Limp Mode or IC Pump Gone Bad?
Old Nov 4, 2011 | 05:26 AM
CityOfAngels's Avatar
2006 E55 AMG
I just picked up an 06 E55 with 60k miles.
It is in excellent condition and was driving great initially. After a few runs, I experienced something like a limp mode, or perhaps it was the IC pump failing. I would floor it from any speed and it would just accelerate soo slowly. I tried turning the car on/off and it was driving fine for a couple runs but then the same problem. I'm not sure if this is the IC pump failure or an issue of something else.
Old Nov 4, 2011 | 09:33 AM
jmb614's Avatar
E55 AMG
Sounds like an IC pump issue. When I first picked up my E55 it was doing the same, I believe when IAT temperatures hit 200F the supercharger will shut down. I replaced the pump with a CM-30 and that took care of it. I later installed a Meziere WP-136 and a larger heat exchanger because of my modding needs.
Old Nov 4, 2011 | 10:34 AM
RedBullJnky's Avatar
you to Hate
IC pump is dead. I had same problem.
Old Nov 4, 2011 | 11:07 AM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
could be your Tensioner pulley as the stock ones are plastic and tend to break... this happened to me a month ago or so and car drove like it was on 2 cylinders...
Old Nov 4, 2011 | 11:12 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Deffinetly the IC pump.
Old Nov 4, 2011 | 12:03 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
100% the IC pump.
To get rid of it, get yourself a Johnson CM30 + heat exchanger and you're set to go!
Old Nov 4, 2011 | 12:43 PM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
After replacing 3 I/C pumps on my SL55. I finally think I have one that wont crap the bed. I'm always worried about bad gas too with used car buys. My SL came with 87 octane in it and it made only 380whp on the dyno. But in 3 gallons of 109 octane and made 412whp. Most likely just a bad pump, but crap gas can be an issue as well.
Old Nov 4, 2011 | 02:20 PM
novae500's Avatar
W211
before you create another post, which IC pump to buy? Search search. Johnson CM30, Meziere, Bosch all are good.
Old Nov 4, 2011 | 02:36 PM
2006 E55 AMG
I just dropped it off at the dealer. He said if the ic pump goes out, it usually doesn't come back on. But my car has power sometimes, and doesn't other times.
Old Nov 4, 2011 | 03:36 PM
vntgspd's Avatar
Porsche 911
I think what most are saying is that as the pump ages it is not able to keep up with the demands of the S/C intercooling and intake air temps rise, causing the computer to reduce power (shut down S/C). When things cool down, power returns.
This is happening to mine. I just bought the Bosch Pump (better "010" version) on Ebay for $130 shipped.
Old Nov 4, 2011 | 04:37 PM
danlnyc's Avatar
No need to drop it off at the dealer. I'm 100% certain its your IC pump. Very easy DIY
Old Nov 4, 2011 | 05:50 PM
2006 E55 AMG
Ya but I have a warranty
Old Nov 4, 2011 | 06:28 PM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Warranty FTW!! Now all you need is a heat exchanger Faisal!
Old Nov 4, 2011 | 06:32 PM
kustom2k1's Avatar
03SL55
Make sure they can replicate the problem otherwise they give back the car without fixing it.
