E63 Intake manifold leak
If I have to change gasket what else should I swap out since I am in the area.
Any simple upgrade I can do at this time?
I took MAF cleaner and spray it around the intake front of motor and the idle change as if the car has a misfire that is how I know I have a leak.
I check all hoses making sure it not a hose. No hissing at idle nothing at all. But after my test I know I have a leak. 65k
With stock air filters I have no CEL with KNN I get a CEL for lean at idle which means more air that can be from the added air from KNN filters and the leak combine. Stock filters and no CEL light. I did not even clear the light it went away.
I really just want to snug the bolts down before doing the removal and all that work.
Take a can of Gumout and spray it in the front of the intake at idle and give it a good shot where the front bolts are located. You might have a leak and not even know it.
Local dealer said he seen them at 15k some even lower. He is amazing at 65k only now I get it. I think it was leaking all along and no CEL so no one notice.
