Need Help! Clamps on rubber housing that go from Airboxes to TB
Old Aug 19, 2011 | 11:02 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Hey Guys,
Ok so taking these clamps off was not easy and I was careful so I took them off no problem. Now putting them on is a different story. Is there a trick to getting these on? I tried almost any method I could think of and sat there working on this for almost an hour with a buddy of mine, finally giving up and coming on this forum thinking there must be a easy solution to these snapping back on with no problems.
So who wants to be nice and kind and help me out, how do I get these clamps to close back up together?
Thanks Guys
Old Aug 19, 2011 | 11:12 AM
Triman2008's Avatar
S55 AMG
I used a pair of channel lock pliers and just pinched it shut....seemed to work okay for me. I hope you get it figured out. Good Luck.
Old Aug 19, 2011 | 11:22 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Nah its always been the devil bro. Some guys have a few tips. Hope they chime in. My tech uses a kinda angled set of pliers. Always like the ones for removing c clips to get his on. Still a beotch.
Here is one tip from an OG
Here is a picture for the person with the clamp question. It is a pain to deal with them but it can be done. Mini screwdriver to release, side cutters to close and some technique and persistance helps. This is Ted's replacement installed.
Old Aug 19, 2011 | 11:28 AM
Thanks, Ill try everything today
I think it took me less time to install my Surge tanks than to clip one clamp together.
Man these things are crazy, I'm gonna be back in the garage at it again with these suckers and I have 4 to do.
Thanks for the help.
Old Aug 19, 2011 | 01:54 PM
Forrest Gump 9's Avatar
shrimp boat
I didn't know we can re-use those things. I just use normal worm clamps on mine.
Old Aug 19, 2011 | 02:19 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
I was going to suggest just swapping them out, as well. If you want to keep a nice clean look, use some T-bolt clamps. Otherwise, a standard hose clamp will work.
Old Aug 19, 2011 | 03:35 PM
Def want to use a cleaner look for the car, do you have a link of what these clamps look like? can these be purchased at a local car part store?
KAMIL
Old Aug 19, 2011 | 10:28 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
http://www.summitracing.com/search/B.../?autoview=SKU
Old Aug 21, 2011 | 03:08 AM
Ok I used these and they worked 100% perfect took me about 5 minutes to get all 4 of these clamps to snap back in.
Old Aug 25, 2011 | 10:40 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Yeah if you can't get it a normal worm clamp will work. Good luck.
Aaron
Old Aug 26, 2011 | 12:54 AM
Got it with the tool in the picture above. Very helpful when anyone tries to clamp these back together.
