Would someone tells me how the meth kit still pump water/meth?
- noticed the meth tank got empty fast, I said ok, coz i turned it on while driving on highway to dubai and I went upto 220 km/hr speed sometimes on average speed of 160 km/hr.
- I filled once again with water coz i don't want the tank empty and water better than nothing for cooling.
- Just went out for couple of runs on street, and car started to buck (i hope i used the right word) and smoke came out, here I said, ok, maybe water mixture is not good with my current nozzle (D7 = 4XX cc/min as per devil's own), also on top of that, the water run out the tank soooooooo fast !!!!!!!!!
- Here I stopped, and started to investigate, what might went wrong so that water goes fast?
- I disconnect the circuit of meth kit, but the shock that water was still continue to go out of the tank and it is clear that it goes out of the nozzle and into the engine, and water levels in the tank goes lower and lower as I drive and the car bucks again as i believe the water flows in while low rpms and pressure on engine.
- Finally, I disconnected the switched completely and made open circuit but the problems continue till now.
Before I take the care to the tech, anyone has explanation or comment ?!
The meth is completely off (so the pump as it is open circuit) but still water flows, how?
Anyway, it is the time for solenoid.
Also, do you have datalogs since I'm not happy with my setup (M3 at TB and M7 pre IC) and wanted to compare results with you since your combination seems similar.
Ali
