difference in my totals), here is what I came up with:
Each of the airmatic shocks and air spring assemblies weigh in at 19.5lbs and 16lbs. So that comes out to 71lbs. The two control that are replaced weigh in at 4.5lbs each and are replaced with ones that around 6.5lbs each. Then take into consideration that each KW coilover (with perch, etc) is around 13.5lbs and 14lbs, which is 55lbs. So 59lbs total installed
So...~12lbs total? Anyone else that has done this conversion, does this sound reasonable?
