Who is going for 1/4 mile PB this fall?
Old Sep 12, 2011 | 05:37 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Roll call!
I hope to get to the track in the next couple of weeks. Cant wait!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 12, 2011 | 05:47 PM
BenzoDoc's Avatar
2015 E63S 4Matic
PB/Baseline for sure.
Hoping I can wear out my rears in time to buy new wider tires. Current rears are mighty stretched OEMs
Old Sep 12, 2011 | 06:20 PM
GT-ER's Avatar
2005 E55 AMG
I'll probably go to see if I can get my Toyo T1R's to stick. I was told that last time I went ( I ran a 12.5@118mph with a 2.3'ish 60ft time ) that the track had ZERO prep and that if properly prep'd I could get a 2.0 or less 60ft on the same tires...We'll see I guess.
Old Sep 12, 2011 | 06:32 PM
skratch77's Avatar
2005 E55
I sold my drag setup
Old Sep 12, 2011 | 07:10 PM
LOCO 05' E55's Avatar
P-Carro
Buy mines
2 sets of 16"- one with Mickeys the other with Hoosiers..pick one! they never saw 1.70s and both went 10s
Old Sep 12, 2011 | 07:19 PM
AWOL's Avatar
e55
I sold my dr's. I might go this Friday, not looking to beat my et, just my mph. I went two weeks ago with a DA of 2714, I went 12.1@119.04 with a 1.98 60'
Old Sep 12, 2011 | 07:33 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
with decent prep and a mild burnout to clean and warm the tread you'll do fine with t1r's. i've got a stack of slips with consistent 1.71 60ft's on the 19" variety of those tires.
Old Sep 12, 2011 | 08:20 PM
PLATINUM SPONSOR
2003 CL55
At least the E class can do sick burn outs, the damn CL has extra TQ mgt and it bogs down in the water box. Damn struggle each time to get tires hot.
Why is everyone selling thier track tires?
__________________
www.ultimatepd.com
Old Sep 12, 2011 | 08:58 PM
Forrest Gump 9's Avatar
shrimp boat
You better run 10s with all the mods you throw in your car!!
I'm hoping to improve another two tenth of a second. And may be with the help of the automotive gods, I'll get a 10.999s so I can die a happy man.
Old Sep 12, 2011 | 10:06 PM
GT-ER's Avatar
2005 E55 AMG
Not really...mine won't allow me to do a burn out no matter what I do and if I go into dyno mode it seems to disable my SBC and my car will barely brake.
Old Sep 12, 2011 | 10:55 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Weird, my 05 will spin power braking no problem. Just hit the traction control button and let her eat. I would sit in place for only like 2 seconds before then rolling forward spinning since I was only on street tires though so no reason for anything crazy but it lets me spin. What do you mean by it won't let you do a burnout, like it instantly kills power or you can't sit there for 10 seconds if you wanted?
click
Old Sep 12, 2011 | 11:04 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Im chasing my pb this fall brooke....should be interesting...
Old Sep 12, 2011 | 11:42 PM
BenzoBoi's Avatar
Super Moderator
W221
Look forward to your results!
I was going to go out one last time also and try to hit 10's on straight pump gas but I decided to sell my drag set up and concentrate more on the twisty track as I'm having more fun there. I was REALLY close to 10's but I'm happy with my straight pump time now and want to try going fast through a turn too. I'm MORE than sure I would hit 10's with a race tune but oh well...shoulda, coulda, woulda...
Best of luck! Really want to know what you are going to run!
Old Sep 12, 2011 | 11:54 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Going to try here too. Just need to install the 82mm, rear tank, new tune and pray for tens!
Old Sep 12, 2011 | 11:57 PM
E55Bullet's Avatar
Originally Posted by LOCO 05' E55
Buy mines
So you ran 10's with 1.7? Wow! I was under the impression that 1.5s were the solution!?
Old Sep 13, 2011 | 12:00 AM
GT-ER's Avatar
2005 E55 AMG
click
I don't know...I turn off the TC and it'll allow more wheel spin but after about about 2 seconds it'll cut power big time.
Old Sep 13, 2011 | 12:20 AM
P-Carro
I meant to say those DR's kept me below 1.7s consistently..
Old Sep 13, 2011 | 12:28 AM
E55Bullet's Avatar
Lol k. What was your 60' with the 10.8?
Old Sep 13, 2011 | 12:46 AM
P-Carro
1.61
Old Sep 13, 2011 | 01:07 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Does not everyone strive for a PB?
Old Sep 13, 2011 | 09:36 AM
V12Godspeed's Avatar
Your worst nightmare...
I am shooting for my best and a new record.
Old Sep 13, 2011 | 09:40 AM
Hellzno's Avatar
E55 AMG
what is PB? peanut butter....forgot jelly .... PBJ
Old Sep 13, 2011 | 09:42 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
last time i got me PB i broke my sub frame bolt. so dont know if i will be trying to get another one. BTW any local houston member are wlecome to borrow mt BFG DRs
Old Sep 13, 2011 | 09:47 AM
Benz-O-Rama's Avatar
If I see a 10.99 this fall, I'm selling my drag radials and not running her again.
Old Sep 13, 2011 | 10:03 AM
chawkins2001's Avatar
2006 E55 AMG
Buy mines
Sell just the hoosier tires
